查看: 6773|回复: 2
XILINX 开发板资料下载(开发板由Digilent提供)
发表于 2013-1-8 20:36:27 | 显示全部楼层 |阅读模式
网址:http://www.digilentinc.com/
我只用过下面两款,不过只会点个LED,实在是把板子的资源浪费了,等我想学FPGA了
板子却被老师收回去了。
Spartan 3E Starter Board
    [li]Xilinx XC3S500E FPGA[/li][li]Xilinx XCF04 Platform Flash for storing FPGA configurations[/li][li]32MB Micron DDR SDRAM[/li][li]16MB Numonyx StrataFlash[/li][li]2MB ST Microelectronics Serial Flash[/li][li]Linear Technologies Power Supplies[/li][li]Texas Instruments TPS75003 Triple-Supply Power Management IC[/li][li]SMSC LAN83C185 Ethernet PHY[/li]
下面的这个板子最霸道,可以当电脑主板用。什么硬盘,内存条都可以用。
Virtex-II Pro Development System
    [li]Virtex-2 Pro XC2VP30 FPGA with 30,816 Logic Cells, 136 18-bit multipliers, 2,448Kb of block RAM, and two PowerPC Processors[/li][li]DDR SDRAM DIMM that can accept up to 2Gbytes of RAM[/li][li]10/100 Ethernet port[/li][li]USB2 port[/li][li]Compact Flash card slot[/li][li]XSGA Video port[/li][li]Audio Codec[/li][li]SATA, and PS/2, RS-232 ports[/li][li]High and Low Speed expansion connectors with a large collection of available expansion boards[/li]
 楼主| 发表于 2013-1-8 20:41:00 | 显示全部楼层
此公司提供了以下开发板(貌似只做xilinx的),相应的开发板都有开发板资料下载
发表于 2014-4-6 12:42:48 | 显示全部楼层
顶一下
GMT+8, 2026-10-24 00:47 , Processed in 0.677613 second(s), 27 queries .
