查看: 3871|回复: 0
[μCOS-III] Micrium发布新一期博文,11个你可能不知道的情况---纪念uCOS内核25周年庆
发表于 2017-6-7 02:00:04 | 显示全部楼层 |阅读模式
官方地址:
https://www.micrium.com/11-myths-about-ucos/
http://www.electronicdesign.com/ ... /11-myths-about-cos
μC/OS (1992), μC/OS-II (1998), and μC/OS-III (2008)
注意,下面有些题目是假命题:
1. The μC/OS kernels were community-developed.
2. The μC/OS kernel was based on other kernels.
3. μC/OS is a real-time kernel, not an RTOS.
4. μC/OS is limited to 64 tasks.
5. An RTOS requires a memory management unit (MMU).
6. The μC/OS-xx kernels are free and just for hobbyists, not professionals.
7. The μC/OS-III books are user guides.
8. The μC/OS kernels are not popular.
9. The μC/OS kernels were the first kernels ported to many ARM CPUs.
10. The code for the μC/OS kernels isn’t very clean, and the kernels are hard to use.
11. Micrium is abandoning μC/OS-II and μC/OS-III and will only support Silicon Labs chips.
GMT+8, 2026-11-23 09:55 , Processed in 0.895447 second(s), 24 queries .
