查看: 3525|回复: 1
[FreeRTOS] FreeRTOS + emWin移植,用GUI基础函数画点线和字符串正常,但运行带窗体的demo不正
发表于 2017-9-20 18:02:21 | 显示全部楼层 |阅读模式
各位大神,再请教下,Keil5.23安装路径下STM32469I-Discovery目录下面emwin和FreeRTOS例子各自下载到板子上也都能正常运行,我现在把俩工程整理融合,期望做 STM32469I +emwin +FreeRTOS,移植已完成,编译无错误,下载到板子上。对于仅仅用GUI基本函数画点线显示字符的demo都能正常显示;但对于GUIBuilder demo这些带有windows或者dialog窗体的例子,就显示不正常:背景图片不显示,滚动条控件只显示轮廓不动作,请问是啥原因啊?下附main.c文件
  * @file    STemWin/STemWin_SampleDemo/Src/main.c
  * @author  MCD Application Team
  * @version V1.0.6
  * @date    04-November-2016
  * @brief   This file provides main program functions
  * @attention
  * <h2><center>© Copyright © 2016 STMicroelectronics International N.V.
  * All rights reserved.</center></h2>
  * Redistribution and use in source and binary forms, with or without
  * modification, are permitted, provided that the following conditions are met:
  * 1. Redistribution of source code must retain the above copyright notice,
  *    this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  *    this list of conditions and the following disclaimer in the documentation
  *    and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of other
  *    contributors to this software may be used to endorse or promote products
  *    derived from this software without specific written permission.
  * 4. This software, including modifications and/or derivative works of this
  *    software, must execute solely and exclusively on microcontroller or
  *    microprocessor devices manufactured by or for STMicroelectronics.
  * 5. Redistribution and use of this software other than as permitted under
  *    this license is void and will automatically terminate your rights under
  *    this license.
  * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
  * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
  * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "rtc.h"
#include "GUIDEMO.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
osThreadId LEDThread1Handle, LEDThread2Handle;
TIM_HandleTypeDef TimHandle1;
uint32_t uwPrescalerValue = 0;
/* Private function prototypes -----------------------------------------------*/
static void BSP_Config(void);
void BSP_Pointer_Update(void);
void BSP_Background(void);
static void SystemClock_Config(void);
static void LED_Thread1(void const *argument);
static void LED_Thread2(void const *argument);
static void Error_Handler(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program
  * @param  None
  * @retval None
int main(void)
  /* STM32F4xx HAL library initialization:
       - Configure the Flash prefetch, instruction and Data caches
       - Configure the Systick to generate an interrupt each 1 msec
       - Set NVIC Group Priority to 4
       - Global MSP (MCU Support Package) initialization
  HAL_Init();
  /* Configure the system clock to 180 MHz */
  SystemClock_Config();
  /* Initialize LCD and LEDs */
  BSP_Config();
   /* Compute the prescaler value to have TIM3 counter clock equal to 10 KHz */
  uwPrescalerValue = (uint32_t) ((SystemCoreClock /2) / 10000) - 1;
  /* Set TIMx instance */
  TimHandle1.Instance = TIM3;
  /* Initialize TIM3 peripheral as follows:
       + Period = 500 - 1
       + Prescaler = ((SystemCoreClock/2)/10000) - 1
       + ClockDivision = 0
       + Counter direction = Up
  TimHandle1.Init.Period = 500 - 1;
  TimHandle1.Init.Prescaler = uwPrescalerValue;
  TimHandle1.Init.ClockDivision = 0;
  TimHandle1.Init.CounterMode = TIM_COUNTERMODE_UP;
  if(HAL_TIM_Base_Init(&TimHandle1) != HAL_OK)
    while(1)
  /*##-2- Start the TIM Base generation in interrupt mode ####################*/
  /* Start Channel1 */
  if(HAL_TIM_Base_Start_IT(&TimHandle1) != HAL_OK)
    while(1)
  /* Thread 1 definition */
  osThreadDef(LED1, LED_Thread1, osPriorityNormal, 0, configMINIMAL_STACK_SIZE);
   /*  Thread 2 definition */
  osThreadDef(LED3, LED_Thread2, osPriorityNormal, 0, configMINIMAL_STACK_SIZE);
  /* Start thread 1 */
  LEDThread1Handle = osThreadCreate (osThread(LED1), NULL);
  /* Start thread 2 */
  LEDThread2Handle = osThreadCreate (osThread(LED3), NULL);
  /* Start scheduler */
  osKernelStart();
  for(;;);
  * @brief TIM MSP Initialization
  *        This function configures the hardware resources used in this application:
  *           - Peripheral's clock enable
  *           - Peripheral's GPIO Configuration
  * @param htim: TIM handle pointer
  * @retval None
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef *htim)
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* TIMx Peripheral clock enable */
  __HAL_RCC_TIM3_CLK_ENABLE();
  /*##-2- Configure the NVIC for TIMx #########################################*/
  /* Set the TIMx priority */
  HAL_NVIC_SetPriority(TIM3_IRQn, 0, 1);
  /* Enable the TIMx global Interrupt */
  HAL_NVIC_EnableIRQ(TIM3_IRQn);
  * @brief  Initializes the STM32F469I-DISCO's LCD and LEDs resources.
