查看: 14707|回复: 14
[有问必答] RA8875显示问题,求教。
发表于 2014-3-7 09:28:32 | 显示全部楼层 |阅读模式
RA8875,跑示例,显示异常,如下图。
还有就是读内存,全是0,
u16 RA8875_GetPixel(u16 X,u16 Y)
u16 RGB;
RA8875_WAITSTATUS();
Memory_read_Coordinate(X,Y);
WriteCommand(0x02);
RGB = RA8875_RAM;
Bus_Delay(10);
RGB = RA8875_RAM;
return RGB;
FSMC调了也不用。
static void LCD_FSMCConfig(void)
FSMC_NORSRAMInitTypeDef  init;
FSMC_NORSRAMTimingInitTypeDef  timingWrite;
FSMC_NORSRAMTimingInitTypeDef  timingRead;
/*-- FSMC Configuration ------------------------------------------------------*/
/*----------------------- SRAM Bank 4 ----------------------------------------*/
/* FSMC_Bank1_NORSRAM4 configuration */
/* 摄像头DMA麻点,需设置 4 0 5 2 0 0 */
timingWrite.FSMC_AddressSetupTime = 2;
timingWrite.FSMC_AddressHoldTime = 0;
timingWrite.FSMC_DataSetupTime = 2;
timingWrite.FSMC_BusTurnAroundDuration = 1;
timingWrite.FSMC_CLKDivision = 0;
timingWrite.FSMC_DataLatency = 0;
timingWrite.FSMC_AccessMode = FSMC_AccessMode_A;
timingRead.FSMC_AddressSetupTime = 3;
timingRead.FSMC_AddressHoldTime = 0;
timingRead.FSMC_DataSetupTime = 6;
timingRead.FSMC_BusTurnAroundDuration = 1;
timingRead.FSMC_CLKDivision = 0;
timingRead.FSMC_DataLatency = 0;
timingRead.FSMC_AccessMode = FSMC_AccessMode_A;
  LCD configured as follow:
     - Data/Address MUX = Disable
     - Memory Type = SRAM
     - Data Width = 16bit
     - Write Operation = Enable
     - Extended Mode = Enable
     - Asynchronous Wait = Disable
init.FSMC_Bank = FSMC_Bank1_NORSRAM4;
init.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
init.FSMC_MemoryType = FSMC_MemoryType_SRAM;
init.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
init.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
init.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable; /* 注意旧库无这个成员 */
init.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
init.FSMC_WrapMode = FSMC_WrapMode_Disable;
init.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
init.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
init.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
init.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
init.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
init.FSMC_ReadWriteTimingStruct = &timingRead;
init.FSMC_WriteTimingStruct = &timingWrite;
FSMC_NORSRAMInit(&init);
/* - BANK 1 (of NOR/SRAM Bank 1~4) is enabled */
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
求解。
中间有条线
中间有条线
好多条
好多条
参与人数 1 +3 收起 理由
eric2013 + 3 图片显示功能很帅
发表于 2014-3-7 10:20:47 | 显示全部楼层
首先感谢楼主发这个帖子,发现论坛也可以这么发图片。
你可以先把触摸功能关闭了试试看,因为在使用RA8875的情况下,刷屏和触摸操作都需要使用FSMC通讯,也就是说有冲突
发表于 2014-3-7 11:03:18 | 显示全部楼层
我试了下图片的显示方式,无法实现你上面的那种方式显示,你要是有时候的教我一下你是怎么设置的。
 楼主| 发表于 2014-3-7 12:37:18 | 显示全部楼层
感谢大家,我关中断试试。
 楼主| 发表于 2014-3-7 12:39:01 | 显示全部楼层
点小图就成这样了。
发表于 2014-3-7 13:02:59 | 显示全部楼层
回 physh 的帖子
physh:点小图就成这样了。 (2014-03-07 12:39)
小图是在哪里点击的,能发个截图不,感谢
 楼主| 发表于 2014-3-8 12:54:16 | 显示全部楼层
仔细想了想,应该不是触摸中断与FSMC冲突引起的,触摸是轮询方式,没用硬件中断,而且是跑的例程,没有触摸。不用UCGUI,用RA8875硬件画图正常。应该是UCGUI设置问题吧,我用的是外部的RAM。本人认为。还有一个安富莱的图片放大的例程,在我这跑,只有显示屏的上半部显示,下半部黑屏。
发表于 2014-3-8 14:09:47 | 显示全部楼层
回 physh 的帖子
physh:仔细想了想,应该不是触摸中断与FSMC冲突引起的,触摸是轮询方式,没用硬件中断,而且是跑的例程,没有触摸。不用UCGUI,用RA8875硬件画图正常。应该是UCGUI设置问题吧,我用的是外部的RAM。本人认为。还有一个安富莱的图片放大的例程,在我这跑,只有显示屏的上半部显示,下半部 .. (2014-03-08 12:54)
降低下FSMC的速度试试
发表于 2014-5-20 23:21:58 | 显示全部楼层
正在使用8875,请求加楼主好友
发表于 2014-5-21 09:53:41 | 显示全部楼层
回 johnny092 的帖子
johnny092:正在使用8875,请求加楼主好友 (2014-05-20 23:21)
μCOS&emWin&μCGUI群: 216681322
发表于 2014-7-6 10:18:12 | 显示全部楼层
不知道 楼主的问题 解决了 没有  我的板子  也是加载了个SRAM在 FSMC总线上面,会出现02指令读RA8875 RAM数据返回值为0,这样造成光标 拖动 有黑影(因为读取的像数值是错误的),,但是 去掉SRAM 也就是FSMC总线 直挂载  RA8875 这时候 可以  读取像数 值~~ 为此 很困惑 ,,,寻求 解决方法
发表于 2014-7-6 11:10:41 | 显示全部楼层
回 zhaxiaobian_ 的帖子
zhaxiaobian_:不知道 楼主的问题 解决了 没有  我的板子  也是加载了个SRAM在 FSMC总线上面,会出现02指令读RA8875 RAM数据返回值为0,这样造成光标 拖动 有黑影(因为读取的像数值是错误的),,但是 去掉SRAM 也就是FSMC总线 直挂载  RA8875 这时候 可以 & .. (2014-07-06 10:18)
你分别是用的那个片选外挂的SRAM和TFT
发表于 2014-7-14 09:53:25 | 显示全部楼层
eric2013:你分别是用的那个片选外挂的SRAM和TFT (2014-07-06 11:10)
8875用的是NE1
  /* 定义LCD驱动器的访问地址 */
    #define RA8875_BASE        ((uint32_t)(0x60000000 ))
    #define RA8875_REG        *(__IO uint16_t *)(RA8875_BASE+ (1 << 17))
    #define RA8875_RAM        *(__IO uint16_t *)(RA8875_BASE)
SRAM用的是NE3
#define Bank1_SRAM3_ADDR    ((u32)0x68000000)
#define SRAM_WRITE(Address, Data)  (*(vu16 *)(Address) = (Data))
发表于 2014-7-14 10:37:25 | 显示全部楼层
回 zhaxiaobian_ 的帖子
zhaxiaobian_:8875用的是NE1
  /* 定义LCD驱动器的访问地址 */
....... (2014-07-14 09:53)
问题解决了,RA8875片选接上拉后,读像素点RGB颜色正常。       我现在有个疑问STM32的FSMC_NE1配置的是推挽输出,按道理来说,驱动能力是比较大的,上拉电阻完全可以省掉,但是为什么 会出现这个问题。。。
GMT+8, 2026-11-28 12:25 , Processed in 0.367440 second(s), 34 queries .
