查看: 6218|回复: 1
[有问必答] 图片的这些二进制像素信息是有什么软件可以自动提取出来么
发表于 2015-4-2 13:24:15 | 显示全部楼层 |阅读模式
extern const unsigned char gImage_QQ[48 * 48];
一个QQ图标
const unsigned char gImage_QQ[4608] = { /* 0X00,0X10,0X30,0X00,0X30,0X00,0X01,0X1B, */
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,
0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDB,0XDE,0X18,0XC6,0XB6,0XB5,0X96,0XB5,
0X96,0XB5,0X96,0XB5,0XD7,0XB5,0X79,0XCE,0X9E,0XF7,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XB6,0XB5,0XF0,0X7B,0X6A,0X52,0X66,0X29,0XC4,0X18,0XA3,0X10,
0X83,0X10,0X83,0X10,0XE4,0X18,0XA7,0X31,0X0C,0X5B,0XF3,0X9C,0X5D,0XEF,0XFF,0XFF,
0X79,0XCE,0X8E,0X6B,0X09,0X42,0X26,0X29,0X06,0X21,0X06,0X21,0X05,0X21,0X26,0X21,
0X25,0X21,0X25,0X21,0X05,0X21,0XE4,0X20,0X83,0X10,0XE4,0X18,0X49,0X4A,0X75,0XAD,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X75,0XAD,
0X6B,0X4A,0XEA,0X39,0XCA,0X31,0X88,0X31,0X26,0X29,0X05,0X21,0XE5,0X20,0XE5,0X20,
0X05,0X21,0XE5,0X20,0X05,0X21,0X05,0X21,0X05,0X21,0X05,0X21,0XA3,0X10,0X25,0X21,
0X10,0X7C,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X34,0XA5,0X2A,0X42,
0X2C,0X42,0X0B,0X3A,0XA9,0X31,0X68,0X29,0X47,0X29,0X05,0X21,0XE5,0X20,0X05,0X21,
0XE5,0X20,0X05,0X21,0X05,0X21,0XE4,0X20,0X05,0X21,0X05,0X21,0X05,0X21,0XE4,0X18,
0XC3,0X18,0X6D,0X6B,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XBD,0X2A,0X42,0X2C,0X42,
0X0C,0X3A,0XCA,0X39,0XA9,0X31,0X27,0X21,0XC5,0X18,0XA4,0X18,0XE5,0X20,0XE5,0X20,
0XE5,0X20,0XE5,0X20,0XA3,0X10,0X83,0X10,0XA3,0X10,0XE4,0X20,0XE4,0X20,0X04,0X21,
0XE4,0X20,0XA3,0X18,0XEF,0X7B,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3C,0XE7,0XAB,0X52,0XA9,0X31,0X0B,0X3A,
0XCA,0X39,0XC9,0X31,0X27,0X21,0X2A,0X42,0XAF,0X73,0XE8,0X41,0XA4,0X18,0XE5,0X20,
0XE5,0X20,0XA3,0X10,0X09,0X42,0X51,0X8C,0XAB,0X52,0XA3,0X18,0XE4,0X18,0X04,0X21,
0X04,0X21,0XE4,0X20,0XE4,0X20,0X34,0XA5,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X72,0X8C,0X47,0X29,0XCA,0X31,0XA9,0X31,
0XA9,0X31,0X27,0X21,0X6B,0X4A,0X1C,0XE7,0XFF,0XFF,0XDF,0XF7,0X6A,0X4A,0XA3,0X18,
0XA4,0X18,0XC8,0X39,0X5D,0XEF,0XFF,0XFF,0XBE,0XF7,0XCB,0X5A,0X83,0X10,0X04,0X21,
