查看: 4314|回复: 0
[emWin] emWin的首版是发布于99年6月10号,再次特别感谢一位网友提供早期版本的更新记录
发表于 2016-11-29 00:37:26 | 显示全部楼层 |阅读模式
在此,特别感谢amobbs上的网友xyz543提供早期版本的更新记录。
无论是SEGGER还是Micrium都已经不再提供早期版本的更新记录了,在google上面也搜索了好多,也是没有找到。
Version control for emWin/GSC
000804 V1.32    a) various changes implemented
000403 V1.30f   a) LCD.h V1.30 used
000327 V1.30e   a) LCD.h V1.06a used
000323 V1.30d   a) GUIArcFloat.c included
000323 V1.30c   a) LCD.h V1.06 used
000229 V1.30b   a) Improved Unicode support in GUIChar.c
000217 V1.30a   a) LCD_Color update to V1.16 (grayscale support in 8666 mode)
000211 V1.30    a) 2 new info functions for fonts implemented
                b) Unicode string support added
991210 V1.28d   a) GUIChar.C: GUI_DispStringHCenter added
                b) Compile Warnings eliminated
991210 V1.28c   a) GUI2DGL.C splitted
991204 V1.28b   a) GUI_Context.AWin init modified
991203 V1.28a   a) GUI2DGL init now initializes GUI_Context.AWin
991203 V1.28    a) LCDColor updated (support for 3bpp)
991129 V1.26d   a) GUIChar.C update (1.20c)
991129 V1.26c   a) GUI2DGL.C update (reg. LCD_Init)
991110 V1.26b   a) GUIChar.h update
991110 V1.26a   a) GUI.H: System defines (Keys etc) added
991109 V1.26    a) GUI2DCL.C eliminated
991018 V1.24    a) All value display routines rewritten in order to
                   support writing into a string (which is helpful
                   for other modules, like Progbar etc.)
                b) Type cast added in GUI_GetCharDistX in order to
                   make sure characters above 128 are properly handled
991018 V1.22b   a) LCDChar.c 1.20.02 used
991018 V1.22a   a) LCDColor V1.12a used
991018 V1.22    a) Support for 8666 mode (LCDColor V1.12 used)
991015 V1.21.10 a) LCDColor.c update V1.10f
991014 V1.21.09 a) GUI2DGL.C update 1.02.05
991014 V1.21.08 a) GUI.h: Define for GUI_LIGHTBLUE changed
991012 V1.21.07 a) LCDColor.c: Color translation in 8bpp mode with fixed table as default added
991011 V1.21.06 a) LCDCOLOR.C V1.10.04 used
991009 V1.21.05 a) new GUI2DGL.C used
990927 V1.21.04 a) LCDColor.C: LCD_Color2Color15: Blue and red in return value swapped
990926 V1.21.03 a) Clipping on entire region for cursor
990921 V1.21.02 a) Add. locking support for thread safety
990918 V1.21.00 a) New file GUITASK.C added for thread safety
990909 V1.20.05 GUI2DCL.c: clean up
990901 V1.20.04 Config sample changed
990831 V1.20.02 GUIChar V1.10.01 in order to avoid compiler warnings
990821 V1.20.01 GUI: Small changes to avoid compiler warnings
990821 V1.20.00 Files reorganized, GUIX, GUIFONT, GUIFONTX directories
                created
990821 V1.14.01 WMID.H eliminated
990820 V1.14.00 LCDMEM4.C added
                LCDChar.C: GUI_DispStringCenterAt added
990810 V1.12.03 GUI.H cleanup, Sample\GUIConf.h cleaned up
990809 V1.12.02 GUIColor changed in order to ensure proper function
                with 16-bit CPUs
990804 v1.12.01 Some compiler warnings generated by the IAR compiler
                eliminated, code cleaned up
990802 V1.12.00 Font files now in seperate directory
                LCDWIN.C --> LCDWIN.CPP, now exports a routine
                to display the BITMAP under Windows
990725 v1.10.00 Dynamic fonts are supported (Fontkonverter compatible)
990720 v1.04.01 New version LCD135X.C
990713 v1.04.00 LCD135X.C:  V1.10
                LCDColor.C: V1.10
990712 V1.03.05 LCD15XX.C: V1.31.01
990709 V1.03.04 LCD15XX.C: V1.30.03
990709 V1.03.03 LCD15XX.C: V1.30.01
990708 V1.03.02 LCD15XX.C: V1.21.02
990615 V1.03.01 GL_DrawArc now works with degrees
990615 V1.03 Drawarc implemented
990615 V1.02 New Version LCD15XX.C: 1.21
990614 V1.01 New version of LCD15XX.C with support for Segment
             COM lookup tables
990610 V1.00 ** Initial version for version control purpose
GMT+8, 2026-11-23 09:03 , Processed in 0.771854 second(s), 24 queries .
