查看: 4276|回复: 4
[uC/TCP-IP] uC/TCP-IP的整体组成框架
发表于 2017-8-31 03:05:09 | 显示全部楼层 |阅读模式
https://www.silabs.com/products/ ... m-tcp-ip-networking
Network Apps supoprted by Micrium's TCP/IP layers
DHCP Clinet
Dynamic Host Configuration Protocol – Client
    [li]Transmit and receive option is supported[/li][li]IPv4 Only[/li]
DNS Client
Domain Name System – Client
    [li]Support IPv4 and IPv6[/li][li]Auto select best address[/li][li]Integrated cache[/li]
FTP Client
File Transfer Protocol – Client
    [li]Support authentication.[/li][li]Transfer via buffers or files (file system required).[/li][li]Support SSL (Secure Sockets Layer)[/li]
HTTP Client
Hypertext Transfer Protocol – Web Client
    [li]Full support for HTTP 1.1 (RFC 2616)[/li][li]All HTTP methods suported (GET, POST, PUT, DELETE, HEAD, OPTIONS, and TRACE)[/li][li]Support for WebSocket[/li][li]Support for persistent connections[/li][li]HTTP header field processing (HTTP cookies)[/li][li]HTTP query string processing[/li][li]Support multiple simultaneous connection with multiple HTTP Server[/li]
HTTP Server
Hypertext Transfer Protocol – Web Server
    [li]Supports multi connection - up to 255 client connections[/li][li]Supports any file system, or can be used via a static file system, which is provided[/li][li]Highly customizable via hook functions[/li][li]Include add-on for advanced functionalities such as Authentication Module and REST Framework[/li]
MQTT Client
MQTT Messaging Protocol - Client
    [li]Supports multiple simultaneous connections with multiple MQTT brokers[/li][li]Support for multiple message in the air simultaneously[/li][li]Unlimited number of connections and messages[/li][li]Support all Qualities of Service (QoS-0, QoS-1 & QoS-2)[/li]
SMTP Client
Simple Mail Transfer Protocol – Client
    [li]Support for SSL/TLS[/li][li]Support Authentication[/li]
SNTP ClientSimple Network Time Protocol – Client
Telnet Server
Telnet – Server
    [li]Integrated with uCOS-Shell[/li][li]Support authentication uCOS-Common[/li][li]Support SSL (Secure Sockets Layer).[/li]
TFTP Client
Trivial File Transfer Protocol – Client
    [li]Transfer and reception via buffers or files (file system required).[/li]
TFTP Server
Trivial File Transfer Protocol – Server
    [li]Support any file system; a file system is required.[/li]
发表于 2017-8-31 10:35:32 | 显示全部楼层
不知道好不好用
 楼主| 发表于 2017-8-31 10:39:12 | 显示全部楼层
回 jcx0324 的帖子
jcx0324:不知道好不好用 (2017-08-31 10:35)
将一个协议栈搞稳定,至少要半年时间的测试,我这里测试RL-TCPnet快1年半了。https://forum.anfulai.cn/forum.php?mod=viewthread&tid=20959
做稳定不容易啊,得把这个协议栈的脾性摸透
发表于 2017-11-21 22:55:21 | 显示全部楼层
eric2013:将一个协议栈搞稳定,至少要半年时间的测试,我这里测试RL-TCPnet快1年半了。https://forum.anfulai.cn/forum.php?mod=viewthread&tid=20959
做稳定不容易啊,得把这个协议栈的脾性摸透 (2017-08-31 10:39)
uctcp  后面搞吗?
 楼主| 发表于 2017-11-22 00:46:36 | 显示全部楼层
回 miaoqiongb 的帖子
miaoqiongb:uctcp  后面搞吗? (2017-11-21 22:55)
暂时应该还不会,下一个会搞LwIP。
GMT+8, 2026-11-25 11:31 , Processed in 0.225185 second(s), 27 queries .
