查看: 6058|回复: 1
[有问必答] 用v3板读max6675芯片转换数据的时候遇到点问题
发表于 2014-5-17 13:21:06 | 显示全部楼层 |阅读模式
除了芯片的vcc和GND之外,把cs也接地了(低电平选中)。把时钟接在了pb6,miso接到了pb5(引脚上串的电阻已经拿掉了)。虚拟spi来读数据。程序如下
#include "stm32f10x_it.h"
#include "max6675.h"
void max6675_Init(void)
    /* 打开GPIOB的时钟 */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO , ENABLE);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 ;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_5 ;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
void delay(unsigned int ms)
    unsigned int i,j;
    for(i=0;i<ms;i++)
        for(j=0;j<39;j++);
uint16_t read(void )
    uint16_t  wendu=0;
    int i;
    max6675_Init();
    for(i=0;i<16;i++)
        GPIO_SetBits(GPIOB,GPIO_Pin_6);  //  SCK=1
        delay(1);
        GPIO_ResetBits(GPIOB,GPIO_Pin_6);      //SCK=0
        delay(1);
        if (GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_5) == Bit_SET)     //1
            wendu=wendu|0x0001;
        wendu=wendu<<1;
     wendu=wendu>>3;
     return wendu;
照理6675接k型热电偶应该是很灵敏的,但是手摸上去示数完全不变,反而剧烈晃动的时候示数变化很大,完全不明白什么原因,本来还以为热电偶换了,重新买了一套还是这个样子
发表于 2014-5-17 14:56:16 | 显示全部楼层
最好用硬件SPI,使用软件方式做为片选,V3板子上这两个用来接SPI FLASH和触摸
GMT+8, 2026-11-22 13:04 , Processed in 0.786645 second(s), 30 queries .
