查看: 5405|回复: 2
TI-RTOS例程中,请问任务怎么实现切换呢,或者怎样改变任务的优先级
发表于 2016-8-8 17:56:57 | 显示全部楼层 |阅读模式
这是我写的代码
void task1_Fxn(UArg a0, UArg a1)
    ti_sysbios_knl_Task_Handle Task111Handle;
     while(1)
        PIN_setOutputValue(PINHandle,PIN_ID(25),1);//LED 1
        CPUdelay(5000000);
        //Task_sleep(500/ Clock_tickPeriod);
       Task_setPri(Task111Handle,0);
void task2_Fxn(UArg a0, UArg a1)
    while(1)
       PIN_setOutputValue(PINHandle, PIN_ID(25),0);        //LED 0
       CPUdelay(5000000);
       Task_setPri(Task111Handle,2);
函数名:主函数
传入参数:NONE
传出参数:NONE
//const char echoPrompt[] = "\fEchoing characters:\r\n";
int main(void)
    PIN_init(ledPinTable);    //Gpio_ini
//    UART_init();              //USart ini
    Task_Params_init(&taskParams1);                     //预定义任务配置信息
    taskParams1.stack = myTaskStack1;                    //初始化堆空间首地址
    taskParams1.stackSize = sizeof(myTaskStack1);       //初始化堆空间大小
    taskParams1.priority=2;                             //任务优先级 0
    taskParams1.instance->name = "task1_Fxn";
    //taskParams1.arg0 = (UInt)1000000;
    //Task_construct(&myTask1, task1_Fxn, &taskParams1, NULL);
    Task_create(task1_Fxn,&taskParams1, NULL);
    Task_Params_init(&taskParams2);                     //预定义任务配置信息
    taskParams2.stack = myTaskStack2;                    //初始化堆空间首地址
    taskParams2.stackSize = sizeof(myTaskStack2);       //初始化堆空间大小
    taskParams2.priority=1;                             //任务优先级 0
    taskParams2.instance->name = "task2_Fxn";
    //taskParams2.arg0 = (UInt)1000000;
    //Task_construct(&myTask2, task2_Fxn, &taskParams2, NULL);
    Task_create(task2_Fxn,&taskParams2, NULL);
    BIOS_start();
编译过没有错误,该定义的都定义过了,请教大神们,如何实现任务切换,不胜感激!
发表于 2016-8-8 18:06:11 | 显示全部楼层
TI的没有用过,帮顶。
 楼主| 发表于 2016-8-9 09:16:23 | 显示全部楼层
求解答!!!
GMT+8, 2026-10-24 19:10 , Processed in 0.193413 second(s), 24 queries .
