查看: 3298|回复: 9
请教下,播放flac音乐时,屏幕有干扰,是怎么回事啊 ?
发表于 2017-9-19 20:05:38 | 显示全部楼层 |阅读模式
刚开始时貌似有地方卡住了的感觉,会发出卡卡卡的使用,但是过一会就好了,声音就正常播放了,只是屏幕有干扰发生,不知道是怎么情况 ???
播放部分代码如下:
int flac_play_song(char* path)
  FLACContext fc;
  int fd;
  int n;
  int bytesleft;
  int consumed;
  char tmp[20];
  static volatile int8_t i;
  unsigned char *filebuf;
  unsigned short *temp_buffer;
  char value=0;
  uint8_t res;
  int16_t *PCM_buffer0=0;
  int16_t *PCM_buffer1=0;
  uint8_t *p8;
  UINT br;
  u32 flac_fptr=0;
  char PlayAddr[100] = {0};
  strcpy(PlayAddr, (const char *)path);
  audiodev.file = (FIL*)mymalloc(SRAMDTCM,sizeof(FIL));
  res=f_open(audiodev.file,(char*)PlayAddr,FA_READ); //读取文件错误
  if(res!=FR_OK)
    myfree(SRAMDTCM, audiodev.file);
    return 0xff;
  flacctrl      = mymalloc(SRAMDTCM,sizeof(__flacctrl));
  /* Read the metadata and position the file pointer at the start of the
   first audio frame */
  flac_init(audiodev.file,  flacctrl,  &fc);
    dump_headers(&fc);
    f_lseek (audiodev.file , audiodev.file->fptr);
    printf("波特率:%dKbps\n\r\n",fc.bitrate);
    printf("采样率:%d\n\r\n",fc.samplerate);
    if (fc.length/1000%60>=10)
    printf("总时间:%d:%d\n\r\n",fc.length/1000/60, fc.length/1000%60);
    printf(tmp,"总时间:%d:0%d\n\r\n",fc.length/1000/60, fc.length/1000%60);
    printf("块大小:%d\n\r\n",fc.max_blocksize);
    PCM_buffer0 = (int16_t *)mymalloc(SRAMEX,MAX_BLOCKSIZE * MAX_CHANNELS * 2);
    PCM_buffer1 = (int16_t *)mymalloc(SRAMEX,MAX_BLOCKSIZE * MAX_CHANNELS * 2);
    filebuf = (uint8_t *)mymalloc(SRAMEX,MAX_FRAMESIZE * 2);    //内存分配.
    if (filebuf==NULL)
        printf("\n\r no mem!!\n\r\n");
        goto fail;
    temp_buffer= (unsigned short *)mymalloc(SRAMEX,MAX_FRAMESIZE * MAX_CHANNELS * 2);    //内存分配.
    if((fc.min_blocksize != fc.max_blocksize) || (fc.max_blocksize > MAX_BLOCKSIZE ) || (fc.max_framesize > MAX_FRAMESIZE))
        printf("\n\rOo Do not support this file!!\n\r\n");
        printf("You can choose another Converter.Such as foobar2000 ^_^\n\r\n");
        goto fail;
    audiodev.i2sbuf1 = (uint8_t *)PCM_buffer0;
    audiodev.i2sbuf2 = (uint8_t *)PCM_buffer1;
    FLAC_Stop();
    FLAC_EnterPlayMode();    //进入播放模式
    FLAC_SaiConfInit(flacctrl->bps, flacctrl->samplerate, flacctrl->outsamples);
    __LTDC_drv->LTDC_DispStringAt(5, 375, LCD_COLOR_BLUE,               //显示当前播放的 .wav文件名字
                              LCD_COLOR_WHITE,
                              &FontAscii8x16,
                              (const uint8_t *)PlayAddr);
        f_read(audiodev.file,filebuf,MAX_FRAMESIZE,&br);//读取最大帧长数据
        bytesleft = br;
        flac_fptr = audiodev.file->fptr;    //记录当前的文件位置.
    FLAC_Start();                    //开始播放
    while (bytesleft)
      while(audiodev.AudioTransferEnd==0)//等待传输完成
      audiodev.AudioTransferEnd=0;
            if(audiodev.AudioSwitchBuf == 0)
        p8 = audiodev.i2sbuf1;
        p8 = audiodev.i2sbuf2;
      fc.decoded0 = (int32_t *)p8;
      fc.decoded1 = (int32_t *)temp_buffer;
       flac_decode_frame(&fc,filebuf,bytesleft,(int16_t *)p8);
        consumed=fc.gb.index/8;
        rt_memmove(filebuf,&filebuf[consumed],bytesleft-consumed);
        bytesleft-=consumed;
        f_read(audiodev.file, &filebuf[bytesleft],MAX_FRAMESIZE-bytesleft, &br);
        if (br > 0)
            bytesleft+=br;
        flac_fptr=audiodev.file->fptr;    //记录当前的文件位置.
