查看: 3055|回复: 1
[emWin] 请教STM32F103平台上出现按钮创建对话框程序死掉问题
发表于 2017-9-26 11:17:28 | 显示全部楼层 |阅读模式
按钮创建对话框三次后程序会死掉,同时请教STemwin内存管理问题
代码如下:
extern const GUI_BITMAP bm3;
    { FRAMEWIN_CreateIndirect,  "",           0,                       0,  0,  320,240, 0,0},
        { BUTTON_CreateIndirect,    "Address",        GUI_ID_BUTTON0,         240,204,80,36,0,0},
        { BUTTON_CreateIndirect,    &quotM2.5",            GUI_ID_BUTTON1,         240,24,80,60 ,0,0},
        { BUTTON_CreateIndirect,    "Temperature",    GUI_ID_BUTTON2,         240,84,80,60, 0,0},
        { BUTTON_CreateIndirect,    "humidity",       GUI_ID_BUTTON3,         240,144,80,60, 0,0},
static const GUI_WIDGET_CREATE_INFO _aButtonCreateA[] = {
    { FRAMEWIN_CreateIndirect,  "Address",           0,                       40,  40,  200,180, 0,0},
static const GUI_WIDGET_CREATE_INFO _aButtonCreateP[] = {
    { FRAMEWIN_CreateIndirect,  &quotM2.5",           0,                      40,  40,  200,180,FRAMEWIN_CF_ACTIVE,0},
static const GUI_WIDGET_CREATE_INFO _aButtonCreateT[] = {
    { FRAMEWIN_CreateIndirect,  "Temperature",           0,                      40,  40,  200,180,FRAMEWIN_CF_ACTIVE,0},
static const GUI_WIDGET_CREATE_INFO _aButtonCreateH[] = {
    { FRAMEWIN_CreateIndirect,  "humidity",           0,                      40,  40,  200,180,FRAMEWIN_CF_ACTIVE,0},
void upmap(void);
*       A′°¿ú
void PaintDialog_A(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
        upmap();
void InitDialog_A(WM_MESSAGE * pMsg)
        BUTTON_Handle Button_Add;
        FRAMEWIN_SetTitleVis(hWin,0);
        FRAMEWIN_SetBorderSize(hWin,0);
        FRAMEWIN_SetClientColor(hWin,GUI_BLACK);
        Button_Add=WM_GetDialogItem(hWin,GUI_ID_BUTTON0);
        BUTTON_SetBkColor(Button_Add,0,0xff0000 + (255 - 200) * 0x101L);
        BUTTON_SetBkColor(Button_Add,1,GUI_BLUE);
*       BD¡′°
void PaintDialog_ADD(WM_MESSAGE * pMsg)
void InitDialog_ADD(WM_MESSAGE * pMsg)
//         FRAMEWIN_AddButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0, GUI_ID_BUTTON6);
        FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
        FRAMEWIN_SetTitleHeight(hWin,16);
        FRAMEWIN_SetBarColor(hWin,1,0xff0000 + (255 - 200) * 0x101L);
*       cbButton»Øμ÷oˉêy
static void _cbButton_ADD(WM_MESSAGE * pMsg)
        int NCode, Id;
    switch (pMsg->MsgId)
            case WM_INIT_DIALOG:
            InitDialog_ADD(pMsg);
//             case WM_NOTIFY_PARENT:
//             Id = WM_GetId(pMsg->hWinSrc);
//             NCode = pMsg->Data.v;
//             switch (Id)
//                 case GUI_ID_BUTTON6:
//                     if(NCode==WM_NOTIFICATION_RELEASED)
//                                             GUI_EndDialog(hWin,0);
//                                             WM_DeleteWindow(pMsg->hWinSrc);
//                                 break;
            case WM_DELETE:
                    GUI_ALLOC_Free(pMsg->hWin);
            default:
          WM_DefaultProc(pMsg);
static void _cbButton_PM(WM_MESSAGE * pMsg)
                case WM_DELETE:
        default:
static void _cbButton_TMP(WM_MESSAGE * pMsg)
                case WM_DELETE:
        default:
static void _cbButton_HM(WM_MESSAGE * pMsg)
                case WM_DELETE:
        default:
*       cbCallback£¨Ö÷½çÃæ£©   »Øμ÷oˉêy
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
        case WM_PAINT:
            PaintDialog_A(pMsg);
            InitDialog_A(pMsg);
            switch (Id)
                case GUI_ID_BUTTON0:
                       GUI_ExecDialogBox(_aButtonCreateA, GUI_COUNTOF(_aButtonCreateA), &_cbButton_ADD, hWin, 0, 0);
                                case GUI_ID_BUTTON1:
                                            GUI_ExecDialogBox(_aButtonCreateP,GUI_COUNTOF(_aButtonCreateP),&_cbButton_PM,hWin,0,0);
                                case GUI_ID_BUTTON2:
                                            GUI_ExecDialogBox(_aButtonCreateT,GUI_COUNTOF(_aButtonCreateT),&_cbButton_TMP,hWin,0,0);
                                case GUI_ID_BUTTON3:
                                            GUI_ExecDialogBox(_aButtonCreateH,GUI_COUNTOF(_aButtonCreateH),&_cbButton_HM,hWin,0,0);
                default:
*       MainTask
int main(void)
    SystemInit();
    delay_init(72);         //Ñóê±3õê¼»ˉ
    NVIC_Configuration();
    uart_init(9600);
     LED_Init();
    KEY_Init();
    Timerx_Init();
  GUI_Init();
  WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
  WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
    while(1)
    GUI_Exec();
void upmap(void)
    //GUI_MEMDEV_Handle item;
    //hWnd=WM_CreateWindow(0,0,320,240,WM_CF_SHOW,&_cbBkWindow,0);
    //item = GUI_MEMDEV_Create(0,0,320,24);
    //GUI_MEMDEV_Select(item);
    GUI_SetDrawMode(GUI_DRAWMODE_NORMAL);
    GUI_SetBkColor(GUI_WHITE);
    GUI_SetFont(&GUI_Font16_ASCII);
    GUI_SetColor(0xff0000 + (255 - 200) * 0x101L);
    GUI_SetTextMode(GUI_TM_TRANS);
    GUI_DrawBitmap(&bm3,0,0);
    GUI_DispStringAt("kn", 40, 5);
    //GUI_MEMDEV_CopyToLCDAA(item);
    //GUI_MEMDEV_Delete(item);
发表于 2017-9-26 12:20:41 | 显示全部楼层
程序中有两个主要问题,一个是函数 GUI_ALLOC_Free(pMsg->hWin);,此函数删掉,关闭对话框会自动收回。
还有一个最主要的问题,这里不可以使用阻塞式的对话框创建方式,这样会层层嵌套,直到死机:GUI_ExecDialogBox
程序中所有的GUI_ExecDialogBox函数,统一修改成非阻塞的函数:GUI_CreateDialogBox来实现。
另外多窗口的控制管理可以学习下我们的这个例子:https://forum.anfulai.cn/forum.php?mod=viewthread&tid=19834
GMT+8, 2026-11-23 10:31 , Processed in 0.553186 second(s), 27 queries .
