查看: 4259|回复: 0
[CMSIS-RTOS] 据CMSIS手册说明,它包含的所有的资料都是免费的,含CMSIS-RTOS V1和V2,遵循Apach
发表于 2017-11-19 02:32:56 | 显示全部楼层 |阅读模式
手册中关于license的授权说明如下:
“The CMSIS is provided free of charge by ARM under Apache 2.0 license. View the Apache 2.0 License.”
而且CMISI-RTOS V1里面的说明也比较明确了:
This RTX implementation is available under the Apache-2.0 license and can be freely distributed with project templates.
而Apache 2.0授权的项目比较宽松,可以是盈利,非盈利,开源,闭源的任何方式。现在的CMSIS-RTOS V1和CMSIS-RTOS V2都已经集中放在CMSIS文件夹里面,所以这两个RTOS已经是免费的了,无需花钱购买。
RTOS文件夹里面是RTX4及其CMSIS-RTOS V1封装层。
RTOS2文件夹里面是RTX5及其CMSIS-RTOS V2封装层。
而这两个RTOS之间是什么关系呢,就跟uCOS-II和uCOS-III一样,已经没有任何关系。
======================补充知识点=========================
关于各种license的授权,知乎上面一篇帖子讲解的不错:https://www.zhihu.com/question/19962512
完整的Apache 2.0说明如下:
  1. Apache License
  2.                            Version 2.0, January 2004
  3.                         http://www.apache.org/licenses/
  4.    TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
  5.    1. Definitions.
  6.       "License" shall mean the terms and conditions for use, reproduction,
  7.       and distribution as defined by Sections 1 through 9 of this document.
  8.       "Licensor" shall mean the copyright owner or entity authorized by
  9.       the copyright owner that is granting the License.
  10.       "Legal Entity" shall mean the union of the acting entity and all
  11.       other entities that control, are controlled by, or are under common
  12.       control with that entity. For the purposes of this definition,
  13.       "control" means (i) the power, direct or indirect, to cause the
  14.       direction or management of such entity, whether by contract or
  15.       otherwise, or (ii) ownership of fifty percent (50%) or more of the
  16.       outstanding shares, or (iii) beneficial ownership of such entity.
  17.       "You" (or "Your") shall mean an individual or Legal Entity
  18.       exercising permissions granted by this License.
  19.       "Source" form shall mean the preferred form for making modifications,
  20.       including but not limited to software source code, documentation
  21.       source, and configuration files.
  22.       "Object" form shall mean any form resulting from mechanical
  23.       transformation or translation of a Source form, including but
  24.       not limited to compiled object code, generated documentation,
  25.       and conversions to other media types.
  26.       "Work" shall mean the work of authorship, whether in Source or
  27.       Object form, made available under the License, as indicated by a
  28.       copyright notice that is included in or attached to the work
  29.       (an example is provided in the Appendix below).
  30.       "Derivative Works" shall mean any work, whether in Source or Object
  31.       form, that is based on (or derived from) the Work and for which the
  32.       editorial revisions, annotations, elaborations, or other modifications
  33.       represent, as a whole, an original work of authorship. For the purposes
  34.       of this License, Derivative Works shall not include works that remain
  35.       separable from, or merely link (or bind by name) to the interfaces of,
  36.       the Work and Derivative Works thereof.
  37.       "Contribution" shall mean any work of authorship, including
  38.       the original version of the Work and any modifications or additions
  39.       to that Work or Derivative Works thereof, that is intentionally
  40.       submitted to Licensor for inclusion in the Work by the copyright owner
  41.       or by an individual or Legal Entity authorized to submit on behalf of
  42.       the copyright owner. For the purposes of this definition, "submitted"
  43.       means any form of electronic, verbal, or written communication sent
  44.       to the Licensor or its representatives, including but not limited to
  45.       communication on electronic mailing lists, source code control systems,
  46.       and issue tracking systems that are managed by, or on behalf of, the
  47.       Licensor for the purpose of discussing and improving the Work, but
  48.       excluding communication that is conspicuously marked or otherwise
  49.       designated in writing by the copyright owner as "Not a Contribution."
  50.       "Contributor" shall mean Licensor and any individual or Legal Entity
  51.       on behalf of whom a Contribution has been received by Licensor and
  52.       subsequently incorporated within the Work.
  53.    2. Grant of Copyright License. Subject to the terms and conditions of
  54.       this License, each Contributor hereby grants to You a perpetual,
  55.       worldwide, non-exclusive, no-charge, royalty-free, irrevocable
  56.       copyright license to reproduce, prepare Derivative Works of,
  57.       publicly display, publicly perform, sublicense, and distribute the
  58.       Work and such Derivative Works in Source or Object form.
  59.    3. Grant of Patent License. Subject to the terms and conditions of
  60.       this License, each Contributor hereby grants to You a perpetual,
  61.       worldwide, non-exclusive, no-charge, royalty-free, irrevocable
  62.       (except as stated in this section) patent license to make, have made,
  63.       use, offer to sell, sell, import, and otherwise transfer the Work,
  64.       where such license applies only to those patent claims licensable
  65.       by such Contributor that are necessarily infringed by their
  66.       Contribution(s) alone or by combination of their Contribution(s)
  67.       with the Work to which such Contribution(s) was submitted. If You
  68.       institute patent litigation against any entity (including a
  69.       cross-claim or counterclaim in a lawsuit) alleging that the Work
  70.       or a Contribution incorporated within the Work constitutes direct
  71.       or contributory patent infringement, then any patent licenses
  72.       granted to You under this License for that Work shall terminate
  73.       as of the date such litigation is filed.
