查看: 3894|回复: 12
[emWin] 求助:裸跑,WM_Exec()后卡住
发表于 2017-6-7 13:05:45 | 显示全部楼层 |阅读模式
初学STemWIN,用GUIBuilder4.0做了个对话框,里面只有一个按钮,在系统下,执行WM_Exec(),后面的程序正常运行;到了裸跑时执行WM_Exec(),能显示出正确窗口,但是程序就此卡住,后面的都不执行了。哪位大神遇到过这事?
发表于 2017-6-7 13:07:41 | 显示全部楼层
方便的话,看下你的代码。
 楼主| 发表于 2017-6-7 13:10:55 | 显示全部楼层
#include "system.h"
#include "SysTick.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "beep.h"
#include "lcd_driver.h"
#include "touch.h"
#include "timer.h"
#include "flash.h"
#include "sram.h"
#include "malloc.h"
#include "GUI.h"
#include "WM.h"
#include "GUIDemo.h"
#include "FramewinDLG.h"
#include "FramewinDLG2.h"
ErrorStatus  HSEStartUpStatus;
int main()
    Systick_Init(72);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    USART1_Init(9600);
    TFTLCD_Init();            //LCD初始化
    KEY_Init();                 //按键初始化
    BEEP_Init();            //初始化蜂鸣器
    FSMC_SRAM_Init();        //初始化SRAM
    my_mem_init(SRAMIN);     //初始化内部内存池
    my_mem_init(SRAMEX);      //初始化外部内存池
    FLASH_Init();
    TOUCH_Init();                //触摸屏初始化
    TIM3_Int_Init(999,71);    //1KHZ 定时器1ms
    TIM6_Int_Init(999,719);    //10ms中断
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC,ENABLE);//使能CRC时钟,否则STemWin不能使用
    LED_Init();
    GPIO_ResetBits(GPIOC,GPIO_Pin_1);
    GUI_Init();
    CreateFramewin();
    GPIO_SetBits(GPIOC, GPIO_Pin_0);
    while(1)
        delay_ms(2000);
        GPIO_SetBits(GPIOC, GPIO_Pin_1);
        delay_ms(2000);
        GPIO_ResetBits(GPIOC, GPIO_Pin_1);
 楼主| 发表于 2017-6-7 13:12:09 | 显示全部楼层
CreateFramewin();
GUI_Exec();  //加上这句之后就会卡住,GPIOC-1接的灯就不闪了
 楼主| 发表于 2017-6-7 13:14:46 | 显示全部楼层
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
*       Defines
#define ID_FRAMEWIN_0     (GUI_ID_USER + 0x00)
#define ID_BUTTON_0     (GUI_ID_USER + 0x01)
#define ID_EDIT_0     (GUI_ID_USER + 0x02)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
  { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, -2, 450, 320, 0, 0x0, 0 },
  { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 180, 187, 80, 20, 0, 0x0, 0 },
  { EDIT_CreateIndirect, "Edit", ID_EDIT_0, 182, 87, 80, 20, 0, 0x64, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Edit'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
    EDIT_SetText(hItem, "123");
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
  case WM_NOTIFY_PARENT:
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_BUTTON_0: // Notifications sent by 'Button'
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        // USER END
        // USER END
      // USER END
    case ID_EDIT_0: // Notifications sent by 'Edit'
      switch(NCode) {
        // USER END
        // USER END
      case WM_NOTIFICATION_VALUE_CHANGED:
        // USER END
      // USER END
    // USER START (Optionally insert additional code for further Ids)
    // USER END
  // USER START (Optionally insert additional message handling)
  // USER END
  default:
    WM_DefaultProc(pMsg);
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin(void);
WM_HWIN CreateFramewin(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
// USER START (Optionally insert additional public code)
// USER END
 楼主| 发表于 2017-6-7 13:15:28 | 显示全部楼层
这个文件是GUI_Builder保存的,没改过
发表于 2017-6-7 13:17:54 | 显示全部楼层
回 freefishzyq 的帖子
freefishzyq:CreateFramewin();
 (2017-06-07 13:12)
初始化之后先显示个背景色,显示个文本,看看能够显示出来不。
 楼主| 发表于 2017-6-7 13:20:43 | 显示全部楼层
    GUI_Init();
    FRONT_COLOR=RED;
    LCD_ShowString(10,10,tftlcd_data.width,tftlcd_data.height,16,"STemWin Base Project!");
    //CreateFramewin();
    //GUI_Exec();
    while(1)
        delay_ms(2000);
        delay_ms(2000);
完全正常,可以显示,灯也闪
发表于 2017-6-7 13:23:38 | 显示全部楼层
回 freefishzyq 的帖子
freefishzyq:GPIO_ResetBits(GPIOC,GPIO_Pin_1);
    GUI_Init();
....... (2017-06-07 13:20)
不是这个函数LCD_ShowString。
是emWin自己的API函数,用emWin自己的API函数试试,刷个屏,显示个字符。
 楼主| 发表于 2017-6-7 13:26:37 | 显示全部楼层
GUI_Init();
    GUI_SetBkColor(GUI_BLUE);
    GUI_Clear();
    GUI_SetFont(&GUI_Font24_ASCII);
    GUI_SetColor(GUI_YELLOW);
    GUI_DispString("Hello World!\\n");
    //FRONT_COLOR=RED;
    //LCD_ShowString(10,10,tftlcd_data.width,tftlcd_data.height,16,"STemWin Base Project!");
    //CreateFramewin();
    //GUI_Exec();
    while(1)
        delay_ms(2000);
        delay_ms(2000);
完全正常,刷成蓝屏,黄字显示。灯闪正常
这时候加上GUI_Exec(); 不会卡住,灯闪
发表于 2017-6-7 13:41:45 | 显示全部楼层
回 freefishzyq 的帖子
freefishzyq:GUI_Init();
....... (2017-06-07 13:26)
这么神奇,你的GUI_X.C文件里面做了emWin的时间基准更新了没有。
另外就是调整状态跟踪下代码,使用窗口的话要使用16bpp的底层函数,如果你用的通用移植方法,这个bug非常好找,如果是官方自带的要麻烦些。
主要就是这两个问题了,别的没什么问题了。
 楼主| 发表于 2017-6-7 13:45:40 | 显示全部楼层
[s:143] 谢谢。我找找看
发表于 2017-6-8 02:27:16 | 显示全部楼层
回 freefishzyq 的帖子
freefishzyq:[s:143] 谢谢。我找找看 (2017-06-07 13:45)
[s:130]
GMT+8, 2026-11-23 09:56 , Processed in 1.430204 second(s), 24 queries .