        while(audiodev.status&(1<<1))    //正常播放中
          FLAC_MsgShow(audiodev.file); //得到总时间和当前播放的时间
          audiodev.totsec=flacctrl->totsec;        //参数传递
          audiodev.cursec=flacctrl->cursec;
          audiodev.bitrate=flacctrl->bitrate;
          audiodev.samplerate=flacctrl->samplerate;
          audiodev.bps=flacctrl->bps;
            if(audiodev.status&0X01)break;    //没有按下暂停
        //    else
        //    HAL_Delay(5);    // delay_ms(1000/OS_TICKS_PER_SEC);
        if((audiodev.status&(1<<1))==0)        //请求结束播放/播放完成
fail:
     Getmemtablestatus(); //获取内存块状态
   f_close(audiodev.file);
   myfree(SRAMDTCM,audiodev.file);
   myfree(SRAMDTCM,flacctrl);
        myfree(SRAMEX,PCM_buffer0);
      myfree(SRAMEX,PCM_buffer1);
      myfree(SRAMEX,filebuf);
        myfree(SRAMEX,temp_buffer);
    return value;
发表于 2017-9-20 00:38:33 | 显示全部楼层
这个不太清楚哦,做这种音乐播放的时候,特别注意框架设计,框架设计的好,随意倒腾都不会有问题。
可以参考我搞的MP3的:https://forum.anfulai.cn/forum.p ... 687&fpage=4
 楼主| 发表于 2017-9-21 09:13:06 | 显示全部楼层
eric2013:这个不太清楚哦,做这种音乐播放的时候,特别注意框架设计,框架设计的好,随意倒腾都不会有问题。
可以参考我搞的MP3的:https://forum.anfulai.cn/forum.p ... 687&fpage=4 (2017-09-20 00:38)
多谢多谢,我去看看
 楼主| 发表于 2017-9-25 22:34:58 | 显示全部楼层
按照你的历程修改了,结果也还是一样的啊,
具体效果你可以看看这个视频
http://v.youku.com/v_show/id_XMz ... j.8428770.3416059.1
播放其他的 wav, mp3 都是完全没有任何问题的,而且只要不播放 flac ,显示完全正常
发表于 2017-9-26 10:33:36 | 显示全部楼层
回 hpdell 的帖子
hpdell:按照你的历程修改了,结果也还是一样的啊,
具体效果你可以看看这个视频
....... (2017-09-25 22:34)
参考这个,群友在我们的例子基础上添加的FLAC和APE
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=26163
 楼主| 发表于 2017-9-26 22:02:58 | 显示全部楼层
eric2013:参考这个,群友在我们的例子基础上添加的FLAC和APE
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=26163 (2017-09-26 10:33)
你好,我刚刚把 优化基本设置为最高貌似就可以了,
播放 flac 的文件屏幕不闪,但是 播放完后不能够播放其他 类型的 音乐文件了,
我的编译器使用的 是  iar
这个问题是不是说明 这个 flac 的库文件有些指针写的不支持 iar 编译器啊 ?
或者是需要修改哪里 ??
发表于 2017-9-28 08:49:04 | 显示全部楼层
回 hpdell 的帖子
hpdell:你好,我刚刚把 优化基本设置为最高貌似就可以了,
....... (2017-09-26 22:02)
这个应该是你的程序问题了。音频的切换设计有问题。
 楼主| 发表于 2017-9-28 12:31:08 | 显示全部楼层
eric2013:这个应该是你的程序问题了。音频的切换设计有问题。
 (2017-09-28 08:49)
我使用移植 keil 里面的工程 到 iar 上的,估计有可能他们有些地方不兼容造成的,有没有这个可能啊 ??
发表于 2017-9-29 09:19:17 | 显示全部楼层
回 hpdell 的帖子
hpdell:我使用移植 keil 里面的工程 到 iar 上的,估计有可能他们有些地方不兼容造成的,有没有这个可能啊 ??
 (2017-09-28 12:31)
可能有,估计概率比较小些,可以的话,在MDK上面也搞下。
 楼主| 发表于 2017-10-4 21:56:36 | 显示全部楼层
eric2013:
你好,我在 keil 编译器下测试也还是会出现显示闪烁的情况,但是我使用的 flac 库跟你们的历程库一样啊,
也不知道是怎么个情况 ??
最终的解决方法是 把 优化基本搞到最高就可以了,另外把音频内存都搞成单片机内部的 ram内存了,貌似不能够使用外部的sdram,这个说明什么情况啊 ????
是我的外部 sdram 走线不好 ??
GMT+8, 2026-11-25 11:35 , Processed in 1.322963 second(s), 24 queries .
