查看: 5979|回复: 2
[客户分享] ST最新发布的高边电流检测运放(从资料来看效果不错),用于测试板子功耗非常方便
发表于 2014-7-19 11:35:15 | 显示全部楼层 |阅读模式
先说下什么是高边电流检测,看这个帖子(来自Maxim公司):
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=2453
Key Features
    [li]Independent supply and input common-mode voltages[/li][li]Wide common-mode operating range: 2.9 V to 70 V in single-supply configuration, -2.1 V to 65 V in dual-supply configuration[/li][li]Wide common-mode surviving range: -16 V to 75 V (reversed battery and load-dump conditions)[/li][li]Supply voltage range: 2.7 to 5.5 V in single-supply configuration[/li][li]Low current consumption: I[sub]CC[/sub]max = 360 μA[/li][li]Pin selectable gain: 20 V/V, 25 V/V, 50 V/V or 100 V/V[/li][li]Buffered output[/li]
勘误手册:
disclaimer_errata.pdf (158 KB, 下载次数: 513)
数据手册:
DM00109906.pdf (767 KB, 下载次数: 168)
原地址链接:
http://www.st.com/web/catalog/se ... ;amp;sp_mid=9823012
发表于 2014-7-19 11:49:19 | 显示全部楼层
给你补上原地址了,看了下价格还行。
发表于 2014-7-21 15:54:45 | 显示全部楼层
看看。。。。。。。。
GMT+8, 2026-11-28 12:16 , Processed in 0.594400 second(s), 27 queries .
