查看: 7235|回复: 3
[emWin] 关于emwin定时器问题求教!
发表于 2014-9-23 19:04:21 | 显示全部楼层 |阅读模式
本人在程序中设置了一个定时器,定时刷新界面,可是就是不启动,请大家帮帮忙!程序如下。
const GUI_WIDGET_CREATE_INFO _APP_CNC_AUTO[] = {
{ FRAMEWIN_CreateIndirect, "",                                   0,     0,   0,  800, 443, 0, 0,GUI_TA_HCENTER},
{ MULTIEDIT_CreateIndirect, ""  ,                GUI_ID_MULTIEDIT0,    2,   5, 320, 240,MULTIEDIT_CF_READONLY},   //图像显示区域
{ MULTIEDIT_CreateIndirect, ""  ,                ID_MULTIEDIT_17,    445,  2, 345, 350,MULTIEDIT_CF_READONLY},
{ TEXT_CreateIndirect,       "当前坐标",         ID_TEXT_1,          450,  5,  64,  16, 0, 0},
{ TEXT_CreateIndirect,       "X:",               ID_TEXT_2,          460,  25,  36,  24, 0, 0},
{ MULTIEDIT_CreateIndirect,  ""  ,               ID_MULTIEDIT_1,     550,  25, 235,  30,MULTIEDIT_CF_READONLY},   //X:   当前坐标
{ TEXT_CreateIndirect,       "",                 ID_TEXT_3,          550,  25, 235,  30, 0, 0},                   //X轴数值显示
void _InitCNCDialogShow(WM_MESSAGE * pMsg)
  WM_HWIN hWin = pMsg->hWin;
  BUTTON_SetFont(WM_GetDialogItem(hWin,ID_BOTTON_0),&GUI_FontHZ_SimSun_1616);//文本字体
  BUTTON_SetTextAlign(WM_GetDialogItem(hWin,ID_BOTTON_0),GUI_TA_CENTER|GUI_TA_VCENTER); //文本右水平与垂直居中对齐
  MULTIEDIT_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_MULTIEDIT0),MULTIEDIT_CI_READONLY,GUI_BLUE);
  TEXT_SetTextColor(WM_GetDialogItem(hWin,ID_TEXT_1),GUI_MAGENTA);
  TEXT_SetFont(WM_GetDialogItem(hWin,ID_TEXT_1),&GUI_FontHZ_SimSun_1616);//文本字体
  TEXT_SetTextAlign(WM_GetDialogItem(hWin,ID_TEXT_1),GUI_TA_CENTER|GUI_TA_VCENTER); //文本右水平与垂直居中对齐  。。。。。。。。。。。。。
void Caculate_CNCNUM(WM_MESSAGE * pMsg)
   char buf[1];
  sprintf(buf,"%6d",Coord.X);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_3), buf);
  sprintf(buf,"%6d",Coord.Y);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_5), buf);
  sprintf(buf,"%6d",Coord.Z);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_7), buf);
  sprintf(buf,"%6d",Coord.A);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_9), buf);
  sprintf(buf,"%3.2f",Coord.X1);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_12), buf);
  sprintf(buf,"%3.2f",Coord.Y1);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_14), buf);
  sprintf(buf,"%3.2f",Coord.Z1);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_16), buf);
  sprintf(buf,"%3.2f",Coord.A1);
   TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_18), buf);
  sprintf(buf,"%4d",Speed.MOTO[0]);
  TEXT_SetText(WM_GetDialogItem(hWin,ID_TEXT_25), buf);
}void _cncCallback(WM_MESSAGE * pMsg)
int i, NCode, Id, Value;
  switch (pMsg->MsgId)
   case WM_TIMER:
     Caculate_CNCNUM(pMsg);
     WM_RestartTimer(pMsg->Data.v, 100);    //重启定时器
   case WM_PAINT:
   case WM_INIT_DIALOG:
       _InitCNCDialogShow(pMsg);             //对话框
   case WM_NOTIFY_PARENT:            //告知父窗口,其子窗口中发生了某些改变。
     Id    = WM_GetId(pMsg->hWinSrc);      /* Id of widget */
     NCode = pMsg->Data.v;                 /* Notification code */
     switch (NCode)
      case WM_NOTIFICATION_CLICKED:
        switch (Id)
         case ID_BOTTON_0:
   default:
    WM_DefaultProc(pMsg);
void APP_CNC_AUTO (void)
WM_HWIN hWin2;
   hWin2=GUI_CreateDialogBox(_APP_CNC_Munm, GUI_COUNTOF(_APP_CNC_Munm), &_cncCallback, 0, 0, 0);
    FRAMEWIN_SetText(hWin2,"CNC_system demo                                         MODE:手动");   WM_CreateTimer(WM_GetClientWindow(hWin2),  0,  100,    while (1)
    GUI_Delay(10);
}启动很正常,其它功能也正常,就是WM_TIMER不能定时刷新。仿真发现WM_TIMER根本没有工作。求助!!!!!!!!!
发表于 2014-9-23 21:42:20 | 显示全部楼层
定时的创建和使用是正确的,你在回调函数里面调用串口打印一下输出,确定是否能够定时的进出。
发表于 2014-10-22 15:45:41 | 显示全部楼层
楼主,你的问题解决了没有?我也遇到相同的问题,定时器创建了,但是执行不了case timer,如果解决了请指教,qq963429304,谢谢楼主
发表于 2014-10-22 17:33:54 | 显示全部楼层
回 简单爱琴海 的帖子
简单爱琴海:楼主,你的问题解决了没有?我也遇到相同的问题,定时器创建了,但是执行不了case timer,如果解决了请指教,qq963429304,谢谢楼主 (2014-10-22 15:45)
严格按照我们60期emWin教程的定时器篇章试试,应该没有问题的。
GMT+8, 2026-11-23 06:59 , Processed in 0.521114 second(s), 30 queries .
