查看: 5862|回复: 1
[emWin] STemWin中已经支持的控件ID和按键ID
发表于 2014-3-6 21:06:10 | 显示全部楼层 |阅读模式
*       GUI_KEY_...
* These ID values are basically meant to be used with widgets
* Note that we have chosen the values to be close to existing
* "standards", so do not change them unless forced to.
#define GUI_KEY_BACKSPACE         8         /* ASCII: BACKSPACE Crtl-H */
#define GUI_KEY_TAB                        9         /* ASCII: TAB       Crtl-I */
#define GUI_KEY_BACKTAB             10
#define GUI_KEY_ENTER                  13        /* ASCII: ENTER     Crtl-M */
#define GUI_KEY_LEFT                     16
#define GUI_KEY_UP                         17
#define GUI_KEY_RIGHT                   18
#define GUI_KEY_DOWN                  19
#define GUI_KEY_HOME                   23
#define GUI_KEY_END                      24
#define GUI_KEY_SHIFT                   25
#define GUI_KEY_CONTROL           26
#define GUI_KEY_ESCAPE              27        /* ASCII: ESCAPE    0x1b   */
#define GUI_KEY_INSERT               29
#define GUI_KEY_DELETE              30
#define GUI_KEY_SPACE                32
#define GUI_KEY_PGUP                   33
#define GUI_KEY_PGDOWN            34
#define GUI_KEY_F1                40
#define GUI_KEY_F2                41
*       Dialog item IDs
*  The IDs below are arbitrary values. They just have to be unique
*  within the dialog.
*  If you use your own Ids, we recommend to use values above GUI_ID_USER.
#define GUI_ID_OK                      1
#define GUI_ID_CANCEL             2
#define GUI_ID_YES                    3
#define GUI_ID_NO                      4
#define GUI_ID_CLOSE               5
#define GUI_ID_HELP                  6
#define GUI_ID_MAXIMIZE           7
#define GUI_ID_MINIMIZE            8
#define GUI_ID_VSCROLL    0xFE
#define GUI_ID_HSCROLL    0xFF
#define GUI_ID_EDIT0      0x100
#define GUI_ID_EDIT1      0x101
#define GUI_ID_EDIT2      0x102
#define GUI_ID_EDIT3      0x103
#define GUI_ID_EDIT4      0x104
#define GUI_ID_EDIT5      0x105
#define GUI_ID_EDIT6      0x106
#define GUI_ID_EDIT7      0x107
#define GUI_ID_EDIT8      0x108
#define GUI_ID_EDIT9      0x109
#define GUI_ID_LISTBOX0   0x110
#define GUI_ID_LISTBOX1   0x111
#define GUI_ID_LISTBOX2   0x112
#define GUI_ID_LISTBOX3   0x113
#define GUI_ID_LISTBOX4   0x114
#define GUI_ID_LISTBOX5   0x115
#define GUI_ID_LISTBOX6   0x116
#define GUI_ID_LISTBOX7   0x117
#define GUI_ID_LISTBOX8   0x118
#define GUI_ID_LISTBOX9   0x119
#define GUI_ID_CHECK0     0x120
#define GUI_ID_CHECK1     0x121
#define GUI_ID_CHECK2     0x122
#define GUI_ID_CHECK3     0x123
#define GUI_ID_CHECK4     0x124
#define GUI_ID_CHECK5     0x125
#define GUI_ID_CHECK6     0x126
#define GUI_ID_CHECK7     0x127
#define GUI_ID_CHECK8     0x128
#define GUI_ID_CHECK9     0x129
#define GUI_ID_SLIDER0    0x130
#define GUI_ID_SLIDER1    0x131
#define GUI_ID_SLIDER2    0x132
#define GUI_ID_SLIDER3    0x133
#define GUI_ID_SLIDER4    0x134
#define GUI_ID_SLIDER5    0x135
#define GUI_ID_SLIDER6    0x136
#define GUI_ID_SLIDER7    0x137
#define GUI_ID_SLIDER8    0x138
#define GUI_ID_SLIDER9    0x139