  74.    4. Redistribution. You may reproduce and distribute copies of the
  75.       Work or Derivative Works thereof in any medium, with or without
  76.       modifications, and in Source or Object form, provided that You
  77.       meet the following conditions:
  78.       (a) You must give any other recipients of the Work or
  79.           Derivative Works a copy of this License; and
  80.       (b) You must cause any modified files to carry prominent notices
  81.           stating that You changed the files; and
  82.       (c) You must retain, in the Source form of any Derivative Works
  83.           that You distribute, all copyright, patent, trademark, and
  84.           attribution notices from the Source form of the Work,
  85.           excluding those notices that do not pertain to any part of
  86.           the Derivative Works; and
  87.       (d) If the Work includes a "NOTICE" text file as part of its
  88.           distribution, then any Derivative Works that You distribute must
  89.           include a readable copy of the attribution notices contained
  90.           within such NOTICE file, excluding those notices that do not
  91.           pertain to any part of the Derivative Works, in at least one
  92.           of the following places: within a NOTICE text file distributed
  93.           as part of the Derivative Works; within the Source form or
  94.           documentation, if provided along with the Derivative Works; or,
  95.           within a display generated by the Derivative Works, if and
  96.           wherever such third-party notices normally appear. The contents
  97.           of the NOTICE file are for informational purposes only and
  98.           do not modify the License. You may add Your own attribution
  99.           notices within Derivative Works that You distribute, alongside
  100.           or as an addendum to the NOTICE text from the Work, provided
  101.           that such additional attribution notices cannot be construed
  102.           as modifying the License.
  103.       You may add Your own copyright statement to Your modifications and
  104.       may provide additional or different license terms and conditions
  105.       for use, reproduction, or distribution of Your modifications, or
  106.       for any such Derivative Works as a whole, provided Your use,
  107.       reproduction, and distribution of the Work otherwise complies with
  108.       the conditions stated in this License.
  109.    5. Submission of Contributions. Unless You explicitly state otherwise,
  110.       any Contribution intentionally submitted for inclusion in the Work
  111.       by You to the Licensor shall be under the terms and conditions of
  112.       this License, without any additional terms or conditions.
  113.       Notwithstanding the above, nothing herein shall supersede or modify
  114.       the terms of any separate license agreement you may have executed
  115.       with Licensor regarding such Contributions.
  116.    6. Trademarks. This License does not grant permission to use the trade
  117.       names, trademarks, service marks, or product names of the Licensor,
  118.       except as required for reasonable and customary use in describing the
  119.       origin of the Work and reproducing the content of the NOTICE file.
  120.    7. Disclaimer of Warranty. Unless required by applicable law or
  121.       agreed to in writing, Licensor provides the Work (and each
  122.       Contributor provides its Contributions) on an "AS IS" BASIS,
  123.       WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
  124.       implied, including, without limitation, any warranties or conditions
  125.       of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
  126.       PARTICULAR PURPOSE. You are solely responsible for determining the
  127.       appropriateness of using or redistributing the Work and assume any
  128.       risks associated with Your exercise of permissions under this License.
  129.    8. Limitation of Liability. In no event and under no legal theory,
  130.       whether in tort (including negligence), contract, or otherwise,
  131.       unless required by applicable law (such as deliberate and grossly
  132.       negligent acts) or agreed to in writing, shall any Contributor be
  133.       liable to You for damages, including any direct, indirect, special,
  134.       incidental, or consequential damages of any character arising as a
  135.       result of this License or out of the use or inability to use the
  136.       Work (including but not limited to damages for loss of goodwill,
  137.       work stoppage, computer failure or malfunction, or any and all
  138.       other commercial damages or losses), even if such Contributor
  139.       has been advised of the possibility of such damages.
  140.    9. Accepting Warranty or Additional Liability. While redistributing
  141.       the Work or Derivative Works thereof, You may choose to offer,
  142.       and charge a fee for, acceptance of support, warranty, indemnity,
  143.       or other liability obligations and/or rights consistent with this
  144.       License. However, in accepting such obligations, You may act only
  145.       on Your own behalf and on Your sole responsibility, not on behalf
  146.       of any other Contributor, and only if You agree to indemnify,
  147.       defend, and hold each Contributor harmless for any liability
  148.       incurred by, or claims asserted against, such Contributor by reason
  149.       of your accepting any such warranty or additional liability.
  150.    END OF TERMS AND CONDITIONS
  151.    APPENDIX: How to apply the Apache License to your work.
  152.       To apply the Apache License to your work, attach the following
  153.       boilerplate notice, with the fields enclosed by brackets "{}"
  154.       replaced with your own identifying information. (Don't include
  155.       the brackets!)  The text should be enclosed in the appropriate
  156.       comment syntax for the file format. We also recommend that a
  157.       file or class name and description of purpose be included on the
  158.       same "printed page" as the copyright notice for easier
  159.       identification within third-party archives.
  160.    Copyright {yyyy} {name of copyright owner}
  161.    Licensed under the Apache License, Version 2.0 (the "License");
  162.    you may not use this file except in compliance with the License.
  163.    You may obtain a copy of the License at
  164.        http://www.apache.org/licenses/LICENSE-2.0
  165.    Unless required by applicable law or agreed to in writing, software
  166.    distributed under the License is distributed on an "AS IS" BASIS,
  167.    WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  168.    See the License for the specific language governing permissions and
  169.    limitations under the License.
GMT+8, 2026-11-25 11:49 , Processed in 0.794591 second(s), 27 queries .
