查看: 4088|回复: 2
[FatFs] FatFS升级到0.13a版本(更新日期2017-10-14)
发表于 2017-10-16 00:39:45 | 显示全部楼层 |阅读模式
论坛下载: ff13a.zip (2.26 MB, 下载次数: 142)
官方下载地址: http://elm-chan.org/fsw/ff/00index_e.html
R0.13a (October 14, 2017)
  Added support for UTF-8 encoding on the API. (FF_LFN_UNICODE = 2)
  Added options for file name output buffer. (FF_LFN_BUF, FF_SFN_BUF).
  Added dynamic memory allocation option for working buffer of f_mkfs() and f_fdisk().
  Fixed f_fdisk() and f_mkfs() create the partition table with wrong CHS parameters. (appeared at R0.09)
  Fixed f_unlink() can cause lost clusters at fragmented file on the exFAT volume. (appeared at R0.12c)
  Fixed f_setlabel() rejects some valid characters for exFAT volume. (appeared at R0.12)
R0.13 (May 21, 2017)
  Changed heading character of configuration keywords "_" to "FF_".
  Removed ASCII-only configuration, FF_CODE_PAGE = 1. Use FF_CODE_PAGE = 437 instead.
  Added f_setcp(), run-time code page configuration. (FF_CODE_PAGE = 0)
  Improved cluster allocation time on stretch a deep buried cluster chain.
  Improved processing time of f_mkdir() with large cluster size by using FF_USE_LFN = 3.
  Improved NoFatChain flag of the fragmented file to be set after it is truncated and got contiguous.
  Fixed archive attribute is left not set when a file on the exFAT volume is renamed. (appeared at R0.12)
  Fixed exFAT FAT entry can be collapsed when write or lseek operation to the existing file is done. (appeared at R0.12c)
  Fixed creating a file can fail when a new cluster allocation to the exFAT directory occures. (appeared at R0.12c)
R0.12c (March 04, 2017)
  Improved write throughput at the fragmented file on the exFAT volume.
  Made memory usage for exFAT be able to be reduced as decreasing _MAX_LFN.
  Fixed successive f_getfree() can return wrong count on the FAT12/16 volume. (appeared at R0.12)
  Fixed configuration option _VOLUMES cannot be set 10. (appeared at R0.10c)
发表于 2017-11-24 15:48:16 | 显示全部楼层
如果把例程中更新为R0.13,请问需要更改哪些地方?
 楼主| 发表于 2017-11-24 17:29:07 | 显示全部楼层
回 游在云间 的帖子
游在云间:如果把例程中更新为R0.13,请问需要更改哪些地方? (2017-11-24 15:48)
底层不用改,ffconf.h文件里面根据需要做配置,另外有个结构体好像有修改。
具体我还没有测试,这个是用户反馈的。
GMT+8, 2026-10-24 22:05 , Processed in 0.171833 second(s), 27 queries .
