查看: 4433|回复: 3
大神看看我的这个sdram 读写速度如何啊 ???
发表于 2016-11-1 12:14:51 | 显示全部楼层 |阅读模式
SDRAM Test 8Bit Data Write Start ...[2016-10-28 07:14:41.350]           // 表示写入开始
SDRAM Test 8Bit Data Begin Check ...[2016-10-28 07:14:47.760]        // 6.41 表示写入 完成 用时读 开始
SDRAM Check Num = 0                 [2016-10-28 07:14:53.587]             // 5.827     读取数据完成, 以下类同
SDRAM Test 16Bit Data Write Start ...[2016-10-28 07:14:53.587]
SDRAM Test 16Bit Data Begin Check ...[2016-10-28 07:14:57.954]  // 4.367
SDRAM Check Num = 1                  [2016-10-28 07:15:02.085]  // 4.131
SDRAM Test 32Bit Data Write Start ...[2016-10-28 07:15:02.085]
SDRAM Test 32Bit Data Begin Check ...[2016-10-28 07:15:04.077]  // 1.992
SDRAM Check Num = 2                  [2016-10-28 07:15:05.959]  // 1.882
SDRAM Test 8Bit Data Write Start ...[2016-10-29 08:00:17.771]
SDRAM Test 8Bit Data Begin Check ...[2016-10-29 08:00:24.179]   // 6.408
SDRAM Check Num = 0                 [2016-10-29 08:00:30.009]   // 5.83
SDRAM Test 16Bit Data Write Start ...[2016-10-29 08:00:30.009]
SDRAM Test 16Bit Data Begin Check ...[2016-10-29 08:00:34.377]  // 4.368
SDRAM Check Num = 1                  [2016-10-29 08:00:38.456]  // 4
SDRAM Test 32Bit Data Write Start ...[2016-10-29 08:00:38.456]
SDRAM Test 32Bit Data Begin Check ...[2016-10-29 08:00:40.481]  // 2.025
SDRAM Check Num = 2                  [2016-10-29 08:00:42.379]  // 1.898
SDRAM Test 8Bit Data Write Start ...[2016-10-29 08:01:06.998]
SDRAM Test 8Bit Data Begin Check ...[2016-10-29 08:01:13.421]  // 6.423
SDRAM Check Num = 6                 [2016-10-29 08:01:19.247]  // 5.826
SDRAM Test 16Bit Data Write Start ...[2016-10-29 08:01:19.247]
SDRAM Test 16Bit Data Begin Check ...[2016-10-29 08:01:23.615]  // 4.368
SDRAM Check Num = 7                  [2016-10-29 08:01:27.698]  // 4.083
SDRAM Test 32Bit Data Write Start ...[2016-10-29 08:01:27.698]
SDRAM Test 32Bit Data Begin Check ...[2016-10-29 08:01:29.737]  // 2.039
SDRAM Check Num = 8                  [2016-10-29 08:01:31.618]  // 1.881
上述就是三次的读写测试时间,你看看效果如何啊 ??
测试函数如下:
void SDRAM_Test_8bit(void)
  uint8_t  *ptrSdramAddr_8Bit = (uint8_t *)SDRAM_BASE_USER_ADDR;   //   吧地址转换为指针
  uint32_t ii = 0;
  uint32_t jj=0;
  __IO uint8_t  SdramDataTest = 0 ;
  SdramDataTest = 0;
  printf("SDRAM Test 8Bit Data Write Start ...\r\n");
  for(ii=0;ii<0x7800000;ii++)
    *ptrSdramAddr_8Bit  = ( __IO uint8_t )(SdramDataTest);
    SdramDataTest++;
    ptrSdramAddr_8Bit ++;
  SdramDataTest=0;
  printf("SDRAM Test 8Bit Data Begin Check ...\r\n");
  for(ii=0;ii< 0x7800000;ii++)
    jj  = *ptrSdramAddr_8Bit++;
    SdramDataTest++;
  printf("SDRAM Check Num = %d\r\n\r\n", OkErrCnt++);
void SDRAM_Test_16bit(void)
  uint16_t  *ptrSdramAddr_16Bit = (uint16_t *)SDRAM_BASE_USER_ADDR;
  __IO uint32_t ii = 0;
  uint16_t  jj=0;
  __IO uint16_t  SdramDataTest = 0;
  ptrSdramAddr_16Bit = (uint16_t *)SDRAM_BASE_USER_ADDR;   //   吧地址转换为指针
  SdramDataTest = 0;
  printf("SDRAM Test 16Bit Data Write Start ...\r\n");
  for(ii=0;ii<0x3C00000;ii++)  // 128MByte   1024*1024*32*4 = (128MByte - 8MByte) / 2 = 0x3C00000
    *ptrSdramAddr_16Bit  = ( __IO uint16_t )(SdramDataTest);
    SdramDataTest++;
    ptrSdramAddr_16Bit ++;
  SdramDataTest=0;
  printf("SDRAM Test 16Bit Data Begin Check ...\r\n");
  for(ii=0;ii< 0x3C00000;ii++)
    jj  = *ptrSdramAddr_16Bit ++;
    SdramDataTest++;
void SDRAM_Test_32bit(void)
  uint32_t  *ptrSdramAddr_32Bit = (uint32_t *)(SDRAM_BASE_USER_ADDR);          // SDRAM_BASE_USER_ADDR;
  uint32_t jj=0;
  __IO uint32_t  ii = 0, SdramDataTest = 0;
  ptrSdramAddr_32Bit = (uint32_t *)(SDRAM_BASE_USER_ADDR);   //   吧地址转换为指针
  SdramDataTest = 0;
  printf("SDRAM Test 32Bit Data Write Start ...\r\n");
  for(ii=0;ii<0x1E00000;ii++)  // 128MByte   1024*1024*32*4 = (128MByte - 8MByte) / 4 = 0x1E00000
    *ptrSdramAddr_32Bit  = ( __IO uint32_t )(SdramDataTest);
    ptrSdramAddr_32Bit ++;
    SdramDataTest++;
  SdramDataTest=0;
  ptrSdramAddr_32Bit = (uint32_t *)SDRAM_BASE_USER_ADDR;
  printf("SDRAM Test 32Bit Data Begin Check ...\r\n");
  for(ii=0;ii< 0x1E00000;ii++)
    jj  = *ptrSdramAddr_32Bit++;
   SdramDataTest++;
发表于 2016-11-2 01:31:40 | 显示全部楼层
这个是我给我们的V6板子测试的
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=16836
 楼主| 发表于 2016-11-2 10:44:46 | 显示全部楼层
eric2013:这个是我给我们的V6板子测试的
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=16836 (2016-11-02 01:31)
那如此看来我的是比较慢了啊,怎么会这样啊 ?
发表于 2016-11-2 11:26:05 | 显示全部楼层
回 hpdell 的帖子
hpdell:那如此看来我的是比较慢了啊,怎么会这样啊 ? (2016-11-02 10:44)
你用我的测试方法搞搞,
for循环本身也是比较耗时间的,你可以展开一部分。
GMT+8, 2026-11-25 10:46 , Processed in 0.236448 second(s), 24 queries .
