查看: 6785|回复: 4
[有问必答] RTC问题的请教
发表于 2016-10-24 22:54:32 | 显示全部楼层 |阅读模式
版主好,最近在做stm32F407 VGT6的RTC 实验。测试发现,重新配置时间时,时分秒参数写入后能立即生效,但是年月日参数写入后却不能立刻生效。
并且我监视了 RTC-DR寄存器,发现写入前后该寄存器值没有发生变化。更为奇葩的是,我复位后,再次读取得RTC-DR  寄存器值,竟然和我写入的一致。
比如: 写入前 读   RTC-DR寄存器值 为 0x103212,写入0x113212后再读 RTC-DR寄存器值还是 0x103212。复位重启后,读RTC-DR寄存器值则是0x113212。希望版主能帮忙解答下。
程序
static uint8_t RTC_WakeUP(void);
RTC_TimeTypeDef RTC_TimeStructure;
RTC_DateTypeDef RTC_DateStructure;
void RTC_Init_Config(void)
    RTC_InitTypeDef RTC_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);
    PWR_BackupAccessCmd(ENABLE);
    RTC_WakeUP();
    if(0xA5A1!=RTC_ReadBackupRegister(RTC_BKP_DR0))
        RCC_LSEConfig(RCC_LSE_ON);
            while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
        RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
        RCC_RTCCLKCmd(ENABLE);
        RTC_InitStructure.RTC_AsynchPrediv = 0x7f;
        RTC_InitStructure.RTC_SynchPrediv  = 0xff;
        RTC_InitStructure.RTC_HourFormat   = RTC_HourFormat_24;
        RTC_Init(&RTC_InitStructure);
        Set_RTC_Time(19,12,24,16,20,20,2);
        RTC_WriteBackupRegister(RTC_BKP_DR0, 0xA5A1);
uint8_t RTC_Param_Config(uint16_t year,
                                        uint8_t month,
                                        uint8_t day,
                                        uint8_t hour,
                                        uint8_t minute,
                                        uint8_t second,
                                        uint8_t week)
    RTC_WakeUP();
        //RTC_WaitForSynchro();
        //RTC_Param_Config(16,12,24,16,20,20,2);
    Set_RTC_Time(year,month,day,hour,minute,second,week);
        return 0;
void Set_RTC_Time(uint16_t year,
                                        uint8_t month,
                                        uint8_t day,
                                        uint8_t hour,
                                        uint8_t minute,
                                        uint8_t second,
                                        uint8_t week)
    RTC_TimeStructure.RTC_Hours=hour;
    RTC_TimeStructure.RTC_Minutes=minute;
    RTC_TimeStructure.RTC_Seconds=second;
    RTC_DateStructure.RTC_Year=year;
    RTC_DateStructure.RTC_Month=month;
    RTC_DateStructure.RTC_Date=day;
    RTC_DateStructure.RTC_WeekDay=week;
    while (RTC_SetDate(RTC_Format_BIN,&RTC_DateStructure)==ERROR) {};
    while (RTC_SetTime(RTC_Format_BIN,&RTC_TimeStructure)==ERROR ){};
    EXTI_InitTypeDef  EXTI_InitStructure;
    NVIC_InitTypeDef  NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
    RTC_WakeUpCmd(DISABLE);
    RTC_WakeUpClockConfig(RTC_WakeUpClock_RTCCLK_Div8);
    RTC_SetWakeUpCounter(4096);
    RTC_ClearITPendingBit(RTC_IT_WUT);
    EXTI_ClearITPendingBit(EXTI_Line22);
    RTC_ITConfig(RTC_IT_WUT,ENABLE);
    RTC_WakeUpCmd(ENABLE);
    EXTI_InitStructure.EXTI_Line=EXTI_Line22;
    EXTI_InitStructure.EXTI_Mode=EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger=EXTI_Trigger_Rising;
    EXTI_InitStructure.EXTI_LineCmd=ENABLE;
    EXTI_Init(&EXTI_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel=RTC_WKUP_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority=2;
    NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    return 0;
uint8_t  Read_RealTime(Time_Def_Structure *pTime_Struct_Instance)
//    RTC_TimeTypeDef RTC_TimeStructure;
//    RTC_DateTypeDef RTC_DateStructure;
    RTC_GetDate(RTC_Format_BIN,&RTC_DateStructure);
    RTC_GetTime(RTC_Format_BIN,&RTC_TimeStructure);
    pTime_Struct_Instance->RTC_Year            =        RTC_DateStructure.RTC_Year;
    pTime_Struct_Instance->RTC_Month        =        RTC_DateStructure.RTC_Month;
    pTime_Struct_Instance->RTC_Date            =        RTC_DateStructure.RTC_Date;
    pTime_Struct_Instance->RTC_WeekDay    =        RTC_DateStructure.RTC_WeekDay;
    pTime_Struct_Instance->RTC_Hours            =        RTC_TimeStructure.RTC_Hours;
    pTime_Struct_Instance->RTC_Minutes        =        RTC_TimeStructure.RTC_Minutes;
    pTime_Struct_Instance->RTC_Seconds        =        RTC_TimeStructure.RTC_Seconds;
    return 0;
不知道有没有问题
 楼主| 发表于 2016-10-24 22:55:46 | 显示全部楼层
在吗,版主
发表于 2016-10-25 10:27:22 | 显示全部楼层
你用的是F407吗,F407有个bug,你设置完毕时间和日期后,读取的时候一定要先读取时间,然后读取日期才可以
 楼主| 发表于 2016-10-25 10:33:28 | 显示全部楼层
eric2013:你用的是F407吗,F407有个bug,你设置完毕时间和日期后,读取的时候一定要先读取时间,然后读取日期才可以
 (2016-10-25 10:27)
果然是这样,解决了。有官方文档说明这个问题吗?
发表于 2016-10-25 10:34:43 | 显示全部楼层
回 406178052 的帖子
406178052:果然是这样,解决了。有官方文档说明这个问题吗? (2016-10-25 10:33)
没有,这个是问的人多了,才发现这个奇葩的问题。
GMT+8, 2026-11-28 14:08 , Processed in 1.721518 second(s), 24 queries .
