查看: 9361|回复: 4
[emWin] 按键控制菜单的疑问
发表于 2014-5-29 17:38:54 | 显示全部楼层 |阅读模式
我已经跑了一下官方菜单的例子,自己做了个扫描按键的程序,经测试,按键消息能响应,但是找不到响应按键的回调函数在哪,因为我想改一下程序,实现不同的功能。
发表于 2014-5-29 17:43:06 | 显示全部楼层
你说的是模拟器上面的吧,那个已经被封装了,看不到的。
 楼主| 发表于 2014-5-29 18:22:06 | 显示全部楼层
不是,我用的不是模拟器上的,是官方的例程,那我们还怎么用菜单啊,只是左右上下移动也没用啊
发表于 2014-5-29 18:26:36 | 显示全部楼层
回 worldcui 的帖子
worldcui:不是,我用的不是模拟器上的,是官方的例程,那我们还怎么用菜单啊,只是左右上下移动也没用啊 (2014-05-29 18:22)
官方那个例子,或者你把代码贴上
 楼主| 发表于 2014-5-29 18:34:36 | 显示全部楼层
eric2013:官方那个例子,或者你把代码贴上 (2014-05-29 18:26)
*       Static data
static WM_HWIN _hMenu;
static WM_HWIN _hText;
static WM_HWIN _hFrame;
static char * _paDescription[] = {
  "Creates a new file",
  "Opens an existing file",
  "Closes the file",
  "Quits the application",
  "Opens file 1",
  "Opens file 2",
  "Opens file 3",
  "Opens file 4",
  "Undoes the last action",
  "Redoes the previously undone action",
  "Copies to clipboard",
  "Inserts contents of clipboard",
  "Deletes the selection",
  "Displays program information"
*       Static code
*       _AddMenuItem
static void _AddMenuItem(MENU_Handle hMenu, MENU_Handle hSubmenu, const char* pText, U16 Id, U16 Flags) {
  MENU_ITEM_DATA Item;
  Item.pText    = pText;
  Item.hSubmenu = hSubmenu;
  Item.Flags    = Flags;
  Item.Id       = Id;
  MENU_AddItem(hMenu, &Item);
*       _CreateMenu
* Purpose:
*   Creates the menu widget
static WM_HWIN _CreateMenu(WM_HWIN hParent) {
  MENU_Handle hMenu, hMenuFile, hMenuEdit, hMenuHelp, hMenuRecent;
  // Create main menu
  hMenu       = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_HORIZONTAL, ID_MENU);
  // Create sub menus
  hMenuFile   = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
  hMenuEdit   = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
  hMenuHelp   = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
  hMenuRecent = MENU_CreateEx(0, 0, 0, 0, WM_UNATTACHED, 0, MENU_CF_VERTICAL, 0);
  // Add menu items to menu 'Recent'
  _AddMenuItem(hMenuRecent, 0,           "File 1",   ID_MENU_RECENT_0,    0);
  _AddMenuItem(hMenuRecent, 0,           "File 2",   ID_MENU_RECENT_1,    0);
  _AddMenuItem(hMenuRecent, 0,           "File 3",   ID_MENU_RECENT_2,    0);
  _AddMenuItem(hMenuRecent, 0,           "File 4",   ID_MENU_RECENT_3,    0);
  // Add menu items to menu 'File'
  _AddMenuItem(hMenuFile,   0,           "New",      ID_MENU_FILE_NEW,    0);
  _AddMenuItem(hMenuFile,   0,           "Open",     ID_MENU_FILE_OPEN,   0);
  _AddMenuItem(hMenuFile,   0,           "Close",    ID_MENU_FILE_CLOSE,  MENU_IF_DISABLED);
  _AddMenuItem(hMenuFile,   0,           0,          0,                   MENU_IF_SEPARATOR);
  _AddMenuItem(hMenuFile,   hMenuRecent, "Files...", ID_MENU_FILE_RECENT, 0);