0X04,0X21,0X04,0X21,0XA3,0X18,0X08,0X42,0XFB,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFB,0XDE,0X6A,0X4A,0X26,0X21,0X88,0X31,0X88,0X31,
0X67,0X29,0X06,0X21,0X14,0XA5,0XFF,0XFF,0XDB,0XDE,0XD7,0XBD,0X55,0XAD,0XC4,0X18,
0X63,0X10,0XF3,0X9C,0X3C,0XE7,0X18,0XC6,0XFF,0XFF,0XB6,0XB5,0XC4,0X18,0XC4,0X18,
0X04,0X21,0XE4,0X20,0X25,0X21,0XA3,0X10,0X92,0X94,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X55,0XAD,0XE5,0X18,0X47,0X29,0X47,0X29,0X47,0X29,
0X06,0X21,0X46,0X29,0X59,0XCE,0XFF,0XFF,0X10,0X84,0XEB,0X62,0X55,0XAD,0X66,0X29,
0XE4,0X18,0X96,0XB5,0XCE,0X7B,0XEB,0X62,0XBA,0XD6,0X5D,0XE7,0X66,0X29,0XA3,0X18,
0X04,0X21,0XE4,0X20,0X04,0X21,0XE4,0X20,0X8A,0X4A,0X3C,0XE7,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XCF,0X7B,0X83,0X10,0X26,0X21,0X05,0X21,0X06,0X21,
0XC5,0X18,0X26,0X29,0X9A,0XD6,0XFF,0XFF,0X4C,0X6B,0XA6,0X39,0X71,0X94,0XA7,0X31,
0X05,0X21,0XD2,0X9C,0X34,0XAD,0X14,0XA5,0X34,0XAD,0XBE,0XF7,0X66,0X31,0XA3,0X18,
0X04,0X21,0X04,0X21,0XE4,0X20,0X25,0X29,0X25,0X21,0X18,0XC6,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X3C,0XE7,0XAB,0X52,0XC4,0X18,0X05,0X21,0XE5,0X20,0X05,0X21,
0XC4,0X18,0XE4,0X18,0X96,0XB5,0XFF,0XFF,0XD7,0XBD,0X0C,0X6B,0XB6,0XB5,0X66,0X31,
0X63,0X10,0XD3,0X9C,0XFF,0XFF,0X5D,0XEF,0X7D,0XF7,0X39,0XC6,0X04,0X21,0XC4,0X18,
0X04,0X21,0XE4,0X20,0XE4,0X20,0X04,0X21,0XE4,0X18,0XF3,0X9C,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XDB,0XDE,0XE8,0X39,0XC5,0X18,0X05,0X21,0XE5,0X20,0X05,0X21,
0X05,0X21,0X83,0X10,0X2D,0X6B,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X92,0X94,0X83,0X10,
0X63,0X10,0XAB,0X52,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XAF,0X73,0X82,0X10,0XE4,0X20,
0X04,0X21,0XE4,0X20,0X04,0X21,0X04,0X21,0X05,0X21,0X31,0X84,0XDF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XDB,0XD6,0X87,0X31,0XE5,0X20,0X05,0X21,0X05,0X21,0XE5,0X20,
0X05,0X21,0XE4,0X20,0XA4,0X18,0XF0,0X7B,0XBC,0XCE,0XD4,0X94,0XC5,0X18,0X84,0X10,
0XA5,0X18,0X63,0X08,0X0D,0X5B,0X19,0XBE,0XD0,0X73,0XA4,0X10,0XC4,0X18,0X04,0X21,
0X04,0X21,0XE4,0X20,0X04,0X21,0X04,0X21,0X25,0X21,0XCF,0X7B,0XBE,0XF7,0XFF,0XFF,