  * @param  None
  * @retval None
  /* Initialize STM32F469I-DISCO's LEDs */
  BSP_LED_Init(LED1);
  BSP_LED_Init(LED2);
  BSP_LED_Init(LED3);
  BSP_LED_Init(LED4);
    /* Initializes the SDRAM device */
  BSP_SDRAM_Init();
  /* Initialize the Touch screen */
  BSP_TS_Init (800, 480);
  /* Enable the CRC Module */
  __HAL_RCC_CRC_CLK_ENABLE();
  * @brief  BSP_Background.
  * @param  None
  * @retval None
   /* toggle LED1 each 100ms */
  BSP_LED_Toggle(LED1);
  /* Capture input event and update cursor */
  if(GUI_IsInitialized() == 1)
    BSP_Pointer_Update();
  * @brief  Provide the GUI with current state of the touch screen
  * @param  None
  * @retval None
  static GUI_PID_STATE TS_State = {0, 0, 0, 0};
  __IO TS_StateTypeDef  ts;
  uint16_t xDiff, yDiff;
  BSP_TS_GetState((TS_StateTypeDef *)&ts);
  if((ts.touchX[0] >= LCD_GetXSize()) ||(ts.touchY[0] >= LCD_GetYSize()) )
    ts.touchX[0] = 0;
    ts.touchY[0] = 0;
  xDiff = (TS_State.x > ts.touchX[0]) ? (TS_State.x - ts.touchX[0]) : (ts.touchX[0] - TS_State.x);
  yDiff = (TS_State.y > ts.touchY[0]) ? (TS_State.y - ts.touchY[0]) : (ts.touchY[0] - TS_State.y);
  if((TS_State.Pressed != ts.touchDetected ) ||
     (xDiff > 20 )||
       (yDiff > 20))
    TS_State.Pressed = ts.touchDetected;
    TS_State.Layer = 0;
    if(ts.touchDetected)
      TS_State.x = ts.touchX[0];
      if(ts.touchY[0] < 240)
        TS_State.y = ts.touchY[0] ;
        TS_State.y = (ts.touchY[0] * 480) / 450;
      GUI_TOUCH_StoreStateEx(&TS_State);
      TS_State.x = 0;
      TS_State.y = 0;
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  while(1)
    /* Insert a delay */
    HAL_Delay(50);
  * @brief  System Clock Configuration
  *         The system Clock is configured as follow :
  *            System Clock source            = PLL (HSE)
  *            SYSCLK(Hz)                     = 180000000
  *            HCLK(Hz)                       = 180000000
  *            AHB Prescaler                  = 1
  *            APB1 Prescaler                 = 4
  *            APB2 Prescaler                 = 2
  *            HSE Frequency(Hz)              = 8000000
  *            PLL_M                          = 8
  *            PLL_N                          = 360
  *            PLL_P                          = 2
  *            PLL_Q                          = 7
  *            PLL_R                          = 6
  *            VDD(V)                         = 3.3
  *            Main regulator output voltage  = Scale1 mode
  *            Flash Latency(WS)              = 5
  * @param  None
  * @retval None
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  HAL_StatusTypeDef ret = HAL_OK;
  /* Enable Power Control clock */
  __HAL_RCC_PWR_CLK_ENABLE();
  /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.  */
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /* Enable HSE Oscillator and activate PLL with HSE as source */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
#if defined(USE_STM32469I_DISCO_REVA)
  RCC_OscInitStruct.PLL.PLLM = 25;
#else
  RCC_OscInitStruct.PLL.PLLM = 8;
#endif /* USE_STM32469I_DISCO_REVA */
  RCC_OscInitStruct.PLL.PLLN = 360;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  RCC_OscInitStruct.PLL.PLLR = 6;
  ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
  if(ret != HAL_OK)
    Error_Handler();
  /* activate the OverDrive to reach the 180 Mhz Frequency */
  ret = HAL_PWREx_EnableOverDrive();
  if(ret != HAL_OK)
    Error_Handler();
  /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
  clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
  if(ret != HAL_OK)
    Error_Handler();
  * @brief  Toggle LED1 and LED4 thread
  * @param  thread not used
  * @retval None
  (void) argument;
  /* Init the STemWin GUI Library */
  BSP_SDRAM_Init(); /* Initializes the SDRAM device */
  __HAL_RCC_CRC_CLK_ENABLE(); /* Enable the CRC Module */
  BSP_Config();
  RTC_Init();
  /* Activate the use of memory device feature */
  MainTask();
  for(;;);
  * @brief  Toggle LED3 thread
  * @param  argument not used
  * @retval None
  (void) argument;
  for(;;)
      BSP_LED_Toggle(LED3);
      osDelay(500);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
发表于 2017-9-21 01:47:59 | 显示全部楼层
先加大任务栈,emWin任务的任务栈搞个5KB看看。
GMT+8, 2026-11-24 15:37 , Processed in 1.588694 second(s), 30 queries .
