查看: 6942|回复: 4
[有问必答] STM32F407操作NANDFLASH错误
发表于 2016-9-17 20:19:11 | 显示全部楼层 |阅读模式
    我用STM32F407的FSMC驱动NANDFLASH(K9F1208)可以正常读出NANDFLASH的ID,现在的问题是当正确擦除块后用页读命令读取擦除的块时读出的数据全是0,
void NAND_GpioInit()
  GPIO_InitTypeDef myGPIO;
  AFGPIO_InitTypeDef myAFGPIO;
  myGPIO.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_15;
  myGPIO.GPIO_Mode =GPIO_Mode_AF;
  myGPIO.GPIO_OType =GPIO_OType_PP;
  myGPIO.GPIO_PuPd =GPIO_PuPd_NOPULL;
  myGPIO.GPIO_Speed =GPIO_Speed_100MHz;
  GPIO_Init(GPIOD,&myGPIO);
  myGPIO.GPIO_Pin =GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
  GPIO_Init(GPIOE,&myGPIO);
  myGPIO.GPIO_Pin =GPIO_Pin_9;
  GPIO_Init(GPIOG,&myGPIO);
  myGPIO.GPIO_Pin =GPIO_Pin_6;
  myGPIO.GPIO_Mode =GPIO_Mode_IN;
  myGPIO.GPIO_PuPd =GPIO_PuPd_IPU;
  myGPIO.GPIO_OType =GPIO_OType_OD;
  myAFGPIO.GPIO_Pin =AFGPIO_Pin_0|AFGPIO_Pin_1|AFGPIO_Pin_4|AFGPIO_Pin_5|AFGPIO_Pin_11|AFGPIO_Pin_12|AFGPIO_Pin_14|AFGPIO_Pin_15;
  myAFGPIO.GPIO_AF =AFGPIO_AF12;
  AFGPIO_Init(GPIOD,&myAFGPIO);
  myAFGPIO.GPIO_Pin =AFGPIO_Pin_7|AFGPIO_Pin_8|AFGPIO_Pin_9|AFGPIO_Pin_10;
  AFGPIO_Init(GPIOE,&myAFGPIO);
  myAFGPIO.GPIO_Pin =AFGPIO_Pin_9;
  AFGPIO_Init(GPIOG,&myAFGPIO);
void NAND_FsmcInit()
  FSMC_Bank3 -&gtCR3 =0;
  FSMC_Bank3 -&gtCR3|=(UINT32)(1<<13);  //ALE To RE Delay
  FSMC_Bank3 -&gtCR3|=(UINT32)(1<<9);   //CLE To RE Delay
  //FSMC_Bank3 -&gtCR3|=(1<<1); //en wait
  //FSMC_Bank3 -&gtCR3|=(1<<17); //ecc 512
  //FSMC_Bank3 -&gtCR3|=(1<<6); //en ecc
  FSMC_Bank3 -&gtMEM3 =0;
  FSMC_Bank3 -&gtMEM3|=(UINT32)(1<<24);  //Mem HiZ Hold =1
  FSMC_Bank3 -&gtMEM3|=(UINT32)(2<<16);  //Mem Hold time  =2
  FSMC_Bank3 -&gtMEM3|=(UINT32)(3<<8);   //Mem Wait time =3
  FSMC_Bank3 ->PMEM3|=(UINT32)(1<<0);   //Mem Setup time =1
  FSMC_Bank3 ->PATT3 =0;
  FSMC_Bank3 ->PATT3|=(UINT32)(1<<24);
  FSMC_Bank3 ->PATT3|=(UINT32)(2<<16);
  FSMC_Bank3 ->PATT3|=(UINT32)(3<<8);
  FSMC_Bank3 ->PATT3|=(UINT32)(1<<0);
  FSMC_Bank3 ->PCR3|=(UINT32)(1<<3);   //NANDFLASH
  FSMC_Bank3 ->PCR3|=(UINT32)(1<<2);   //NANDFLASH Enable
  NAND_GpioInit();
// NAND_Reset();
void NAND_Reset()
  NAND_WrCmd(0xff);
  NAND_Busy();
UINT32 NAND_ReadID()
  UINT32 id =0;
  NAND_WrCmd(0x90);
  NAND_WrAdr(0x00);
  id =NAND_RdByte() <<24;
  NAND_WrAdr(0x01);
  id|=NAND_RdByte() <<16;
  NAND_WrAdr(0x02);
  id|=NAND_RdByte() <<8;
  NAND_WrAdr(0x03);
  id|=NAND_RdByte() <<0;
  return id;
UINT8 NAND_ReadSR()
  static UINT8 sr=0;
  NAND_WrCmd(0x70);
  NAND_Busy();
  sr =NAND_RdByte();
  return sr;
UINT8 NAND_BlockErase(UINT32 bladr)
  bladr <<=5;
  NAND_WrCmd(0x60);
  NAND_WrAdr(bladr);
  NAND_WrAdr(bladr>>8);
  NAND_WrAdr(bladr>>16);
  NAND_WrCmd(0xD0);
  NAND_Busy();
  if((NAND_ReadSR()&0x01) !=NAND_OK)return NAND_FAIL;
  return NAND_OK;
void NAND_PageRead(UINT32 padr,UINT8 *Buf)
  UINT16 i;
  NAND_WrCmd(0x00);
  NAND_WrAdr(0);
  NAND_WrAdr(padr);
