查看: 3498|回复: 3
单ADC多通道采样问题
发表于 2017-12-8 16:07:19 | 显示全部楼层 |阅读模式
最近想做一个ADC电压采样,用来判断多块锂电池的电量,现在有个问题,初始化ADC后,get到的值都是一样的,麻烦大神给看下咋回事
void MY_ADC_Init(void)
    ADC1_Handler.Instance=ADC1;
    ADC1_Handler.Init.ClockPrescaler=ADC_CLOCK_SYNC_PCLK_DIV4;   //4·ÖÆμ£¬ADCCLK=PCLK2/4=108/4=27MHZ
    ADC1_Handler.Init.Resolution=ADC_RESOLUTION_12B;             //12λÄ£ê½
    ADC1_Handler.Init.DataAlign=ADC_DATAALIGN_RIGHT;             //óò¶ÔÆë
    ADC1_Handler.Init.ScanConvMode=DISABLE;                      //·Çé¨ÃèÄ£ê½
    ADC1_Handler.Init.EOCSelection=DISABLE;                      //1رÕEOCÖD¶Ï
    ADC1_Handler.Init.ContinuousConvMode=DISABLE;                //1رÕá¬Dø×a»»
    ADC1_Handler.Init.NbrOfConversion=2;                         //1¸ö×a»»Ôú1æÔòDòáDÖD ò2¾íêÇÖ»×a»»1æÔòDòáD1
    ADC1_Handler.Init.DiscontinuousConvMode=DISABLE;             //½ûÖ12»á¬Dø2éÑùÄ£ê½
    ADC1_Handler.Init.NbrOfDiscConversion=0;                     //2»á¬Dø2éÑùí¨μàêyÎa0
    ADC1_Handler.Init.ExternalTrigConv=ADC_SOFTWARE_START;       //èí¼t′¥·¢
    ADC1_Handler.Init.ExternalTrigConvEdge=ADC_EXTERNALTRIGCONVEDGE_NONE;//ê1óÃèí¼t′¥·¢
    ADC1_Handler.Init.DMAContinuousRequests=DISABLE;             //1رÕDMAÇëÇó
    HAL_ADC_Init(&ADC1_Handler);                                 //3õê¼»ˉ
//ADCμ×2ãÇy¶ˉ£¬òy½ÅÅäÖã¬ê±Öóê1Äü
//′Ëoˉêy»á±»HAL_ADC_Init()μ÷óÃ
//hadc:ADC¾ä±ú
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
    GPIO_InitTypeDef GPIO_Initure;
    __HAL_RCC_ADC1_CLK_ENABLE();            //ê1ÄüADC1ê±Öó
    __HAL_RCC_GPIOA_CLK_ENABLE();            //¿aÆôGPIOAê±Öó
    GPIO_Initure.Pin=GPIO_PIN_5;            //PA5
    GPIO_Initure.Mode=GPIO_MODE_ANALOG;     //Ä£Äa
    GPIO_Initure.Pull=GPIO_NOPULL;          //2»′øéÏÏÂà-
    HAL_GPIO_Init(GPIOA,&GPIO_Initure);
    GPIO_Initure.Pin=GPIO_PIN_4;
//»ñμÃADCÖμ
//ch: í¨μàÖμ 0~16£¬è¡Öμ·¶Î§Îa£oADC_CHANNEL_0~ADC_CHANNEL_16
//·μ»ØÖμ:×a»»½á1û
u16 Get_Adc1(u32 ch,u32 rank)
    ADC_ChannelConfTypeDef ADC1_ChanConf;
    ADC1_ChanConf.Channel=ch;                                   //í¨μà
    ADC1_ChanConf.Rank=rank;                                     //1¸öDòáD
    ADC1_ChanConf.SamplingTime=ADC_SAMPLETIME_480CYCLES;        //2éÑùê±¼ä
    ADC1_ChanConf.Offset=0;
    HAL_ADC_ConfigChannel(&ADC1_Handler,&ADC1_ChanConf);        //í¨μàÅäÖÃ
    HAL_ADC_Start(&ADC1_Handler);                               //¿aÆôADC
    HAL_ADC_PollForConversion(&ADC1_Handler,10);                //ÂÖÑˉ×a»»
    return (u16)HAL_ADC_GetValue(&ADC1_Handler);                //·μ»Ø×î½üò»′ÎADC11æÔò×éμÄ×a»»½á1û
//»ñè¡Ö¸¶¨í¨μàμÄ×a»»Ö죬è¡times′Î,è»o󯽾ù
//times:»ñè¡′Îêy
//·μ»ØÖμ:í¨μàchμÄtimes′Î×a»»½á1ûƽ¾ùÖμ
u16 Get_Adc1_Average(u32 ch,u8 times,u32 rank)
    u32 temp_val=0;
    u8 t;
    for(t=0;t<times;t++)
        temp_val+=Get_Adc1(ch,rank);
    return temp_val/times;
 楼主| 发表于 2017-12-8 16:08:21 | 显示全部楼层
没发现这样配置ADC有问题,但是就是不能工作
发表于 2017-12-9 01:18:25 | 显示全部楼层
HAL库不清楚,标准库我们有例子,论坛V5板子置顶帖。另外多通道采集,务必把DMA弄上,否则时序没法及时处理。
发表于 2017-12-15 10:33:46 | 显示全部楼层
有可能是通道间的采样时间不够
GMT+8, 2026-11-25 11:31 , Processed in 0.434269 second(s), 24 queries .
