查看: 8668|回复: 8
[μCOS-III] 【uCOS-III教程】第10章 μCOS-III在高版本MDK开启FPU方案
春暖花开
发表于 2014-12-29 10:34:00 | 显示全部楼层 |阅读模式
特别说明:
1.  本教程是安富莱电子原创。
2.  安富莱STM32F407开发板资料已经全部开源,开源地址:地址链接
3.  当前共配套300多个实例,4套用户手册。
    由于官方提供的μCOS-III移植工程中对于浮点寄存器的入栈和出栈处理是错误的,所以网上就流传了各种修正版本。但是这些修正的代码只能在MDK4.7以下版本中可以正常的运行,MDK4.7及其以上的版本无法正常运行。本期教程为此而生。本期教程提供的方案只有任务使用了浮点寄存器(也就是做了浮点运算)才需要将其入栈,没有使用浮点寄存器的任务不需要进行入栈,认识到这点很重要。此方案在MDK4.54、4.73、5.10以及IAR6.3、6.7上面测试均通过。
    10.1 官方移植方案
    10.2 开启FPU解决方案
    10.3 开启FPU的优劣
    10.4 总结
10.1  官方移植方案
    官方提供的移植工程里面,只有IAR工程里面才有浮点寄存器的入栈和出栈处理函数,MDK工程里面是没有的。下面这个是os_cpu_c.c文件夹中的函数:
*                                       INITIALIZE A TASK'S STACK
* Description: This function is called by either OSTaskCreate() orOSTaskCreateExt() to initialize the
*              stack frame of thetask being created.  This function ishighly processor specific.
* Arguments  : task          is a pointer to the task code
*              p_arg         is a pointer to a user supplied dataarea that will be passed to the task
*                            whenthe task first executes.
*              ptos          is a pointer to the top ofstack.  It is assumed that 'ptos' pointsto
*                            a'free' entry on the task stack.  IfOS_STK_GROWTH is set to 1 then
*                            'ptos'will contain the HIGHEST valid address of the stack.  Similarly, if
*                            OS_STK_GROWTH is set to 0, the 'ptos' willcontains the LOWEST valid address
*                            of thestack.
*              opt           specifies options that can be usedto alter the behavior of OSTaskStkInit().
*                            (see uCOS_II.H for OS_TASK_OPT_xxx).
* Returns    : Always returns thelocation of the new top-of-stack once the processor registers have
*              been placed on thestack in the proper order.
* Note(s)    : (1) Interrupts areenabled when task starts executing.
*              (2) All tasks run inThread mode, using process stack.
*              (3) There are twodifferent stack frames depending on whether the Floating-Point(FP)
*                  co-processor isenabled or not.
*                  (a) The stack frame shown in thediagram is used when the FP co-processor is not present and
*                     OS_TASK_OPT_SAVE_FP is disabled. In this case, the FP registers and FPStatus Control
*                      register arenot saved in the stack frame.
*                  (b) If the FPco-processor is present but the OS_TASK_OPT_SAVE_FP is not set, then the stack
*                      frame issaved as shown in diagram (a). Moreover, if OS_TASK_OPT_SAVE_FP is set, thenthe
*                      FP registers and FP StatusControl register are saved in the stack frame.
*                      (1) Whenenabling the FP co-processor, make sure to clear bits ASPEN and LSPEN in the
*                         Floating-Point Context Control Register (FPCCR).