0XFF,0XFF,0XDF,0XFF,0XD3,0XBC,0XA3,0X20,0X05,0X21,0XE5,0X20,0XE5,0X20,0X05,0X21,
0XE5,0X18,0XA5,0X10,0XA5,0X10,0XC3,0X20,0XC3,0X49,0X62,0X62,0X63,0X83,0X24,0X9C,
0X04,0X9C,0XC3,0X9B,0XE1,0X82,0X21,0X6A,0X62,0X41,0X24,0X29,0XC5,0X18,0XA4,0X10,
0XE4,0X18,0X04,0X21,0XE4,0X20,0X04,0X21,0X67,0X19,0X66,0X59,0XBA,0XEE,0XFF,0XFF,
0XFF,0XFF,0X1C,0XF7,0XE2,0X98,0X81,0X48,0XE5,0X10,0X05,0X29,0XE5,0X20,0XC5,0X18,
0XC5,0X18,0XC4,0X51,0X42,0X9B,0XE2,0XD4,0X24,0XFE,0X26,0XFF,0XA7,0XFF,0XA7,0XFF,
0X66,0XFF,0XE4,0XFE,0X63,0XFE,0XA1,0XFD,0X00,0XFD,0X60,0XDC,0X42,0X9B,0XE3,0X51,
0XC4,0X18,0XC4,0X10,0XE4,0X20,0X25,0X21,0X25,0X19,0X60,0X70,0X6C,0XBB,0XFF,0XFF,
0XFF,0XFF,0X96,0XD5,0XC1,0XA0,0XA5,0XB1,0X82,0X20,0XE5,0X10,0XE5,0X20,0X64,0X39,
0X62,0XA3,0XC0,0XF4,0XA0,0XFD,0X85,0XFE,0X6A,0XFF,0X8B,0XFF,0XAB,0XFF,0XAB,0XFF,
0X6A,0XFF,0XE8,0XFE,0X45,0XFE,0X82,0XFD,0XE0,0XFC,0XE0,0XFC,0X40,0XFD,0XC0,0XFC,
0X61,0XA3,0X44,0X39,0XE5,0X18,0XE4,0X10,0X81,0X58,0XA5,0XC1,0X64,0XA1,0X3C,0XF7,
0XDF,0XFF,0X6D,0XB3,0X23,0XA1,0XC4,0XE1,0XE1,0XA0,0XA3,0X18,0X85,0X00,0X24,0X62,
0X40,0XFD,0XE0,0XFC,0X81,0XE4,0X23,0XFE,0X86,0XFE,0XC7,0XFE,0X07,0XFF,0X07,0XFF,
0XC6,0XFE,0X65,0XFE,0XC3,0XFD,0X21,0XFD,0XC0,0XFC,0X20,0XFD,0X40,0XDC,0XE0,0XFC,
0X20,0XFD,0XC4,0X49,0X84,0X00,0XC1,0X70,0X60,0XB0,0XA4,0XC9,0X43,0XA9,0X9A,0XE6,
0XBF,0XFF,0X6D,0XC3,0X84,0XB9,0XC0,0XB8,0X41,0XE9,0XE5,0XB1,0XE3,0X28,0X83,0X00,
0X23,0X5A,0XC1,0XB3,0XA2,0X82,0X82,0XA3,0XC1,0XFD,0X21,0XFE,0X22,0XFE,0X22,0XFE,
0XE2,0XFD,0XA1,0XFD,0X60,0XFD,0X40,0XFD,0X00,0XFD,0X61,0XA3,0XC2,0X82,0X82,0XAB,
0X83,0X39,0X62,0X08,0X42,0X89,0XA3,0XD9,0X80,0XB8,0X42,0XD1,0X27,0XBA,0X7D,0XF7,
0XFF,0XFF,0X71,0XC4,0X63,0XC9,0X60,0XB8,0X42,0XD1,0X25,0XF2,0XA3,0XD1,0X24,0X69,
0X84,0X08,0XC4,0X08,0XE4,0X18,0XC5,0X18,0X23,0X5A,0XE2,0XAB,0X01,0XE5,0X81,0XFD,
0X61,0XFD,0X21,0XF5,0X61,0XDC,0X62,0XA3,0X03,0X5A,0XC4,0X10,0XE4,0X10,0XA3,0X10,
0XC3,0X40,0X00,0XB9,0X61,0XF1,0XC5,0XD1,0XE1,0XC8,0XC0,0XD0,0XC6,0X89,0X1C,0XE7,
0X7A,0XCE,0X87,0X39,0XA1,0X98,0XA0,0XD0,0X84,0XC9,0XA3,0XD9,0XE0,0XE0,0XC2,0XF1,
0X87,0XD2,0X65,0X71,0X24,0X39,0XC4,0X18,0X84,0X00,0XA4,0X08,0XE3,0X18,0X63,0X31,
