查看: 3680|回复: 2
[FreeRTOS] PendSV_Handler里有一句不懂,求解。
发表于 2017-8-6 02:21:37 | 显示全部楼层 |阅读模式
__asm void xPortPendSVHandler( void )
        extern uxCriticalNesting;
        extern pxCurrentTCB;
        extern vTaskSwitchContext;
        PRESERVE8
        mrs r0, psp
        isb
        /* Get the location of the current TCB. */
        ldr        r3, =pxCurrentTCB
        ldr        r2, [r3]
        /* Is the task using the FPU context?  If so, push high vfp registers. */
        tst r14, #0x10
        it eq
        vstmdbeq r0!, {s16-s31}
        /* Save the core registers. */
        stmdb r0!, {r4-r11, r14}
        /* Save the new top of stack into the first member of the TCB. */
        str r0, [r2]
        stmdb sp!, {r3}
        mov r0, #configMAX_SYSCALL_INTERRUPT_PRIORITY
        msr basepri, r0
        dsb
        isb
        bl vTaskSwitchContext
        mov r0, #0
        msr basepri, r0
        ldmia sp!, {r3}
        /* The first item in pxCurrentTCB is the task top of stack. */
        ldr r1, [r3]
        ldr r0, [r1]
        /* Pop the core registers. */
        ldmia r0!, {r4-r11, r14}
        /* Is the task using the FPU context?  If so, pop the high vfp registers
        too. */
        tst r14, #0x10
        it eq
        vldmiaeq r0!, {s16-s31}
        msr psp, r0
        isb
        #ifdef WORKAROUND_PMU_CM001 /* XMC4000 specific errata */
                #if WORKAROUND_PMU_CM001 == 1
                        push { r14 }
                        pop { pc }
                        nop
                #endif
        #endif
        bx r14
stmdb sp!, {r3}   //请问这句保存r3为什么要用sp?
我知道异常里用的是主栈指针msp,但是这里压栈时用的是sp,是不是说明sp缺省时等于msp?
发表于 2017-8-6 02:57:58 | 显示全部楼层
就是下面这个图,SP栈指针只有一个寄存器,如果用SP的话,当前用的是那个,SP就是表示那个。
 楼主| 发表于 2017-8-6 17:21:25 | 显示全部楼层
好的,多谢指点!
GMT+8, 2026-11-24 15:36 , Processed in 1.090849 second(s), 33 queries .
