查看: 2445|回复: 1
请教下,使用dma2d 功能显示图片时,透明功能该如何设置?
发表于 2018-1-13 17:37:34 | 显示全部楼层 |阅读模式
函数如下:
请教下 ,使用dma2d的透明功能改如何设置 ?
配置函数如下
static void BMP_DMA2D_ConverBuffer(uint32_t *pSrc, uint32_t *pDst,
                                    uint16_t _usX, uint16_t _usY,
                                    uint16_t _usWidth, uint16_t _usHeight,
                                    uint32_t InputColorMode, uint32_t OutputColorMode)
  uint32_t source ;
  uint32_t destination = 0;
    uint16_t  OutputOffset = 0;     // 行偏移
    uint16_t  NumberOfLine = 0;     // 行数,表示我们显示的数据需要的行数
    uint16_t  PixelPerLine = 0;        // 每行像素数, 每行需要显示多少个像素点
  __IO uint32_t  XaddrPutPixel = 0;
  source      = (uint32_t)pSrc;
  destination = (uint32_t)pDst;
  XaddrPutPixel = (BYTES_PER_PIXEL * (uint32_t)((_usY * LCD_PIXEL_WIDTH) + (_usX)));
  OutputOffset =  LCD_PIXEL_WIDTH - _usWidth;
  NumberOfLine =  _usHeight ;
  PixelPerLine =  _usWidth  ;
  __HAL_RCC_DMA2D_FORCE_RESET();             // 强制复位
  __HAL_RCC_DMA2D_RELEASE_RESET();           // 释放复位
  DMA2D->CR     &= ~DMA2D_CR_START;    // 停止dma2d
  DMA2D_Handle.Init.Mode          = DMA2D_M2M_PFC;
  DMA2D_Handle.Init.OutputOffset  = OutputOffset;         //OutputOffset;
  DMA2D_Handle.Init.AlphaInverted = DMA2D_REGULAR_ALPHA;  // No Output Alpha Inversion
  DMA2D_Handle.LayerCfg[1].AlphaMode = DMA2D_REPLACE_ALPHA;
  DMA2D_Handle.LayerCfg[1].InputAlpha = 0xFF;
  DMA2D_Handle.Init.RedBlueSwap   = DMA2D_RB_REGULAR;
  DMA2D_Handle.XferCpltCallback  = NULL;
  DMA2D_Handle.LayerCfg[1].InputColorMode = InputColorMode;   // 输入颜色模式
  DMA2D_Handle.Init.ColorMode             = OutputColorMode;  // 输出颜色模式
  DMA2D_Handle.LayerCfg[1].InputOffset = 0;
  DMA2D_Handle.LayerCfg[1].RedBlueSwap = DMA2D_RB_REGULAR;
  DMA2D_Handle.LayerCfg[1].AlphaInverted = DMA2D_REGULAR_ALPHA; /* No ForeGround Alpha inversion */
  DMA2D_Handle.Instance          = DMA2D;
  if(HAL_DMA2D_Init(&DMA2D_Handle) == HAL_OK)
    if(HAL_DMA2D_ConfigLayer(&DMA2D_Handle, 1) == HAL_OK)
      uint32_t timeout = 0;
          if (HAL_DMA2D_Start(&DMA2D_Handle, source, destination + XaddrPutPixel, PixelPerLine, NumberOfLine ) == HAL_OK)
            while((DMA2D->ISR & (DMA2D_FLAG_TC)) == 0)      //等待传输完成
              timeout++;
              if(timeout > 0X1FFFFF) break;          //超时退出
            __HAL_DMA2D_CLEAR_FLAG(&DMA2D_Handle, DMA2D_FLAG_TC | DMA2D_FLAG_CTC);
            DMA2D_Handle.State = HAL_DMA2D_STATE_READY;
            __HAL_UNLOCK(&DMA2D_Handle);
发表于 2018-1-14 20:49:51 | 显示全部楼层
下载HAL库软件包,里面应该有例子的,之前的标准库里面就有例子。
GMT+8, 2026-11-25 11:35 , Processed in 1.067167 second(s), 24 queries .
