查看: 8123|回复: 6
[其它] 官方flashloader v2.8.0版本下载,用于STM8和STM32的串口ISP下载,支持STM32F74x/5
发表于 2016-11-3 01:23:55 | 显示全部楼层 |阅读模式
官方下载地址:链接
百度云下载:http://pan.baidu.com/s/1i4In7tb
Last version V2.8.0 -  01-September-2015
Supported Microsoft OS:
Windows 98SE, 2000, XP, Vista, 7, 8, 8.1, 10
How to use :
  1- Uninstall previous versions:
     use "Start-> Settings-> Control Panel-> Add or Remove Programs"
     to remove the old versions V2.x.y
  2- Run the setup
* V2.8.0 - 01-September-2015
New Features
    + Adding support of STM32L4x6xx devices
    + Adding support of STM32L0xx 192K of flash devices
    + Adding support of STM32F74x/5x devices
    + Adding support of STM32F412xx/F410xx/F446xx/F469xx/F479xx devices
    + Adding support of STM32F303/302xD/E devices
    + Fix com port up to 255
    + Fix GUI/command line version supporting .bin at an address offset different from base address
    + Fix STUARTBLLIB.dll to support non-aligned address at end of flash area. But data should be always multiple of 4 bytes.
Known Limitations
    + Options Bytes management of STM8, STM32L1/L0/L4 and STM32F0/2/3/4/7 devices is supported only in Command line version
      for batch programming,
    + Automatic selection of some STM8 devices may not work properly. If required, use
      command line version with batch files customization,
    + on Some STM32 MCus Write protection of last pages which is controlled by the last protection bit7
      in WPR3 options byte is working properly but the Graphical view of check boxes may not updated
      accordingly on some devices with large size greater than 128Kbytes.
      To enable/disable the write protection of last pages, you can check/uncheck only the first
      page of this group of pages on the graphical view.
    + STM32L "Erase all" feature is not supported. See AN2606 for more details.
* V2.7.0 - 15-September-2014
New Features
    + Adding support of New STM32F0xx/STM32F3xx/STM32F4xx/STM32L1xx/STM32L0xx/ devices
    + Project Source files upgraded to Visual Studio 2013
Known Limitations
    + Options Bytes management of STM8, STM32L1/L0 and STM32F0/2/3/4 devices is supported only in Command line version
发表于 2016-11-3 09:22:53 | 显示全部楼层
为什么CAN接口的不开放出来
 楼主| 发表于 2016-11-3 10:12:52 | 显示全部楼层
回 jcx0324 的帖子
jcx0324:为什么CAN接口的不开放出来 (2016-11-03 09:22)
这种ISP软件用的人还是太少了,下载速度极慢。
发表于 2016-11-4 11:27:26 | 显示全部楼层
can比232速度快多了
 楼主| 发表于 2016-11-4 11:29:33 | 显示全部楼层
回 jcx0324 的帖子
jcx0324:can比232速度快多了 (2016-11-04 11:27)
没有,CAN最高一般是1Mbps。而串口,比如F103就可以到4.5Mbps。
发表于 2016-11-5 11:59:09 | 显示全部楼层
原来是使用自带固化引导,还要设置boot模式。简直麻烦,不过上位机工程倒是可以参看下。
发表于 2016-11-9 12:49:37 | 显示全部楼层
eric2013:没有,CAN最高一般是1Mbps。而串口,比如F103就可以到4.5Mbps。 (2016-11-04 11:29)
ISP貌似波特率是115200,速度很慢的
GMT+8, 2026-11-22 15:26 , Processed in 1.318802 second(s), 24 queries .
