查看: 5383|回复: 2
XILINX   VIRTEX-5原理图
发表于 2013-1-6 21:28:31 | 显示全部楼层 |阅读模式
本以为自己不用搞FPGA这部分了,哎,看来这部分也得我搞。
最近在加紧搞FPGA,感觉FPGA进阶有点困难啊。
网上找了个XILINX   VIRTEX-5原理图  很不错。
virtex-v5.pdf (886 KB, 下载次数: 292)
发表于 2020-12-28 13:03:22
发表于 2025-9-11 13:58:45
The best way to reduce the need for repairs on flat chested sex dolls is to establish a scientific daily maintenance routine. Clean the silicone surface promptly after each use to prevent sweat, oil, and other substances from prolonged contact with the silicone surface. The life size sex doll should be stored in a dedicated stand to prevent prolonged pressure that could cause deformation or permanent marks. For flat areas of flat chested sex dolls, regularly apply silicone care product to maintain the material's elasticity and prevent premature aging. A comprehensive inspection every three months is recommended to detect and address minor issues before they become major problems requiring professional repair.
发表于 2025-9-11 13:59:06
发表于 2025-9-11 13:59:33
发表于 2026-8-8 11:30:59 | 显示全部楼层
A comprehensive overhaul of industry practices does not mean limiting innovation. Instead, it provides an opportunity to build a stronger foundation for future growth. By improving regulations, strengthening manufacturing standards, protecting consumer privacy, and promoting ethical design, the AI sex dolls usa industry can continue developing in a more sustainable direction.
发表于 2026-8-10 17:22:47 | 显示全部楼层
From the meticulously sculpted facial contours to the elegant overall silhouette, every sex dolls  detail reflects the artistry and dedication poured into its creation.
The structure is engineered with rigorous precision, ensuring both stability and flexibility while perfectly maintaining the sexdolls usa's elegant posture and carefully conceived appearance.
GMT+8, 2026-11-23 04:34 , Processed in 0.739557 second(s), 27 queries .