*                    |    xPSR   |       |    xPSR   |
*                    |Return Addr|       |Return Addr |
*                    |  LR(R14)  |       |   LR(R14) |
*                    |    R12    |       |     R12   |
*                    |    R3     |       |     R3    |
*                    |    R2     |       |     R0    |
*                    |    R1     |       |     R1    |
*                    |    R0     |       |     R0    |
*                    |    R11    |       |     R11   |
*                    |    R10    |       |     R10   |
*                    |    R9     |       |     R9    |
*                    |    R8     |       |     R8    |
*                    |    R7     |       |     R7    |
*                    |    R6     |       |     R6    |
*                    |    R5     |       |     R5    |
*                    |    R4     |       |     R4    |
*                         (a)             |  FPSCR    |
*                                        |     S31    |
*                                        |     S1     |
*                                        |     S0     |
*                                             (b)
*             (4) The SP must be 8-bytealigned in conforming to the Procedure Call Standard for the ARM architecture
*                    (a) Section 2.1of the  ABI for the ARM ArchitectureAdvisory Note. SP must be 8-byte aligned
*                        on entry toAAPCS-Conforming functions states :
*                        TheProcedure Call Standard for the ARM Architecture [AAPCS] requires primitive
*                        data typesto be naturally aligned according to their sizes (for size = 1, 2, 4, 8 bytes).
*                        Doingotherwise creates more problems than it solves.
*                        In returnfor preserving the natural alignment of data, conforming code is permitted
*                        to rely onthat alignment. To support aligning data allocated on the stack, the stack
*                        pointer(SP) is required to be 8-byte aligned on entry to a conforming function. In
*                        practicethis requirement is met if:
*                           (1) At each call site, the current size ofthe calling function抯 stack frame is a multiple of 8 bytes.
*                               Thisplaces an obligation on compilers and assembly language programmers.
*                           (2) SPis a multiple of 8 when control first enters a program.
*                               Thisplaces an obligation on authors of low level OS, RTOS, and runtime library
*                               codeto align SP at all points at which control first enters
*                               abody of (AAPCS-conforming) code.
*                       In turn,this requires the value of SP to be aligned to 0 modulo 8:
*                           (3) Byexception handlers, before calling AAPCS-conforming code.
*                           (4) ByOS/RTOS/run-time system code, before giving control to an application.
*                 (b) Section 2.3.1corrective steps from the the SP must be 8-byte aligned on entry
*                     to AAPCS-conformingfunctions advisory note also states.
*                     " Thisrequirement extends to operating systems and run-time code for all architectureversions
*                       prior toARMV7 and to the A, R and M architecture profiles thereafter. Specialconsiderations
*                       associatedwith ARMV7M are discussed in ?.3.3"
*                     (1) Even ifthe SP 8-byte aligment is not a requirement for the ARMv7M profile, the stackis aligned
*                         to 8-byte boundaries to support legacyexecution enviroments.
*                 (c) Section5.2.1.2 from the Procedure Call Standard for the ARM
*                     architecturestates :  "The stack must alsoconform to the following
*                     constraint at a public interface:
*                     (1) SP mod 8 =0. The stack must be double-word aligned"
*                 (d) From the ARMTechnical Support Knowledge Base. 8 Byte stack aligment.
*                     "8 bytestack alignment is a requirement of the ARM Architecture Procedure
*                      Call Standard[AAPCS]. This specifies that functions must maintain an 8 byte
*                      aligned stackaddress (e.g. 0x00, 0x08, 0x10, 0x18, 0x20) on all external
*                      interfaces.In practice this requirement is met if:
*                      (1) At eachexternal interface, the current stack pointer
*                          is amultiple of 8 bytes.