#define GUI_ID_SCROLLBAR0 0x140
#define GUI_ID_SCROLLBAR1 0x141
#define GUI_ID_SCROLLBAR2 0x142
#define GUI_ID_SCROLLBAR3 0x143
#define GUI_ID_RADIO0     0x150
#define GUI_ID_RADIO1     0x151
#define GUI_ID_RADIO2     0x152
#define GUI_ID_RADIO3     0x153
#define GUI_ID_RADIO4     0x154
#define GUI_ID_RADIO5     0x155
#define GUI_ID_RADIO6     0x156
#define GUI_ID_RADIO7     0x157
#define GUI_ID_TEXT0      0x160
#define GUI_ID_TEXT1      0x161
#define GUI_ID_TEXT2      0x162
#define GUI_ID_TEXT3      0x163
#define GUI_ID_TEXT4      0x164
#define GUI_ID_TEXT5      0x165
#define GUI_ID_TEXT6      0x166
#define GUI_ID_TEXT7      0x167
#define GUI_ID_TEXT8      0x168
#define GUI_ID_TEXT9      0x169
#define GUI_ID_BUTTON0    0x170
#define GUI_ID_BUTTON1    0x171
#define GUI_ID_BUTTON2    0x172
#define GUI_ID_BUTTON3    0x173
#define GUI_ID_BUTTON4    0x174
#define GUI_ID_BUTTON5    0x175
#define GUI_ID_BUTTON6    0x176
#define GUI_ID_BUTTON7    0x177
#define GUI_ID_BUTTON8    0x178
#define GUI_ID_BUTTON9    0x179
#define GUI_ID_DROPDOWN0  0x180
#define GUI_ID_DROPDOWN1  0x181
#define GUI_ID_DROPDOWN2  0x182
#define GUI_ID_DROPDOWN3  0x183
#define GUI_ID_MULTIEDIT0 0x190
#define GUI_ID_MULTIEDIT1 0x191
#define GUI_ID_MULTIEDIT2 0x192
#define GUI_ID_MULTIEDIT3 0x193
#define GUI_ID_LISTVIEW0  0x200
#define GUI_ID_LISTVIEW1  0x201
#define GUI_ID_LISTVIEW2  0x202
#define GUI_ID_LISTVIEW3  0x203
#define GUI_ID_PROGBAR0   0x210
#define GUI_ID_PROGBAR1   0x211
#define GUI_ID_PROGBAR2   0x212
#define GUI_ID_PROGBAR3   0x213
#define GUI_ID_GRAPH0     0x220
#define GUI_ID_GRAPH1     0x221
#define GUI_ID_GRAPH2     0x222
#define GUI_ID_GRAPH3     0x223
#define GUI_ID_MULTIPAGE0 0x230
#define GUI_ID_MULTIPAGE1 0x231
#define GUI_ID_MULTIPAGE2 0x232
#define GUI_ID_MULTIPAGE3 0x233
#define GUI_ID_TREEVIEW0  0x240
#define GUI_ID_TREEVIEW1  0x241
#define GUI_ID_TREEVIEW2  0x242
#define GUI_ID_TREEVIEW3  0x243
#define GUI_ID_ICONVIEW0  0x250
#define GUI_ID_ICONVIEW1  0x251
#define GUI_ID_ICONVIEW2  0x252
#define GUI_ID_ICONVIEW3  0x253
#define GUI_ID_LISTWHEEL0 0x260
#define GUI_ID_LISTWHEEL1 0x261
#define GUI_ID_LISTWHEEL2 0x262
#define GUI_ID_LISTWHEEL3 0x263
#define GUI_ID_IMAGE0     0x270
#define GUI_ID_IMAGE1     0x271
#define GUI_ID_IMAGE2     0x272
#define GUI_ID_IMAGE3     0x273
#define GUI_ID_IMAGE4     0x274
#define GUI_ID_IMAGE5     0x275
#define GUI_ID_IMAGE6     0x276
#define GUI_ID_IMAGE7     0x277
#define GUI_ID_IMAGE8     0x278
#define GUI_ID_IMAGE9     0x279
#define GUI_ID_SPINBOX0   0x280
#define GUI_ID_SPINBOX1   0x281
#define GUI_ID_SPINBOX2   0x282
#define GUI_ID_SPINBOX3   0x283
#define GUI_ID_SPINBOX4   0x284
#define GUI_ID_SPINBOX5   0x285
#define GUI_ID_SPINBOX6   0x286
#define GUI_ID_SPINBOX7   0x287
#define GUI_ID_SPINBOX8   0x288
#define GUI_ID_SPINBOX9   0x289
#define GUI_ID_CALENDAR0  0x290
#define GUI_ID_USER       0x800
自定义ID的时候要特别注意,别搞重复了。
 楼主| 发表于 2014-3-6 21:23:22 | 显示全部楼层
要是超过了这些定义的ID,需要自定义,自定义的时候可以用GUI_ID_USER作为基准以避免重复
GMT+8, 2026-11-23 05:35 , Processed in 0.185120 second(s), 24 queries .