0X83,0X39,0X43,0X29,0XC3,0X10,0X84,0X00,0X83,0X08,0XC3,0X28,0X02,0X69,0X62,0XB9,
0X65,0XFA,0X40,0XF9,0XC0,0XD8,0XE4,0XD9,0X62,0XE1,0X60,0XA8,0XE4,0X30,0XED,0X5A,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,
0X4A,0X4A,0X06,0X19,0X83,0X30,0XA0,0XA8,0XE4,0XE1,0X62,0XD9,0XC0,0XD8,0X82,0XE1,
0X04,0XF2,0X40,0XF9,0XE4,0XF1,0X87,0XD2,0XE5,0XA9,0X84,0X89,0X85,0X69,0X45,0X61,
0X03,0X61,0X44,0X69,0X85,0X79,0X62,0X99,0XC3,0XC9,0X85,0XF2,0XA1,0XF9,0X40,0XF9,
0X24,0XFA,0X62,0XE1,0XC0,0XD8,0XC3,0XE9,0X63,0XC1,0X82,0X40,0X05,0X19,0X26,0X29,
0XD3,0X9C,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF0,0X7B,
0X87,0X31,0X06,0X21,0XE5,0X10,0XC4,0X30,0X43,0XA1,0XC0,0XD0,0XA0,0XD8,0XE4,0XE9,
0XC3,0XE9,0XE0,0XE8,0X41,0XF1,0X24,0XFA,0X81,0XF9,0X60,0XF9,0X85,0XFA,0X23,0XFA,
0X80,0XF9,0X03,0XFA,0X85,0XFA,0X60,0XF9,0X60,0XF9,0X44,0XFA,0X81,0XF9,0X20,0XF1,
0X04,0XF2,0XC3,0XF1,0X80,0XD8,0XE1,0XB0,0X05,0X49,0XE5,0X10,0XE5,0X20,0X26,0X21,
0X09,0X42,0X3C,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X59,0XCE,0X0A,0X42,
0X46,0X29,0XE5,0X20,0XC4,0X18,0XE5,0X18,0X8F,0X7B,0XAA,0XAA,0XA1,0XB8,0X05,0XE2,
0X82,0XE9,0X00,0XE9,0X81,0XF1,0X24,0XF2,0X40,0XF1,0X00,0XF9,0X04,0XFA,0XA1,0XF9,
0X00,0XF9,0X81,0XF9,0X24,0XFA,0X40,0XF9,0X40,0XF9,0X65,0XFA,0XC2,0XF9,0X20,0XF9,
0X61,0XF1,0X42,0XD1,0XA6,0XB1,0XF0,0X93,0X88,0X29,0X83,0X18,0XE5,0X20,0XE5,0X20,
0XA7,0X31,0X31,0X84,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X8F,0X73,0X88,0X31,
0XE5,0X20,0X05,0X21,0X84,0X10,0X87,0X31,0XDB,0XD6,0X7E,0XE7,0XC6,0X91,0XA1,0XA0,
0XE1,0XB8,0XC0,0XD8,0XA2,0XE9,0X44,0XFA,0X40,0XF9,0X60,0XF9,0X85,0XFA,0XE3,0XF9,
0X60,0XF9,0XC2,0XF9,0X85,0XFA,0X80,0XF9,0X20,0XF9,0X03,0XFA,0X40,0XF1,0X80,0XD0,
0X84,0XB1,0XCE,0XAB,0X5A,0XC6,0X7F,0XDF,0XCC,0X5A,0X63,0X10,0XE5,0X20,0XC4,0X20,
0X05,0X21,0XAB,0X52,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDB,0XDE,0X6A,0X4A,0X06,0X21,
0XE5,0X20,0X05,0X21,0X83,0X10,0X4A,0X4A,0X5D,0XEF,0XDF,0XFF,0X07,0XC2,0X40,0XA8,
0X80,0XA0,0X60,0X90,0XC1,0XA8,0X22,0XC1,0XA0,0XD0,0X60,0XE0,0X61,0XE9,0X00,0XF1,
0X80,0XF0,0XE0,0XE8,0X82,0XE9,0XA0,0XD8,0XA0,0XD0,0XA4,0XC1,0X89,0XB2,0X10,0XB4,