*                      (2) Your OS maintains8 byte stack alignment on its external interfaces
*                          e.g. ontask switches"
OS_STK *OSTaskStkInit (void (*task)(void *p_arg), void *p_arg, OS_STK*ptos, INT16U opt)
    OS_STK  *p_stk;
    p_stk      = ptos + 1u;                                     /* Loadstack pointer                                  */
                                                               /* Align the stack to 8-bytes.                          */
    p_stk      = (OS_STK *)((OS_STK)(p_stk) &0xFFFFFFF8u);
                                                               /* Registers stacked as if auto-saved on exception      */
    *(--p_stk) =(OS_STK)0x01000000uL;                         /* xPSR                                                */
    *(--p_stk) = (OS_STK)task;                                  /* EntryPoint                                          */
    *(--p_stk) =(OS_STK)OS_TaskReturn;                        /* R14 (LR)                                             */
    *(--p_stk) =(OS_STK)0x12121212uL;                         /* R12                                                  */
    *(--p_stk) =(OS_STK)0x03030303uL;                         /* R3                                                  */
    *(--p_stk) =(OS_STK)0x02020202uL;                         /* R2                                                  */
    *(--p_stk) =(OS_STK)0x01010101uL;                         /* R1                                                  */
    *(--p_stk) = (OS_STK)p_arg;                                 /* R0 :argument                                        */
                                                               /* Remaining registers saved on process stack           */
    *(--p_stk) =(OS_STK)0x11111111uL;                         /* R11                                                 */
    *(--p_stk) =(OS_STK)0x10101010uL;                         /* R10                                                 */
    *(--p_stk) =(OS_STK)0x09090909uL;                         /* R9                                                  */
    *(--p_stk) =(OS_STK)0x08080808uL;                         /* R8                                                  */
    *(--p_stk) =(OS_STK)0x07070707uL;                         /* R7                                                  */
    *(--p_stk) = (OS_STK)0x06060606uL;                          /* R6                                                  */
    *(--p_stk) =(OS_STK)0x05050505uL;                         /* R5                                                  */
    *(--p_stk) = (OS_STK)0x04040404uL;                          /* R4                                                  */
#if (OS_CPU_ARM_FP_EN > 0u)
    if ((opt &OS_TASK_OPT_SAVE_FP) != (INT16U)0) {
        *--p_stk =(OS_STK)0x02000000u;                        /* FPSCR                                                */
                                                               /* Initialize S0-S31 floating point registers           */
        *--p_stk =(OS_STK)0x41F80000u;                        /* S31                                                 */
        *--p_stk =(OS_STK)0x41F00000u;                        /* S30                                                 */
        *--p_stk =(OS_STK)0x41E80000u;                        /* S29                                                 */
        *--p_stk =(OS_STK)0x41E00000u;                        /* S28                                                 */
        *--p_stk = (OS_STK)0x41D80000u;                         /* S27                                                 */
        *--p_stk =(OS_STK)0x41D00000u;                        /* S26                                                 */
        *--p_stk = (OS_STK)0x41C80000u;                         /* S25                                                 */
        *--p_stk =(OS_STK)0x41C00000u;                        /* S24                                                 */
        *--p_stk =(OS_STK)0x41B80000u;                         /* S23                                                 */
        *--p_stk =(OS_STK)0x41B00000u;                        /* S22                                                 */
        *--p_stk =(OS_STK)0x41A80000u;                         /* S21                                                 */
        *--p_stk =(OS_STK)0x41A00000u;                        /* S20                                                 */
        *--p_stk =(OS_STK)0x41980000u;                         /* S19                                                 */
        *--p_stk =(OS_STK)0x41900000u;                        /* S18                                                 */
        *--p_stk =(OS_STK)0x41880000u;                        /* S17                                                 */
        *--p_stk =(OS_STK)0x41800000u;                        /* S16                                                 */
        *--p_stk =(OS_STK)0x41700000u;                        /* S15                                                  */
        *--p_stk =(OS_STK)0x41600000u;                        /* S14                                                 */
        *--p_stk =(OS_STK)0x41500000u;                        /* S13                                                  */
        *--p_stk =(OS_STK)0x41400000u;                        /* S12                                                 */
        *--p_stk =(OS_STK)0x41300000u;                        /* S11                                                 */
        *--p_stk =(OS_STK)0x41200000u;                        /* S10                                                 */
        *--p_stk =(OS_STK)0x41100000u;                        /* S9                                                   */
        *--p_stk =(OS_STK)0x41000000u;                        /* S8                                                  */
        *--p_stk =(OS_STK)0x40E00000u;                        /* S7                                                  */
        *--p_stk =(OS_STK)0x40C00000u;                        /* S6                                                  */
        *--p_stk =(OS_STK)0x40A00000u;                        /* S5                                                  */
        *--p_stk =(OS_STK)0x40800000u;                        /* S4                                                  */
        *--p_stk =(OS_STK)0x40400000u;                        /* S3                                                  */
        *--p_stk =(OS_STK)0x40000000u;                        /* S2                                                  */
        *--p_stk =(OS_STK)0x3F800000u;                        /* S1                                                  */
        *--p_stk = (OS_STK)0x00000000u;                         /* S0                                                  */
#endif
    return (p_stk);
    官方提供的这个堆栈初始化是错误的的,为什么是错误的?因为这个不符合浮点寄存器的入栈和出栈顺序。还有一部分代码在os_cpu_a.asm文件中,内容如下:
  1. #ifdef __ARMVFP__
  2.     PUBLIC  OS_CPU_FP_Reg_Push
  3.     PUBLIC  OS_CPU_FP_Reg_Pop
  4. #endif
  5. ;********************************************************************************************************
  6. ;                                               EQUATES
  7. ;********************************************************************************************************
