查看: 3007|回复: 3
[emWin] messagebox问题,请求帮忙!
发表于 2016-9-4 17:54:28 | 显示全部楼层 |阅读模式
mesagebox创建方法:
*       _MessageBox
* Function description
*   Creates and executes a modal message box
static void _MessageBox(const char * pText, const char * pCaption) {
  WM_HWIN hBox;
    WM_HWIN hItem;
  hBox = MESSAGEBOX_Create(pText, pCaption, 0);
    WM_SetWindowPos(hBox,0,40,160,80);
    FRAMEWIN_SetSkinClassic(hBox);
    FRAMEWIN_SetClientColor(hBox,GUI_BLACK);
    FRAMEWIN_SetFont(hBox,&ST12_Font);
    FRAMEWIN_SetTextColor(hBox,GUI_WHITE);
    hItem = WM_GetDialogItem(hBox,GUI_ID_TEXT0);
  WM_SetWindowPos(hItem, 2, 65,156,20);
    TEXT_SetBkColor(hItem,GUI_BLACK);
    TEXT_SetTextColor(hItem,GUI_WHITE);
    TEXT_SetFont(hItem,&ST12_Font);
    TEXT_SetTextAlign(hItem,TEXT_CF_HCENTER|TEXT_CF_VCENTER);
    hItem = WM_GetDialogItem(hBox,GUI_ID_OK);
    BUTTON_SetFont(hItem,&ST12_Font);
    BUTTON_SetText(hItem," 返  回 ");
    WM_SetWindowPos(hItem, 45, 86,70,25);
    WM_SetFocus(hItem);
  GUI_ExecCreatedDialog(hBox);
  WM_SetFocus(_hMenu);
  MENU_SetSel(_hMenu, -1);
调用:
/*********************************************************************桌面回调函数
*       _cbdesktop
*   Callback routine of client window which 'owns' the menu widget
*   and the status bar
static void _cbdesktop(WM_MESSAGE * pMsg) {
  int             Index;
  MENU_MSG_DATA * pData;
  switch (pMsg->MsgId)
        case WM_PAINT:
            _paint();
        case WM_MENU:
            pData = (MENU_MSG_DATA*)pMsg->Data.p;
            switch (pData->MsgType)
                case MENU_ON_ITEMACTIVATE:
                    // This message is send on highlighting a menu item
                case MENU_ON_ITEMPRESSED:
                    item_id = pData->ItemId;
                    switch(item_id)
                        case ID_MENU_MANGE_113:    {
                            _MessageBox("消息内容...","提示");
                            break;}
                default:
                    WM_DefaultProc(pMsg);
        default:
现在的问题是:执行菜单命令是调用了消息对话框,然后就没有按键反映了。按键任务函数再也进不去了。
按键任务函数:
***************************按键检测******************************************
void key_thread (void const *argument)
     static uint8_t n,pin_state[6];
    for (;;)
        for(n=0;n<KEY_COUNT;n++)
            if(GPIO_PinRead(KEY_PIN[n].Portnum,KEY_PIN[n].Pinnum) == 0)
                if(pin_state[n] == 1)
                    GUI_Delay(10);
                        switch(n)
                            case 0:    GUI_SendKeyMsg(GUI_KEY_UP,1);           break;
                            case 1:    GUI_SendKeyMsg(GUI_KEY_DOWN,1);        break;
                            case 2:    GUI_SendKeyMsg(GUI_KEY_RIGHT,1);            break;
                            case 3:    GUI_SendKeyMsg(GUI_KEY_LEFT,1);        break;
                            case 4:    GUI_SendKeyMsg(GUI_KEY_ENTER,1);    break;
                            case 5: GUI_SendKeyMsg(GUI_KEY_ESCAPE,1);    break;
                pin_state[n] = 0;
            else  pin_state[n] = 1;
        GUI_Delay(100);
请求各位帮忙,多谢!
发表于 2016-9-5 09:49:49 | 显示全部楼层
函数 GUI_ExecCreatedDialog(hBox);是执行阻塞式对话框,程序阻塞在这个里面了,你下面的这个聚焦函数  WM_SetFocus(_hMenu);没有得到执行。
 楼主| 发表于 2016-9-6 17:09:14 | 显示全部楼层
eric2013:函数 GUI_ExecCreatedDialog(hBox);是执行阻塞式对话框,程序阻塞在这个里面了,你下面的这个聚焦函数  WM_SetFocus(_hMenu);没有得到执行。
 (2016-09-05 09:49)
谢谢回复!
 楼主| 发表于 2016-9-6 17:24:36 | 显示全部楼层
已经解决!但是不知道所以然。
问题是是这样的:
按键检测中调用了GUI_SendKeyMsg()函数,这个函数使得按键检测任务被阻塞,换成GUI_StoreKeyMsg()函数就可以了。
但是这样又将
void GUIThread(const void* argument) {
  while (1) {
        WM_Paint(WM_HBKWIN);
        GUI_Exec();
        _copytolcd();
    GUI_Delay(100);     /* Nothing left to do for the moment ... Idle processing */
}这个任务给阻塞掉了,所以刷不了屏了。按键可以响应了,按回车键消息能够返回。却显示不了消息对话框。
这到底是因为什么?还是不明白。我在初始化gui的时候有这样的定义:GUITASK_SetMaxTask(1);
目前只能这样解决:
    GUI_Exec();
    _copytolcd();
在执行消息对话框函数之前先调用一下刷屏函数。
此外我的液晶驱动是这样的:4位灰度屏,当成黑白屏使用。
static void _SetPixelIndex(GUI_DEVICE * pDevice, int x, int y, int PixelIndex) {
    if(PixelIndex)    lcd_data[y][x/8] |=  (0x80>>(x%8));
    else                         lcd_data[y][x/8] &= (~(0x80>>(x%8)));
将数据先写到内存里面,_copytolcd();负责向硬件写数据。
GMT+8, 2026-11-23 08:46 , Processed in 0.320327 second(s), 27 queries .
