查看: 8978|回复: 4
[客户分享] ST最新发布STM32版Arduino™ 板子(F030,F401,F103,L152)
发表于 2014-2-25 19:01:32 | 显示全部楼层 |阅读模式
地址:点击进入
共做了4种芯片的模块
下面是F4的,点击进入
Key Features
    [li]STM32 microcontroller with LQFP64 package[/li][li]Two types of extension resources[/li][li]Arduino Uno Revision 3 connectivity[/li][li]STMicroelectronics Morpho extension pin headers for full access to all STM32 I/Os[/li][li]mbed-enabled (mbed.org)[/li][li]On-board ST-LINK/V2-1 debugger/programmer with SWD connector[/li][li]selection-mode switch to use the kit as a standalone ST-LINK/V2-1[/li][li]Flexible board power supply[/li][li]USB VBUS or external source(3.3 V, 5 V, 7 - 12 V)[/li][li]Power management access point[/li][li]Three LEDs[/li][li]USB communication (LD1), user LED (LD2), power LED (LD3)[/li][li]Two push buttons: USER and RESET[/li][li]USB re-enumeration capability: three different interfaces supported on USB[/li][li]Virtual Com port[/li][li]Mass storage[/li][li]Debug port[/li][li]Comprehensive free software HAL library including a variety of software examples[/li][li]Supported by wide choice of Integrated Development Environments (IDEs) including IAR, Keil, GCC-based IDEs[/li]
发表于 2014-2-25 19:46:21 | 显示全部楼层
st看样子最近赚了不少钱啊,现在产品线真广
 楼主| 发表于 2014-2-25 19:50:48 | 显示全部楼层
回 wyq200704 的帖子
wyq200704:st看样子最近赚了不少钱啊,现在产品线真广 (2014-02-25 19:46)
在国内市场估计是好好的干了一票
发表于 2014-2-26 09:20:37 | 显示全部楼层
用AVR搞这个的挺多
发表于 2014-2-26 12:38:49 | 显示全部楼层
[s:150] [s:150] [s:150] [s:150]
GMT+8, 2026-11-28 12:26 , Processed in 1.315884 second(s), 27 queries .
