查看: 3464|回复: 1
[其它] 英特尔Apollo家族又出新品,Bben MN10电脑棒
发表于 2017-9-1 02:54:41 | 显示全部楼层 |阅读模式
地址
规格:
    [li]SoC – Intel Celeron N3350 dual core processor @ 1.1 GHz / 2.4 GHz, 12 EU Intel HD graphics 500 @ 200 MHz / 650 MHz; 6W TDP[/li][li]System Memory – 3 GB DDR3[/li][li]Storage – 64 GB eMMC flash + micro SD slot up to 128 GB[/li][li]Video Output – HDMI port[/li][li]Audio – HDMI + 3.5mm headphone jack[/li][li]Connectivity – Dual band 802.11 b/g/n/ac WiFi, and Bluetooth 4.0[/li][li]USB – 2x USB 3.0 ports[/li][li]Misc – Fan and ventilation holes,[/li][li]Power Supply – 12V/1.5A via power barrel[/li][li]Dimensions – 110.6 x 45.5 x 13.8 mm[/li][li]Weight – 70 grams[/li]
 楼主| 发表于 2018-4-27 00:18:54 | 显示全部楼层
GMT+8, 2026-11-23 12:50 , Processed in 0.199878 second(s), 27 queries .
