查看: 5947|回复: 0
[其它] Unicode string和ANSI/OEM string在FatFS中的定义
发表于 2014-11-4 13:35:15 | 显示全部楼层 |阅读模式
/* Type of path name strings on FatFs API */
#if _LFN_UNICODE            /* Unicode string */
#if !_USE_LFN
#error _LFN_UNICODE must be 0 at non-LFN cfg.
#endif
#ifndef _INC_TCHAR
typedef WCHAR TCHAR;
#define _T(x) L ## x
#define _TEXT(x) L ## x
#endif
#else                        /* ANSI/OEM string */
#ifndef _INC_TCHAR
typedef char TCHAR;
#define _T(x) x
#define _TEXT(x) x
#endif
#endif
GMT+8, 2026-11-23 06:42 , Processed in 0.259359 second(s), 24 queries .
