查看: 5242|回复: 5
[μCGUI] RA8875初始化后屏幕花屏
发表于 2017-1-3 17:53:21 | 显示全部楼层 |阅读模式
void GUI_LCDInit(void)
   RST_CRL;
   s_WaitNms(30);
   RST_SET;
   CS_SET;
   WR_SET;
   RD_SET;
    s_CmdWrite(0x88);
    s_DataWrite(0x0b);
    s_Delay(10000);
    s_CmdWrite(0x89);
    s_DataWrite(0x02);
    s_Delay(10000);
    s_CmdWrite(0x10);  //SYSR   bit[4:3]=00 256 color  bit[2:1]=        00 8bit MPU interface
    s_DataWrite(0x0C); // if 8bit MCU interface         and 65k color display
    s_Delay(10000);
    //==============        Display Window        640x480 ==================
    s_CmdWrite(0x04);    //PCLK inverse
    s_DataWrite(0x01);
    s_Delay(10000);
    //Horizontal set
    s_CmdWrite(0x14);//HDWR//Horizontal Display Width Setting Bit[6:0]
    s_DataWrite(0x4F);//Horizontal display width(pixels) = (HDWR + 1)*8
    s_CmdWrite(0x15); //Horizontal Non-Display Period Fine Tuning Option Register (HNDFTR)
    s_DataWrite(0x05);//Horizontal Non-Display Period Fine Tuning(HNDFT) [3:0]
    s_CmdWrite(0x16);//HNDR//Horizontal Non-Display Period Bit[4:0]
    s_DataWrite(0x0f);//Horizontal Non-Display Period (pixels) = (HNDR + 1)*8
    s_CmdWrite(0x17);//HSTR//HSYNC Start Position[4:0]
    s_DataWrite(0x01);//HSYNC Start Position(PCLK) = (HSTR + 1)*8
    s_CmdWrite(0x18); //HPWR//HSYNC Polarity ,The period width of HSYNC.
    s_DataWrite(0x00);//HSYNC Width [4:0]   HSYNC Pulse width(PCLK) = (HPWR + 1)*8
    //Vertical set
    s_CmdWrite(0x19); //VDHR0 //Vertical Display Height Bit [7:0]
    s_DataWrite(0xdf);//Vertical pixels = VDHR + 1
    s_CmdWrite(0x1A);//VDHR1 //Vertical Display Height Bit [8]
    s_DataWrite(0x01);//Vertical pixels = VDHR + 1
    s_CmdWrite(0x1B);//VNDR0 //Vertical Non-Display Period Bit [7:0]
    s_DataWrite(0x0A);//Vertical Non-Display area = (VNDR + 1)
    s_CmdWrite(0x1C);//VNDR1 //Vertical Non-Display Period Bit [8]
    s_DataWrite(0x00);//Vertical Non-Display area = (VNDR + 1)
    s_CmdWrite(0x1D);//VSTR0 //VSYNC Start Position[7:0]
    s_DataWrite(0x0E);//VSYNC Start Position(PCLK) = (VSTR + 1)
    s_CmdWrite(0x1E);//VSTR1 //VSYNC Start Position[8]
    s_DataWrite(0x00);//VSYNC Start Position(PCLK) = (VSTR + 1)
    s_CmdWrite(0x1F);//VPWR //VSYNC Polarity ,VSYNC Pulse Width[6:0]
    s_DataWrite(0x01);//VSYNC Pulse Width(PCLK) = (VPWR + 1)
   //Active window  set
   //setting active window X
    s_CmdWrite(0x30); //Horizontal Start Point 0 of Active Window (HSAW0)
    s_DataWrite(0x00); //Horizontal Start Point of Active Window [7:0]
    s_CmdWrite(0x31); //Horizontal Start Point 1 of Active Window (HSAW1)
    s_DataWrite(0x00); //Horizontal Start Point of Active Window [9:8]
    s_CmdWrite(0x34); //Horizontal End Point 0 of Active Window (HEAW0)
    s_DataWrite(0x7f); //Horizontal End Point of Active Window [7:0]
    s_CmdWrite(0x35); //Horizontal End Point 1 of Active Window (HEAW1)
    s_DataWrite(0x02); //Horizontal End Point of Active Window [9:8]
   //setting active window Y
    s_CmdWrite(0x32); //Vertical Start Point 0 of Active Window (VSAW0)
    s_DataWrite(0x00); //Vertical Start Point of Active Window [7:0]
    s_CmdWrite(0x33); //Vertical Start Point 1 of Active Window (VSAW1)
    s_DataWrite(0x00); //Vertical Start Point of Active Window [8]
    s_CmdWrite(0x36); //Vertical End Point of Active Window 0 (VEAW0)
    s_DataWrite(0xdf); //Vertical End Point of Active Window [7:0]
    s_CmdWrite(0x37); //Vertical End Point of Active Window 1 (VEAW1)
    s_DataWrite(0x01); //Vertical End Point of Active Window [8]
   /*setting RA8875 display on*/
    s_CmdWrite(0x01); //
    s_DataWrite(0x80); //
    s_Delay(10000);
    Active_Window(0,639,0,479); }
如上初始化之后,屏幕花屏,哪位知道问题出在哪里,指点下,多谢
发表于 2017-1-4 09:28:31 | 显示全部楼层
你的这个是IO口模拟总线进行通信的吗。
 楼主| 发表于 2017-1-4 10:36:39 | 显示全部楼层
eric2013:你的这个是IO口模拟总线进行通信的吗。 (2017-01-04 09:28)
是的,这个是IO口模拟
发表于 2017-1-6 07:56:16 | 显示全部楼层
你的这个背光是通过RA8875带的PWM驱动的不,如果是的话,说明你的总线通信没问题的。
另外就是要先读取ID,保证你的总线模拟没有问题。
发表于 2020-11-2 19:56:27 | 显示全部楼层
请问解决了吗, 请教解决办法
发表于 2020-11-4 10:10:19 | 显示全部楼层
有雪花屏表示驱动器已经工作了,但是显存数据为乱码,你这里只是开启了显示,没有更新显存数据,你刷个全屏数据看下。
GMT+8, 2026-11-23 19:58 , Processed in 0.949370 second(s), 27 queries .
