查看: 3324|回复: 1
[emWin] button按钮焦点如何退出?
螺旋是时间最美的曲线。
发表于 2016-8-23 09:17:03 | 显示全部楼层 |阅读模式
我创建窗口如下:
  { WINDOW_CreateIndirect, "Window_S4", ID_WINDOW_3, 0, 80, 310, 180, 0, 0x0, 0 },
  { EDIT_CreateIndirect, "Edit_old", ID_EDIT_0, 20, 60, 110, 30, 0, 0x64, 0 },
  { EDIT_CreateIndirect, "Edit_PS1", ID_EDIT_1, 20, 110, 110, 30, 0, 0x64, 0 },
  { BUTTON_CreateIndirect, "确认",           ID_BUTTON_0, 45, 145, 60,25, 0,0},
  { EDIT_CreateIndirect, "Edit_old", ID_EDIT_2, 175, 60, 110, 30, 0, 0x64, 0 },
  { EDIT_CreateIndirect, "Edit_PS1", ID_EDIT_3, 175, 110, 110, 30, 0, 0x64, 0 },
  { BUTTON_CreateIndirect, "确认",           ID_BUTTON_1, 200, 145, 60,25, 0,0},
  { TEXT_CreateIndirect, "登录密码", ID_TEXT_0, 40, 10, 68, 20, 0, 0x64, 0 },//Change password
  { TEXT_CreateIndirect, "原密码", ID_TEXT_1, 20, 40, 60, 20, 0, 0x64, 0 },//OLD
  { TEXT_CreateIndirect, "新密码", ID_TEXT_2, 20, 92, 60, 20, 0, 0x64, 0 },//1
  { TEXT_CreateIndirect, "控制密码", ID_TEXT_3, 192, 10, 165, 20, 0, 0x64, 0 },//Change password
  { TEXT_CreateIndirect, "原密码", ID_TEXT_4, 175,40, 60, 20, 0, 0x64, 0 },//OLD
  { TEXT_CreateIndirect, "新密码", ID_TEXT_5, 175,92, 60, 20, 0, 0x64, 0 },//1
焦点按照以上顺序切换,但当焦点在BUTTON时,按返回按键将焦点聚焦到本窗口,在聚焦到EDIT时,
发现焦点还在BUTTON没有退出焦点,但是没有聚焦框,TAB无法上下切换,如何退出焦点可以TAB切换?
发表于 2016-8-23 10:19:17 | 显示全部楼层
这个不太清楚了,还没有测试过退出焦点的情况。
GMT+8, 2026-11-23 08:45 , Processed in 0.188906 second(s), 24 queries .