0X59,0XCE,0X9E,0XE7,0X9E,0XE7,0X7E,0XE7,0X8F,0X6B,0X83,0X10,0XC4,0X18,0XE4,0X18,
0XE5,0X20,0XE8,0X39,0X96,0XB5,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X15,0XA5,0X87,0X31,0X06,0X21,
0XE5,0X20,0X05,0X21,0X83,0X10,0XCC,0X5A,0XDF,0XF7,0XBA,0XF6,0XA6,0XD1,0XA4,0XE9,
0X26,0XEA,0X64,0XB1,0X23,0XB9,0X64,0XB1,0X6D,0XAB,0X8D,0XB3,0XCA,0XB2,0X68,0XB2,
0X68,0XBA,0XCA,0XBA,0X4C,0XBB,0XCF,0XBB,0XD3,0XBC,0XF8,0XCD,0X3D,0XDF,0XFF,0XF7,
0XFF,0XFF,0XBF,0XF7,0X3D,0XDF,0X7F,0XE7,0X11,0X7C,0X83,0X10,0XC4,0X18,0XC4,0X18,
0XE4,0X20,0X05,0X21,0X72,0X8C,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X52,0X8C,0XE5,0X20,0X06,0X21,
0X05,0X21,0X06,0X21,0X63,0X10,0XAC,0X5A,0XDF,0XF7,0XF7,0XE5,0XC3,0XC8,0X01,0XF1,
0XA2,0XF9,0X63,0XE1,0XC3,0XF9,0XA8,0XEA,0X79,0XDE,0XDF,0XEF,0X5D,0XE7,0X5D,0XE7,
0X5D,0XE7,0X7D,0XE7,0X9E,0XEF,0XDF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XDF,0XFF,0X9E,0XEF,0X3D,0XDF,0X7F,0XDF,0X11,0X7C,0X83,0X10,0XC4,0X18,0XC4,0X18,
0XE4,0X20,0X83,0X10,0XF0,0X7B,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XF0,0X83,0XA4,0X18,0X06,0X21,
0XE5,0X20,0XE5,0X20,0X83,0X10,0X2A,0X4A,0XBF,0XE7,0XB6,0XDD,0X24,0XD1,0X83,0XF1,
0XE4,0XF9,0XA3,0XF1,0X61,0XF9,0X05,0XF2,0X38,0XE6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XDF,0XF7,0X7E,0XEF,0X1D,0XDF,0X5E,0XDF,0XAF,0X6B,0X83,0X10,0XC4,0X18,0XC4,0X18,
0XE4,0X20,0X62,0X08,0XCF,0X7B,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XF0,0X83,0X84,0X10,0X06,0X21,
0X06,0X21,0X09,0X42,0X83,0X10,0X87,0X31,0XFC,0XCE,0XB6,0XDD,0X61,0XD0,0X00,0XF1,
0XA2,0XF9,0XE3,0XF9,0XE3,0XF9,0X46,0XEA,0X58,0XE6,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,
0X9E,0XF7,0X5D,0XE7,0X1D,0XD7,0XFD,0XD6,0XCC,0X52,0X62,0X10,0X0D,0X63,0X04,0X21,
0XC4,0X18,0X62,0X10,0XF0,0X7B,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0X52,0X8C,0XC4,0X18,0XA4,0X18,
0X8F,0X73,0X59,0XCE,0XC5,0X18,0XC5,0X20,0X77,0XA5,0X3D,0XE7,0X48,0XCA,0X62,0XF1,
0XC3,0XF9,0XA2,0XF9,0X00,0XF9,0XC4,0XE9,0X9A,0XE6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XF7,
0X7E,0XEF,0X1D,0XDF,0X3E,0XDF,0X3A,0XBE,0XA7,0X31,0X25,0X29,0X3D,0XEF,0X8E,0X73,