  NAND_WrAdr(padr>>8);
  NAND_WrAdr(padr>>16);
  NAND_Busy();
  for(i=0;i<512;i++)Buf=NAND_RdByte();
UINT8 NAND_PageWrite(UINT32 padr,UINT8 *Buf)
  UINT16 i;
  NAND_WrCmd(0x80);
  NAND_WrAdr(0);
  NAND_WrAdr(padr);
  Delay_ms(1);
  for(i=0;i<512;i++)NAND_WrByte(Buf);
  NAND_WrCmd(0x10);
  NAND_Busy();
  if((NAND_ReadSR()&0x01)!=NAND_OK)return NAND_FAIL;
  return NAND_OK;
//include
#define NAND_OK   0
#define NAND_FAIL 1
#define CMD_AREA          ((UINT32)0x010000)  /* A16 = CLE  high */
#define ADDR_AREA         ((UINT32)0x020000)  /* A17 = ALE high */
#define DATA_AREA         ((UINT32)0x000000)
#define Bank_NAND_ADDR    ((UINT32)0x80000000)
#define NAND_WrCmd(Cmd)      (*(UINT8 *)(Bank_NAND_ADDR | CMD_AREA)) =Cmd
#define NAND_WrAdr(Adr)   (*(UINT8 *)(Bank_NAND_ADDR | ADDR_AREA)) =Adr
#define NAND_WrByte(Dat)  (*(UINT8 *)(Bank_NAND_ADDR | DATA_AREA)) =Dat
#define NAND_RdByte()     (*(UINT8 *)(Bank_NAND_ADDR | DATA_AREA))
#define NAND_Busy()  while((GPIOG ->IDR & (1<<6))==0)
//main函数
NAND_FsmcInit();
tmp =NAND_ReadID();  //可以正常读出ID号
res =NAND_BlockErase(0); //块擦除返回OK
NAND_PageRead(0,buf);  //读出擦除的数据全是0,读取数据错误
目前可以确定是FSMC配置问题,因为我用IO模拟时序的时候读写NANDFLASH块的数据都是正确的,IO模拟时将下面4个宏改成4个函数,分别写了IO模拟时序。
用下面的IO模拟时序时数据是正确的,所以可以肯定是FSMC配置的问题,但我实在是找不出问题来。
UINT8 NAND_RdByte()
  UINT8 tmp;
  NAND_GPIO_OUT(0xff);
  NAND_CLE_CLR();
  NAND_ALE_CLR();
  NAND_CS_CLR();
  Delay_us(100);
  NAND_RE_CLR();
  Delay_us(200);
  tmp =NAND_GPIO_IN();
  NAND_RE_SET();
  Delay_us(100);
  NAND_CLE_SET();
  NAND_ALE_SET();
  NAND_CS_SET();
  return tmp;
void NAND_WrByte(UINT8 Dat)
  NAND_CLE_CLR();
  NAND_ALE_CLR();
  NAND_CS_CLR();
  NAND_GPIO_OUT(Dat);
  Delay_us(500);
  NAND_WE_CLR();
  Delay_us(100);
  NAND_WE_SET();
  Delay_us(100);
  NAND_CLE_SET();
  NAND_ALE_SET();
  NAND_CS_SET();
void NAND_WrCmd(UINT8 Cmd)
  NAND_ALE_CLR();
  NAND_CS_CLR();
  NAND_GPIO_OUT(Cmd);
  Delay_us(500);
  NAND_WE_CLR();
  Delay_us(100);
  NAND_WE_SET();
  Delay_us(100);
  NAND_ALE_SET();
  NAND_CS_SET();
void NAND_WrAdr(UINT8 Adr)
  NAND_CLE_CLR();
  NAND_CS_CLR();
  NAND_GPIO_OUT(Adr);
  Delay_us(500);
  NAND_WE_CLR();
  Delay_us(100);
  NAND_WE_SET();
  Delay_us(100);
  NAND_CLE_SET();
  NAND_CS_SET();
麻烦大虾们帮我看看配置时序哪里有问题,可以正常读出ID,然后就是页读函数
  UINT16 i;
  NAND_WrCmd(0x00);
  NAND_WrAdr(0);
  NAND_WrAdr(padr);
  NAND_Busy();
  for(i=0;i<512;i++)Buf=NAND_RdByte(); //我发现当运行到这里的时候NAND的数据总线是处于高阻态的,NANDFLASH没有数据返回,读取的数据是GPIO数据端口的最后状态
发表于 2016-9-18 09:52:54 | 显示全部楼层
参照例程啊,读取部分还是挺正常的
 楼主| 发表于 2016-9-18 12:40:12 | 显示全部楼层
回 jcx0324 的帖子
jcx0324:参照例程啊,读取部分还是挺正常的 (2016-09-18 09:52)
现在的问题基本可以确定是FSMC配置问题,也看过别人的例程没看出问题来。
发表于 2016-9-18 15:23:22 | 显示全部楼层
写的是寄存器操作,看起来累.........
 楼主| 发表于 2016-9-20 15:39:08 | 显示全部楼层
问题解决了,最后没办法用了逻辑分析仪将NAND_FLASH总线时序抓出来进行分析,总算是找出问题并已解决。
GMT+8, 2026-11-28 14:08 , Processed in 0.781263 second(s), 24 queries .