  8. NVIC_INT_CTRL   EQU     0xE000ED04                              ; Interrupt control state register.
  9. NVIC_SYSPRI14   EQU     0xE000ED22                              ; System priority register (priority 14).
  10. NVIC_PENDSV_PRI EQU           0xFF                              ; PendSV priority value (lowest).
  11. NVIC_PENDSVSET  EQU     0x10000000                              ; Value to trigger PendSV exception.
  12. ;********************************************************************************************************
  13. ;                                     CODE GENERATION DIRECTIVES
  14. ;********************************************************************************************************
  15.     RSEG CODE:CODE:NOROOT(2)
  16.     THUMB
  17. #ifdef __ARMVFP__
  18. ;********************************************************************************************************
  19. ;                                   FLOATING POINT REGISTERS PUSH
  20. ;                             void  OS_CPU_FP_Reg_Push (OS_STK  *stkPtr)
  21. ;
  22. ; Note(s) : 1) This function saves S0-S31, and FPSCR registers of the Floating Point Unit.
  23. ;
  24. ;           2) Pseudo-code is:
  25. ;              a) Get FPSCR register value;
  26. ;              b) Push value on process stack;
  27. ;              c) Push remaining regs S0-S31 on process stack;
  28. ;              d) Update OSTCBCur->OSTCBStkPtr;
  29. ;********************************************************************************************************
  30. OS_CPU_FP_Reg_Push
  31.     MRS     R1, PSP                                             ; PSP is process stack pointer
  32.     CBZ     R1, OS_CPU_FP_nosave                                ; Skip FP register save the first time
  33.
  34.     VMRS    R1, FPSCR
  35.     STR R1, [R0, #-4]!
  36.     VSTMDB  R0!, {S0-S31}
  37.     LDR     R1, =OSTCBCur
  38.     LDR     R2, [R1]
  39.     STR     R0, [R2]
  40. OS_CPU_FP_nosave
  41.     BX      LR
  42. ;********************************************************************************************************
  43. ;                                   FLOATING POINT REGISTERS POP
  44. ;                             void  OS_CPU_FP_Reg_Pop (OS_STK  *stkPtr)
  45. ;
  46. ; Note(s) : 1) This function restores S0-S31, and FPSCR registers of the Floating Point Unit.