0X42,0X08,0XA3,0X18,0XB3,0X9C,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XB7,0XB5,0X47,0X29,0X8B,0X52,
0X7D,0XEF,0XBF,0XF7,0X2E,0X6B,0X02,0X08,0X4E,0X6B,0XBF,0XE7,0XF8,0XCD,0XEA,0XCA,
0X26,0XE2,0X66,0XEA,0X67,0XEA,0X2F,0XDC,0X7E,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XF7,0X9E,0XEF,
0X3D,0XDF,0XFC,0XD6,0X5F,0XDF,0XD4,0X94,0X42,0X08,0X31,0X84,0XFF,0XFF,0X5D,0XEF,
0X49,0X4A,0XA7,0X39,0X9A,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,0XF7,0XB7,0XB5,0X5D,0XEF,
0XFF,0XFF,0XFF,0XFF,0X59,0XCE,0XE5,0X20,0X05,0X21,0XD8,0XB5,0XDF,0XEF,0X3D,0XD7,
0X59,0XD6,0X18,0XDE,0X99,0XE6,0X9E,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XF7,0X9E,0XEF,0X5E,0XE7,
0XFD,0XD6,0X1D,0XD7,0XDC,0XCE,0XE8,0X39,0X45,0X29,0X1B,0XE7,0XFF,0XFF,0XFF,0XFF,
0X3C,0XE7,0XF7,0XBD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0X35,0X9D,0X64,0X08,0X8B,0X4A,0XFD,0XD6,0X7E,0XE7,
0XBF,0XEF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XBF,0XF7,0X7E,0XEF,0X5E,0XE7,0XFD,0XD6,
0XFD,0XD6,0X7F,0XE7,0XF0,0X73,0XA4,0X10,0XD7,0XB5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X9E,0XFF,0X90,0XE5,0X65,0X72,0X23,0X00,0X8F,0X6B,0X5E,0XDF,
0X3D,0XDF,0X3D,0XE7,0X5E,0XEF,0X9E,0XEF,0XBF,0XF7,0XDF,0XF7,0XDF,0XF7,0XDF,0XFF,
0XDF,0XF7,0XBF,0XF7,0XBE,0XF7,0X9E,0XEF,0X5E,0XE7,0X3D,0XDF,0XFD,0XD6,0XFD,0XD6,
0XBF,0XEF,0XF5,0X94,0X63,0X08,0XA4,0X82,0X8F,0XED,0X5D,0XF7,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0X5D,0XF7,0XC9,0XDC,0XE0,0XFD,0X21,0XF6,0X84,0X72,0X24,0X00,0X70,0X6B,
0X3E,0XDF,0X5E,0XDF,0X3D,0XDF,0X3D,0XE7,0X5E,0XE7,0X7E,0XE7,0X7E,0XEF,0X7E,0XEF,
0X7E,0XEF,0X7E,0XE7,0X5E,0XE7,0X3D,0XDF,0X1D,0XD7,0XFD,0XD6,0X3D,0XDF,0XBF,0XEF,
0XD5,0X8C,0XA4,0X10,0X40,0X82,0X60,0XFD,0XE0,0XFD,0XA7,0XDC,0X1B,0XF7,0XFF,0XFF,
0XFF,0XFF,0X93,0XDD,0XE0,0XE3,0XC9,0XFE,0X6E,0XFF,0XC9,0XFE,0X63,0X9B,0X63,0X18,
0X6C,0X42,0X1A,0XB6,0X5E,0XDF,0X3E,0XDF,0X3D,0XDF,0X3D,0XDF,0X1D,0XDF,0X1D,0XDF,
0X1D,0XDF,0X1D,0XD7,0X1D,0XD7,0X1D,0XD7,0X3D,0XDF,0X7F,0XE7,0XFD,0XCE,0X90,0X63,
0XC2,0X28,0X00,0XA3,0XA4,0XFD,0XC5,0XFE,0X81,0XFE,0X00,0XE4,0X10,0XD5,0XFF,0XFF,
