查看: 2589|回复: 0
Discuz! 出现“您当前的访问请求当中含有非法字符“解决方法
发表于 2017-12-23 15:48:01 | 显示全部楼层 |阅读模式
解决办法在dz官方论坛,地址
http://www.discuz.net/thread-3484417-1-1.html
解决方案如下:
\source\class\discuz的discuz_application.php
查找
  • private function _xss_check() {
  •                 static $check = array('"', '>', '<', '\'', '(', ')', 'CONTENT-TRANSFER-ENCODING');
  •                 if(isset($_GET['formhash']) && $_GET['formhash'] !== formhash()) {
  •                         system_error('request_tainting');
  •                 if($_SERVER['REQUEST_METHOD'] == 'GET' ) {
  •                         $temp = $_SERVER['REQUEST_URI'];
  •                 } elseif(empty ($_GET['formhash'])) {
  •                         $temp = $_SERVER['REQUEST_URI'].file_get_contents('php://input');
  •                 } else {
  •                         $temp = '';
  •                 if(!empty($temp)) {
  •                         $temp = strtoupper(urldecode(urldecode($temp)));
  •                         foreach ($check as $str) {
  •                                 if(strpos($temp, $str) !== false) {
  •                 return true;
替换为:
  •                 $temp = strtoupper(urldecode(urldecode($_SERVER['REQUEST_URI'])));
  •                 if(strpos($temp, '<') !== false || strpos($temp, '"') !== false || strpos($temp, 'CONTENT-TRANSFER-ENCODING') !== false) {
  •                 return true;
或使用官方方法解决:http://www.discuz.net/thread-3485502-1-1.html
上传覆盖同名文件,后台更新缓存,重新登录退出看看是否解决了。
GMT+8, 2026-10-23 05:07 , Processed in 0.113302 second(s), 26 queries .