  47. ;
  48. ;           2) Pseudo-code is:
  49. ;              a) Restore regs S0-S31 of new process stack;
  50. ;              b) Restore FPSCR reg value
  51. ;              c) Update OSTCBHighRdy->OSTCBStkPtr pointer of new proces stack;
  52. ;********************************************************************************************************
  53. OS_CPU_FP_Reg_Pop
  54.     VLDMIA  R0!, {S0-S31}
  55.     LDMIA   R0!, {R1}
  56.     VMSR    FPSCR, R1
  57.     LDR     R1, =OSTCBHighRdy
  58.     LDR     R2, [R1]
  59.     STR     R0, [R2]
  60.     BX      LR
  61. #endif
    如果不理解为什么这个浮点寄存的入栈和出栈是错误的,需要认真学习一下第5章:任务切换设计。第5章对于这个问题有深入的讲解。
10.2  开启FPU解决方案
    为了解决FPU的问题,有两个函数需要修改:一个是CPU_STK  *OSTaskStkInit(),另一个是PendSV中断。
10.2.1      修改函数CPU_STK  *OSTaskStkInit()
    函数所在的位置如下:
    下面是修改后的内容:
  1. CPU_STK  *OSTaskStkInit (OS_TASK_PTR    p_task,
  2.                          void          *p_arg,
  3.                          CPU_STK       *p_stk_base,
  4.                          CPU_STK       *p_stk_limit,
  5.                          CPU_STK_SIZE   stk_size,
  6.                          OS_OPT         opt)
  7. {
  8.     CPU_STK  *p_stk;
  9.     (void)opt;                                              /* Prevent compiler warning                               */
  10.     p_stk = &p_stk_base[stk_size];                          /* Load stack pointer                                     */
  11.                                                             /* Align the stack to 8-bytes.                            */
  12.     p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8);
  13.                                                             /* Registers stacked as if auto-saved on exception        */
  14. *--p_stk = (CPU_STK)0x01000000u;                        /* xPSR                                                 */
  15.     *--p_stk = (CPU_STK)p_task;                             /* Entry Point                                            */
  16.     *--p_stk = (CPU_STK)OS_TaskReturn;                      /* R14 (LR)                                               */
  17.     *--p_stk = (CPU_STK)0x12121212u;                        /* R12                                                    */
  18.     *--p_stk = (CPU_STK)0x03030303u;                        /* R3                                                     */
  19.     *--p_stk = (CPU_STK)0x02020202u;                        /* R2                                                     */
  20.     *--p_stk = (CPU_STK)p_stk_limit;                        /* R1                                                     */
  21.     *--p_stk = (CPU_STK)p_arg;                              /* R0 : argument                                          */
  22.                                                             /* Remaining registers saved on process stack             */
  23.     *--p_stk = (CPU_STK)0x11111111u;                        /* R11                                                    */
  24.     *--p_stk = (CPU_STK)0x10101010u;                        /* R10                                                    */
  25.     *--p_stk = (CPU_STK)0x09090909u;                        /* R9                                                     */
  26.     *--p_stk = (CPU_STK)0x08080808u;                        /* R8                                                     */
  27.     *--p_stk = (CPU_STK)0x07070707u;                        /* R7                                                     */
  28.     *--p_stk = (CPU_STK)0x06060606u;                        /* R6                                                     */
  29.     *--p_stk = (CPU_STK)0x05050505u;                        /* R5                                                     */
  30.     *--p_stk = (CPU_STK)0x04040404u;                        /* R4                                                     */
  31.     *--p_stk = (CPU_STK)0xFFFFFFFDUL;        (1)
  32.
  33.       return (p_stk);
  34. }
1.     这句话最重要,这里是将EXC_RETURN也进行了入栈处理。关于EXC_RETURN在前面4.2.5 特殊功能寄存器讲解。这里要补充一点,对于M4内核,EXC_RETURN的bit4也是有意义的。
        当bit4 = 1时,8个寄存器自动入栈,还有8个寄存器需要手动入栈
        当bit4 = 0时,18个浮点寄存器+8个寄存器自动入栈,还有16个浮点寄存器+8个寄存器需要手动入栈。
    这些寄存器在第4章和第5章有详细的讲解,这里就不再赘述了。
10.2.2      修改函数OS_CPU_PendSVHandler
    函数所在的位置如下:
    PendSV中断需要修改的地方如下:
  1. OS_CPU_PendSVHandler
  2.     CPSID   I                                                   ; Prevent interruption during context switch
  3.     MRS     R0, PSP                                             ; PSP is process stack pointer
  4.     CBZ     R0, OS_CPU_PendSVHandler_nosave                     ; Skip register save the first time
  5.     TST      LR, #0x10        (1)
  6. IT       EQ
  7. VSTMDBEQ R0!, {S16-S31}
  8.
