查看: 7278|回复: 0
[IAR] IAR6.3编译STM32F103 (IAR 5 工程) 问题
发表于 2014-3-9 15:38:07 | 显示全部楼层 |阅读模式
解决方法的文档:
DM00039768.pdf (98 KB, 下载次数: 382)
1、打开编译正常的项目(用IAR5建立的),编译时提示如下错误:
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __get_PSP(void)"
(declared at line 52 of "xx:\IAR Systems6\Embedded Workbench 6.0\arm\inc\c\intrinsics.h")
解决办法:
具体操作可以参考这份文档,
[PDF] How to use EWARM 6.2x with projects built with EWARM 6.1 ...Page 1. October 2011 Doc ID 022329 Rev 1 1/6 TN0830 Technical
note How to use EWARM 6.2x with projects built with ...http://www.st.com/st-web-ui/static/active/en/resource/technical/document/technical_note/DM00039768.pdf
GMT+8, 2026-11-24 07:42 , Processed in 0.185266 second(s), 26 queries .