0XBF,0XFF,0X4A,0XCC,0X87,0XF5,0X51,0XFF,0XEB,0XFE,0XC4,0XFE,0X80,0XFE,0X81,0XD4,
0XA2,0X59,0X26,0X29,0XB1,0X6B,0XDA,0XAD,0XBD,0XC6,0X1E,0XCF,0X3E,0XD7,0X5E,0XDF,
0X5E,0XDF,0X5E,0XDF,0X3E,0XD7,0X1E,0XD7,0X7C,0XBE,0X94,0X84,0XE8,0X41,0XA0,0X69,
0X00,0XDC,0XA0,0XFD,0XA5,0XFE,0X2C,0XFF,0X0C,0XFF,0X43,0XF5,0XA7,0XC3,0XBE,0XF7,
0XBE,0XF7,0X09,0XC4,0X63,0XFD,0X84,0XFE,0X41,0XFE,0X40,0XFE,0X40,0XFE,0X40,0XFE,
0X60,0XFD,0XA0,0XC3,0X01,0X72,0XC5,0X51,0XEB,0X62,0X31,0X84,0XD4,0X94,0X36,0X9D,
0X56,0XA5,0XF5,0X9C,0X72,0X94,0X6D,0X73,0X46,0X62,0X00,0X7A,0X60,0XCB,0XE0,0XFC,
0XA0,0XFD,0X20,0XFE,0X20,0XFE,0X43,0XFE,0X87,0XFE,0X83,0XFD,0X46,0XBB,0X9E,0XF7,
0XFF,0XFF,0X13,0XB5,0X21,0XCB,0XE0,0XFC,0XC0,0XFD,0X01,0XFE,0X01,0XFE,0XC1,0XFD,
0XC1,0XFD,0X61,0XFD,0XC0,0XFC,0X20,0XFC,0XE0,0XD2,0X60,0X81,0X44,0X41,0X08,0X42,
0X08,0X42,0X65,0X41,0X60,0X79,0XC0,0XD2,0XE0,0XFB,0X60,0XFC,0X01,0XFD,0X61,0XFD,
0X81,0XFD,0XC1,0XFD,0XC1,0XFD,0XA0,0XFD,0XE0,0XFC,0X40,0XD3,0XB0,0XB4,0XDF,0XFF,
0XFF,0XFF,0XBB,0XD6,0XCE,0X8B,0XE5,0XA2,0X42,0XC3,0XA0,0XDB,0X00,0XEC,0X20,0XF4,
0X20,0XF4,0XC0,0XEB,0XE0,0XD2,0XC1,0XC2,0XC4,0XAA,0XC8,0X82,0XAE,0X7B,0X10,0X84,
0X10,0X84,0XCE,0X7B,0XE9,0X82,0XA4,0XA2,0XA1,0XC2,0XC0,0XD2,0X80,0XEB,0XE0,0XF3,
0X00,0XF4,0XE0,0XEB,0XA0,0XDB,0X42,0XCB,0XE5,0XAA,0XAD,0X93,0XBA,0XD6,0XFF,0XFF,
0XFF,0XFF,0XBE,0XF7,0X9A,0XCE,0XF4,0X9C,0XAE,0X8B,0X2A,0X8B,0XE8,0X8A,0XC7,0X8A,
0XA7,0X8A,0XA8,0X8A,0X0A,0X8B,0XAE,0X8B,0XB3,0X94,0XB7,0XAD,0X38,0XC6,0X59,0XCE,
0X59,0XCE,0X38,0XC6,0XD7,0XB5,0XD4,0X94,0XCE,0X8B,0X2A,0X8B,0XA8,0X8A,0XA7,0X8A,
0XC7,0X8A,0XE8,0X8A,0X2A,0X8B,0XAE,0X8B,0XD4,0X9C,0X9A,0XCE,0XBE,0XF7,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0X9E,0XF7,0X1C,0XDF,0X7A,0XC6,0X18,0XBE,0XF8,0XB5,
0XF8,0XBD,0X59,0XC6,0XDB,0XD6,0X7D,0XEF,0XDF,0XFF,0XDE,0XFF,0XDF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0X9E,0XEF,0XFC,0XD6,0X59,0XC6,0XF8,0XBD,
0XF8,0XB5,0X18,0XBE,0X7A,0XC6,0X1C,0XDF,0XBE,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,
发表于 2015-4-2 17:04:18 | 显示全部楼层
GMT+8, 2026-11-22 14:21 , Processed in 1.238864 second(s), 24 queries .