  9. MOV      R3, LR        (2)
  10. STMDB    R0!,{R3-R11}
  11.     LDR     R1, =OSTCBCurPtr                                    ; OSTCBCurPtr->OSTCBStkPtr = SP;
  12.     LDR     R1, [R1]
  13.     STR     R0, [R1]                                            ; R0 is SP of process being switched out
  14.        ; At this point, entire context of process has been saved
  15. OS_CPU_PendSVHandler_nosave
  16.     PUSH    {R14}                                               ; Save LR exc_return value
  17.     LDR     R0, =OSTaskSwHook                                   ; OSTaskSwHook();
  18.     BLX     R0
  19.     POP     {R14}
  20.     LDR     R0, =OSPrioCur                                      ; OSPrioCur   = OSPrioHighRdy;
  21.     LDR     R1, =OSPrioHighRdy
  22.     LDRB    R2, [R1]
  23.     STRB    R2, [R0]
  24.     LDR     R0, =OSTCBCurPtr                                    ; OSTCBCurPtr = OSTCBHighRdyPtr;
  25.     LDR     R1, =OSTCBHighRdyPtr
  26.     LDR     R2, [R1]
  27.     STR     R2, [R0]
  28.     LDR     R0, [R2]                                            ; R0 is new process SP; SP = OSTCBHighRdyPtr->StkPtr;
  29.     LDMIA    R0!,{R3-R11}        (3)
  30. MOV      LR, R3
  31.
  32. TST      LR, #0x10        (4)
  33. IT       EQ
  34. VLDMIAEQ R0!, {S16-S31}
  35.
  36.     MSR     PSP, R0                                             ; Load PSP with new process SP
  37.
  38.     CPSIE   I
  39.     BX      LR                                                  ; Exception return will restore remaining context
  40.     END
1.     通过检测EXC_RETURN(LR)的bit4来看这个任务是否使用了浮点寄存器,如果使用了需要将剩余的16个浮点寄存器入栈。
TST   LR,  #0x10:
    TST指令通常与EQ,NE条件码配合使用。当所有测试位均为0时,EQ有效。而只要有一个测试位不为0,则NE有效。这里LR和0x10的值按位作逻辑“与”操作。
IT  EQ :
    这里IT指令就是IF-THEN的缩写。IF‐THEN(IT)指令围起一个块,里面最多有4条指令,它里面的指令可以条件执行。 IT已经带了一个“T”,因此还可以最多再带3个“T”或者“E”。并且对T和E的顺序没有要求。其中T对应条件成立时执行的语句,E对应条件不成立时执行的语句。在If‐Then块中的指令必须加上条件后缀,且T对应的指令必须使用和IT指令中相同的条件,E对应的指令必须使用和IT指令中相反的条件。
    IT的使用形式总结如下:
        IT<cond> ;围起1条指令的IF-THEN块
        IT<x><cond> ;围起2条指令的IF-THEN块
