查看: 3545|回复: 1
[网络知识] 所有互联网协议收录文件RFC
发表于 2017-4-4 14:44:00 | 显示全部楼层 |阅读模式
 楼主| 发表于 2019-11-4 14:12:28 | 显示全部楼层
List of RFCs that are covered by the Network Component. More...
A Request for Comments (RFC) is a document from the Internet Engineering Task Force (IETF) and the Internet Society, the main technical development and standards-setting bodies for the Internet. RFCs are official documents of Internet specifications, communications protocols, procedures, and events. The following RFCs are currently implemented in the Network Component v7:
RFC
Title
RFC768
User Datagram Protocol (UDP)
RFC791
Internet Protocol (IPv4)
RFC792
Internet Control Message Protocol (ICMP)
RFC793
Transmission Control Protocol (TCP)
RFC815
IP Datagram Reassembly Algorithms
RFC821
Simple Mail Transfer Protocol (SMTP)
RFC826
An Ethernet Address Resolution Protocol (ARP)
RFC854
Telnet Protocol Specification
RFC855
Telnet Option Specifications
RFC857
Telnet Echo Option
RFC858
Telnet Suppress Go Ahead Option
RFC894
A Standard for the Transmission of IP Datagrams over Ethernet
RFC951
Bootstrap Protocol (BOOTP)
RFC959
File Transfer Protocol (FTP)
RFC1001
Protocol Standard for a NetBIOS Service on a TCP/UDP Transport: Concepts and Methods
RFC1002
Protocol Standard for a NetBIOS Service on a TCP/UDP Transport: Detailed Specifications
RFC1034
Domain Names - Concepts and Facilities (DNS)
RFC1035
Domain Names - Implementation and Specification
RFC1042
Standard for the transmission of IP datagrams over IEEE 802 networks
RFC1055
A Nonstandard for Transmission of IP Datagrams over Serial Lines (SLIP)
RFC1101
Encoding of Network Names and Other Types
RFC1112
Host Extensions for IP Multicasting (IGMP)
RFC1122
Requirements for Internet Hosts - Communication Layers
RFC1123
Requirements for Internet Hosts - Application and Support
RFC1155
Structure and Identification of Management Information for TCP/IP-based Internets
RFC1156
Management Information Base for Network Management of TCP/IP-based internets
RFC1157
A Simple Network Management Protocol (SNMP))
RFC1321
The MD5 Message-Digest Algorithm
RFC1332
The PPP Internet Protocol Control Protocol (IPCP)
RFC1334
PPP Authentication Protocols (PAP, CHAP)
RFC1350
The TFTP Protocol (Revision 2)
RFC1542
Clarifications and Extensions for BOOTP
RFC1661
The Point-to-Point Protocol (PPP)
RFC1662
PPP in HDLC-like Framing
RFC1700
Assigned Numbers
RFC1769
Simple Network Time Protocol (SNTP)
RFC1867
Form-based File Upload in HTML
RFC1869
SMTP Service Extensions
RFC1877
PPP Internet Protocol Control Protocol Extensions for Name Server Addresses
RFC2045
Multipurpose Internet Mail Extensions (MIME) Part One: Format of Internet Message Bodies
RFC2046
Multipurpose Internet Mail Extensions (MIME) Part Two: Media Types
RFC2047
Multipurpose Internet Mail Extensions (MIME) Part Three: Message Header Extensions for Non-ASCII Text
RFC2104
HMAC: Keyed-Hashing for Message Authentication
RFC2113
IP Router Alert Option
RFC2131
Dynamic Host Configuration Protocol (DHCP)
RFC2132
DHCP Options and BOOTP Vendor Extensions
RFC2181
Clarifications to the DNS Specification
RFC2195
IMAP/POP AUTHorize Extension for Simple Challenge/Response
RFC2236
Internet Group Management Protocol, Version 2 (IGMPv2)
RFC2292
Advanced Sockets API for IPv6
RFC2347
TFTP Option Extension
RFC2348
TFTP Blocksize Option
RFC2390
Inverse Address Resolution Protocol (InARP)
RFC2428
FTP Extensions for IPv6 and NATs
RFC2460
Internet Protocol, Version 6 (IPv6) Specification
RFC2464
Transmission of IPv6 Packets over Ethernet Networks
RFC2554
SMTP Service Extension for Authentication
RFC2616
Hypertext Transfer Protocol – HTTP/1.1
RFC2617
HTTP Authentication: Basic and Digest Access Authentication
RFC2988
Computing TCP's Retransmission Timer
RFC3207
SMTP Service Extension for Secure SMTP over Transport Layer Security
RFC3315
Dynamic Host Configuration Protocol for IPv6 (DHCPv6)
RFC3390
Increasing TCP's Initial Window
RFC3493
Basic Socket Interface Extensions for IPv6
RFC3596
DNS Extensions to Support IP Version 6
RFC3646
DNS Configuration options for Dynamic Host Configuration protocol for IPv6 (DHCPv6)
RFC3927
Dynamic Configuration of IPv4 Link-Local Addresses
RFC4007
IPv6 Scoped Address Architecture
RFC4291
IP Version 6 Addressing Architecture
RFC4361
Node-specific Client Identifiers for Dynamic Host Configuration Protocol Version four (DHCPv4)
RFC4443
Internet Control Message Protocol (ICMPv6)
RFC4861
Neighbor Discovery for IP version 6 (IPv6)
RFC4862
IPv6 Stateless Address Autoconfiguration
RFC5342
IANA Considerations and IETF Protocol Usage for IEEE 802 Parameters
RFC5681
TCP Congestion Control
RFC5735
Special Use IPv4 Addresses
RFC5952
A Recommendation for IPv6 Address Text Representation
RFC5961
Improving TCP's Robustness to Blind In-Window Attacks
RFC6298
Draft-00
DHCP Option 61 UUID Type Definition
Using the ARM:mbedTLS Software Pack, additional RFCs are covered:
RFC
Title
RFC5077
Transport Layer Security (TLS) Session Resumption without Server-Side State
RFC5746
Transport Layer Security (TLS) Renegotiation Indication Extension
RFC6066
Transport Layer Security (TLS) Extensions: Extension Definitions
RFC7301
Transport Layer Security (TLS) Application-Layer Protocol Negotiation Extension
GMT+8, 2026-11-25 12:01 , Processed in 1.145244 second(s), 27 queries .