  _AddMenuItem(hMenuFile,   0,           "Exit",     ID_MENU_FILE_EXIT,   0);
  // Add menu items to menu 'Edit'
  _AddMenuItem(hMenuEdit,   0,           "Undo",     ID_MENU_EDIT_UNDO,   0);
  _AddMenuItem(hMenuEdit,   0,           "Redo",     ID_MENU_EDIT_REDO,   0);
  _AddMenuItem(hMenuEdit,   0,           0,          0,                   MENU_IF_SEPARATOR);
  _AddMenuItem(hMenuEdit,   0,           "Copy",     ID_MENU_EDIT_COPY,   0);
  _AddMenuItem(hMenuEdit,   0,           &quotaste",    ID_MENU_EDIT_PASTE,  0);
  _AddMenuItem(hMenuEdit,   0,           "Delete",   ID_MENU_EDIT_DELETE, 0);
  // Add menu items to menu 'Help'
  _AddMenuItem(hMenuHelp,   0,           "About",    ID_MENU_HELP_ABOUT,  0);
  // Add menu items to main menu
  _AddMenuItem(hMenu,       hMenuFile,   "File",     0,                   0);
  _AddMenuItem(hMenu,       hMenuEdit,   "Edit",     0,                   0);
  _AddMenuItem(hMenu,       hMenuHelp,   "Help",     0,                   0);
  // Attach menu to parent window
  FRAMEWIN_AddMenu(hParent, hMenu);
  return hMenu;
*       _DrawGradientV
* Purpose:
*   Draws a vertical gradient
static void _DrawGradientV(int x0, int y0, int x1, int y1, GUI_COLOR Color0, GUI_COLOR Color1) {
  int r0, g0, b0, r1, g1, b1;
  int y, ySize;
  ySize = y1 - y0 + 1;
  r0 = (Color0 >>  0) & 0x000000ff;
  g0 = (Color0 >>  8) & 0x000000ff;
  b0 = (Color0 >> 16) & 0x000000ff;
  r1 = (Color1 >>  0) & 0x000000ff;
  g1 = (Color1 >>  8) & 0x000000ff;
  b1 = (Color1 >> 16) & 0x000000ff;
  for (y = y0; y <= y1; y++) {
    GUI_COLOR Color;
    int r, g, b, Diff;
    Diff = y - y0;
    r = r0 + (r1 - r0) * Diff / ySize;
    g = g0 + (g1 - g0) * Diff / ySize;
    b = b0 + (b1 - b0) * Diff / ySize;
    Color = r | (g << 8) | (b << 16);
    GUI_SetColor(Color);
    GUI_DrawHLine(y, x0, x1);
*       _MessageBox
* Purpose:
*   Creates and executes a modal message box
static void _MessageBox(const char * pText, const char * pCaption) {
  WM_HWIN hBox;
  hBox = MESSAGEBOX_Create(pText, pCaption, GUI_MESSAGEBOX_CF_MODAL | GUI_MESSAGEBOX_CF_MOVEABLE);
  WM_SetStayOnTop(hBox, 1);
  WM_BringToTop(hBox);
  GUI_ExecCreatedDialog(hBox);
  WM_SetFocus(_hMenu);
  MENU_SetSel(_hMenu, -1);
*       _cbClient
* Purpose:
*   Callback routine of client window which 'owns' the menu widget
*   and the status bar
static void _cbClient(WM_MESSAGE * pMsg) {
  char acBuffer[50];
  int Index, xSize, ySize, xPos, yPos;
  WM_HWIN hWin, hClient;
  MENU_MSG_DATA * pData;
  MENU_ITEM_DATA Data;
  hWin = pMsg->hWin;
  hClient = WM_GetClientWindow(hWin);
  xSize = WM_GetWindowSizeX(hClient);
  ySize = WM_GetWindowSizeY(hClient);
  switch (pMsg->MsgId) {
  case WM_SIZE:
    // Adjusts text widget on changinmg the size
    xPos = WM_GetWindowOrgX(hClient);
    yPos = WM_GetWindowOrgY(hClient);
    WM_SetWindowPos(_hText, xPos + 4, yPos + ySize - 10, xSize, 10);
    WM_SetWindowPos(_hMenu, xPos    , yPos             , xSize, WM_GetWindowSizeY(_hMenu));
    TEXT_SetText(_hText, "Ready");
  case WM_PAINT:
    // Draws the background of the client window
    _DrawGradientV(0, 0, xSize - 1, ySize - 12 - 1, GUI_WHITE, GUI_LIGHTBLUE);
    GUI_SetColor(GUI_LIGHTGRAY);
    GUI_FillRect(0, ySize - 12, xSize - 1, ySize - 1);
    GUI_SetTextMode(GUI_TM_TRANS);
    GUI_SetColor(GUI_BLACK);
    GUI_SetFont(&GUI_Font24B_ASCII);
    GUI_DispStringHCenterAt(
      "Welcome"
      , xSize / 2, 20);
    GUI_SetFont(&GUI_Font16B_ASCII);
      "sia\\n"
      "2014\\n"
      "5\\n"
      "29\\n"
      , xSize / 2, 70);
  case WM_MENU:
    pData = (MENU_MSG_DATA*)pMsg->Data.p;
    switch (pData->MsgType) {
    case MENU_ON_ITEMPRESSED:
      // This message is send regardless of the item state is disabled or not
      MENU_GetItem(pMsg->hWinSrc, pData->ItemId, &Data);
      if (Data.Flags & MENU_IF_DISABLED) {
        _MessageBox("The pressed item was disabled", "Message");
    case MENU_ON_ITEMACTIVATE:
      // This message is send on highlighting a menu item
      Index = pData->ItemId - ID_MENU_FILE_NEW;
      if (Index >= 0) {
        TEXT_SetText(_hText, _paDescription[pData->ItemId - ID_MENU_FILE_NEW]);
      } else {
    case MENU_ON_ITEMSELECT:
      // This message is send only if an enabled item has been selected
      sprintf(acBuffer, "ID of the selected\\nitem is 0x%X", pData->ItemId);
      _MessageBox(acBuffer, "Message");
  WM_DefaultProc(pMsg);
*       Public code
*       MainTask
void MainTask(void) {
  int xSize, ySize;
  WM_HWIN hClient;
#if GUI_SUPPORT_MEMDEV
    WM_EnableMemdev(WM_HBKWIN);
  #endif
  WM_SetDesktopColor(GUI_BLACK);
  MENU_SetDefaultEffect(&WIDGET_Effect_3D1L);
  // Create frame window
  _hFrame = FRAMEWIN_CreateEx(0, 0, 240, 320, WM_HBKWIN, WM_CF_SHOW, FRAMEWIN_CF_MOVEABLE, 0, "Main Menu", _cbClient);
  FRAMEWIN_SetFont(_hFrame, &GUI_Font13_ASCII);
  FRAMEWIN_AddMaxButton(_hFrame, FRAMEWIN_BUTTON_RIGHT, 0);
  FRAMEWIN_AddMinButton(_hFrame, FRAMEWIN_BUTTON_RIGHT, 2);
  // Create menu widget
  _hMenu = _CreateMenu(_hFrame);
  // Create text widget as simple status bar
  hClient = WM_GetClientWindow(_hFrame);
  _hText = TEXT_CreateEx(4, ySize - 10, xSize, 10, hClient, WM_CF_SHOW, 0, GUI_ID_TEXT0, "Ready");
  TEXT_SetFont(_hText, &GUI_Font8_ASCII);
  // Set keyboard focus to menu widget
  //while (1) {
  //  GUI_Delay(100);
GMT+8, 2026-11-23 06:09 , Processed in 1.277609 second(s), 24 queries .
