查看: 4555|回复: 1
[emWin] STemWin532下载包含CM0、CM3、CM4、CM7,也包含最新标准库
发表于 2016-12-22 11:50:18 | 显示全部楼层 |阅读模式
一直在找CM3的最新STemWin,今天去官网溜达一圈发现更新了,包含CM0、CM3、CM4、CM7,版本号是STemWin_Library_V1.2.0 。
不知道论坛有没有重复,分享一下。
官方地址http://www.st.com/web/en/catalog/tools/PF259225
en.stemwin 链接: http://pan.baidu.com/s/1cL286y 密码: drkq
Updatehistory
V1.2.0 / 22-September-2016
      MainChanges
    quare][li]Use Segger emWin latest version V5.32[/li][li]Official release supporting STM32469xx/STM32479xx devices and STM32469I-EVAL board[/li][li]Ethernet based Demonstrations are no more supported.[/li][li]Support System Workbench for STM32 (SW4STM32) instead of TrueSTUDIO toolchain[/li][li]The following boards are obsolete so not supported anymore:[/li]
    [li]STM3210B-EVAL board[/li]
    [li]STM32100E-EVAL board[/li]
    [li]STM32100B-EVAL board[/li]
    [li]STM32373C-EVAL board[/li]
    [li]STM32L152-EVAL board[/li]
Contents
    quare][li]STemWin Library V5.32 (releasenotes)
    [/li][li]Cortex-M CMSIS V4.30 (releasenotes)[/li][li]STM32F0xx CMSIS V1.5.1 (releasenotes)[/li][li]STM32F10x CMSIS V3.6.4 (releasenotes)[/li][li]STM32L1xx CMSIS V1.3.4 (releasenotes)[/li][li]STM32F2xx CMSIS V1.1.4 (releasenotes)[/li][li]STM32F30x CMSIS V1.2.3 (releasenotes)[/li][li]STM32F4xx CMSIS V1.7.0 (releasenotes)[/li][li]STM32F0xx_StdPeriph_Driver V1.3.0 (releasenotes)[/li][li]STM32F10x_StdPeriph_Driver V3.6.1 (releasenotes)[/li][li]STM32F2xx_StdPeriph_Driver V1.1.2 (releasenotes)[/li][li]STM32F30x_StdPeriph_Driver V1.2.3 (releasenotes)[/li][li]STM32F4xx_StdPeriph_Driver V1.7.1 (releasenotes)[/li][li]STM32L1xx_StdPeriph_Driver V1.3.1 (releasenotes)[/li][li]STM32_EVAL_Common V5.1.0 (releasenotes)[/li][li]STM3210E_EVAL V5.1.0 (releasenotes)[/li][li]STM3210C_EVAL V5.0.2 (releasenotes)[/li][li]STM322xG_EVAL V5.1.2 (releasenotes)[/li][li]STM32303C_EVAL V1.0.1 (releasenotes)[/li][li]STM3240_41_G_EVAL V1.1.3 (releasenotes)[/li][li]STM32L152D_EVAL V1.0.1 (releasenotes)[/li][li]STM324x9I_EVAL V1.0.4 (releasenotes)[/li][li]FreeRTOS V7.1.1 (releasenotes)[/li]
DevelopmentToolchains and Compilers
    quare][li]IAR EmbeddedWorkbench for ARM (EWARM) toolchain V7.60.2 + ST-Link debug probe
    [/li][li]RealView MicrocontrollerDevelopment Kit (MDK-ARM) toolchain V5.20 + ST-Link debug probe[/li][li]System Workbench for STM32 (SW4STM32) toolchain V1.9 + ST-LINK
    [/li]
SupportedDevices and EVAL boards
    quare][li]STM32F4 series[/li][li]STM324xG-EVAL board (FSMC interface)[/li]
    [li]STM324x9I-EVAL board (Integrated LCD controller)[/li][li]STM32469I-EVAL board (Integrated LCD controller)[/li]
STM32F2 series
    [li]STM322xG-EVAL board (FSMC interface)
    [/li]
STM32F1 series
    [li]STM3210C-EVAL board (SPI interface)[/li]
    [li]STM3210E-EVAL board (FSMC interface)[/li]
STM32F3 series
    [li]STM32303C-EVAL board (SPI interface)[/li]
STM32L1 series
    [li]STM32L152D-EVAL board (FSMC interface)[/li]
Known Limitations
    [li]STM32303C-EVAL board example: thepointer is hidden due to a limitation in the LCD driver regarding the“ReadRAM” functionality needed for XOR operation during the pointerposition update[/li][li]STM32469I-EVAL board example: thepointer and the control bar are hidden due to the unavailabilty of STM32469I-EVAL drivers.[/li]
参与人数 1 +5 收起 理由
eric2013 + 5
发表于 2016-12-22 13:49:08 | 显示全部楼层
官方这个好久没有更新了,这次终于更新了,一直是从Cube库里面获取
谢谢楼主分享[s:151]
GMT+8, 2026-11-23 09:13 , Processed in 0.929187 second(s), 25 queries .