        IT<x><y>  <cond> ;围起3条指令的IF-THEN块
        IT<x><y><z><cond> ;围起4条指令的IF-THEN块
    其中<x>, <y>,<z>的取值可以是“T”或者“E”。而<cond>则是在下表中列出的条件(AL除外)。
    这么说还不够形象,下面举一个简单的例子,用IT指令优化C伪代码:
if(R0==R1)
R3= R4 + R5;
R3= R3 / 2;
R3= R6 + R7;
R3= R3 / 2;
    可以写作:
CMP  R0, R1     ; 比较R0和R1
ITTEEEQ          ; 如果R0== R1, Then-Then-Else-Else
ADDEQR3,R4, R5  ; 相等时加法
ASREQR3,R3, #1   ; 相等时算术右移
ADDNER3,R6, R7  ; 不等时加法
ASRNER3,R3, #1   ; 不等时算术右移
    有了上面这些基础知识后再看下面的指令。
VSTMDBEQ R0!, {S16-S31}:
    结合上面的IT EQ,这里的意思就是 if  LR & 0x10 == 0 then  VSTMDB R0!, {S16-S31}。也就是咱们前面所说的如果EXC_RETURN(LR)的bit4= 0就表示使用浮点寄存器了,这里需要入栈。
2.     这里比较好理解,只不过也将EXC_RETURN进行了入栈。
3.     参考上面的第二条,只不过这里是出栈。
4.     参考上面的第一条,只不过这里是出栈。
10.2.3      开启FPU
    修改了上面的两个地方后别忘了开启FPU:
    通过上面这三部就完成了相关的修改。
10.3 开启FPU的优劣
   开启FPU的好处就是加快浮点运算的执行速度,缺点就是增加任务堆栈的大小,因为34个浮点寄存器也需要入栈。同时也增加了任务的切换时间。下面是在μCOS-III的GUI任务和启动任务中使用了浮点运算的对比(App Task GUI和App Task Start)。
    第一个截图是开启了FPU:
    第二个截图是没有开启FPU:
    特别对比下使用了浮点运行的两个任务。
10.4  总结
    本期教程提供的方案在MDK4.54、4.73、5.10以及IAR6.3、6.7上面测试均通过,用户只需按照上面讲的三个地方做修改即可。
努力打造安富莱高质量微信公众号:点击扫描图片关注
发表于 2014-12-29 21:12:53 | 显示全部楼层
[s:151]  看的有点晕
发表于 2019-4-26 23:24:40 | 显示全部楼层
之前没留意到这个问题,但我们发现只能在一个任务中使用浮点单元,甚至连中断中都不能用浮点运算,否则会导致任务中的浮点运算出错,会不会就是跟这个有关系?
发表于 2019-4-27 09:20:50 | 显示全部楼层
云琴箫龙 发表于 2019-4-26 23:24
之前没留意到这个问题,但我们发现只能在一个任务中使用浮点单元,甚至连中断中都不能用浮点运算,否则会导 ...
可以使用本帖方案走一个。
发表于 2019-4-27 09:39:53 | 显示全部楼层
eric2013 发表于 2019-4-27 09:20
可以使用本帖方案走一个。
这个可以有
发表于 2019-4-28 09:47:54 | 显示全部楼层
之前多任务或者中断中调用浮点单元只会偶尔出现计算异常,昨天再次试着多任务调用浮点运算还真没出现异常的情况。
发表于 2019-5-16 13:49:48 | 显示全部楼层
可以使用本帖方案走一个。
今天在以前一个正常的程序上试了一下,发现程序不调度,一直在空闲任务里面,对比两个内核版本,发现硬汉的版本是V3.01.2,而我之前移植的版本是V3.04.04,在os_cpu_a.asm文件中新增了OS_CPU_FP_Reg_Push和OS_CPU_FP_Reg_Pop两个函数,难道这个版本已经修复浮点问题了(我遇到的问题是多个任务或中断中都使用浮点,会造成浮点寄存器出错)。 os_cpu_a.asm (12.68 KB, 下载次数: 8)
发表于 2019-5-16 15:01:05 | 显示全部楼层
云琴箫龙 发表于 2019-5-16 13:49
今天在以前一个正常的程序上试了一下,发现程序不调度,一直在空闲任务里面,对比两个内核版本,发现硬汉 ...
对这个问题,建议把所有相关的uCOS-III工程,统一升级到3.07.0x,别再折腾这些老版本了,太耗精力了。
发表于 2019-5-16 15:37:59 | 显示全部楼层
是啊,同意的观点
GMT+8, 2026-11-23 16:09 , Processed in 1.467582 second(s), 27 queries .
