查看: 5300|回复: 1
[FatFs] FatFS升级到0.12b版本(更新日期2016-09-04)
发表于 2016-9-9 09:49:47 | 显示全部楼层 |阅读模式
论坛下载: ff12b.zip (14.29 MB, 下载次数: 301)
官方下载地址: http://elm-chan.org/fsw/ff/00index_e.html
更新记录:
R0.12b (September 4, 2016)
  Improved f_rename() to be able to rename objects with the same name but case.
  Fixed an error in the case conversion teble of code page 866. (ff.c)
  Fixed writing data is truncated at the file offset 4GiB on the exFAT volume. (appeared at R0.12)
  Fixed creating a file in the root directory of exFAT volume can fail. (appeared at R0.12)
  Fixed f_mkfs() creating exFAT volume with too small cluster size can collapse unallocated memory. (appeared at R0.12)
  Fixed wrong object name can be returned when read directory at Unicode cfg. (appeared at R0.12)
  Fixed large file allocation/removing on the exFAT volume collapses allocation bitmap. (appeared at R0.12)
  Fixed some internal errors in f_expand() and f_lseek(). (appeared at R0.12)
R0.12a (July 10, 2016)
  Added support for creating exFAT volume with some changes of f_mkfs().
  Added a file open method FA_OPEN_APPEND. An f_lseek() following f_open() is no longer needed.
  f_forward() is available regardless of _FS_TINY.
  Fixed f_mkfs() creates wrong volume. (appeared at R0.12)
  Fixed wrong memory read in create_name(). (appeared at R0.12)
  Fixed compilation fails at some configurations, _USE_FASTSEEK and _USE_FORWARD.
 楼主| 发表于 2016-9-9 09:51:09 | 显示全部楼层
本次升级依然是升级exFAT的相关问题。
GMT+8, 2026-10-25 03:17 , Processed in 0.144832 second(s), 27 queries .
