查看: 5921|回复: 5
TIM9作PWM输入捕获时定时器会自动停止。
发表于 2016-8-1 09:03:31 | 显示全部楼层 |阅读模式
不知道为什么,我用tim9做PWM输入捕获时,定时器会自己停止。哪位大神帮忙看看呀?
中断里面做PWM频率输出和占空比输出。每次进入中断都要重新打开定时器TIM_Cmd(ADVANCE_TIM, ENABLE);,不然捕获为零。
void  ADVANCE_TIM_IRQHandler (void)
  /* Çå3y¶¨ê±Æ÷2¶»ñ/±è½Ï1ÖD¶Ï */
  TIM_ClearITPendingBit(ADVANCE_TIM, TIM_IT_CC1);
  /* »ñè¡êäèë2¶»ñÖμ */
  IC1Value = TIM_GetCapture1(ADVANCE_TIM);
  IC2Value = TIM_GetCapture2(ADVANCE_TIM);
  //printf("IC1Value = %d  IC2Value = %d ",IC1Value,IC2Value);
  if (IC1Value != 0)
    /* Õ¼¿Õ±è¼ÆËã */
    DutyCycle = (float)(IC2Value * 100) / IC1Value;
    /* ÆμÂê¼ÆËã */
    Frequency = 180000000/30/(float)IC1Value;
        printf("Õ¼¿Õ±è£o%0.2f%%   ÆμÂê£o%0.2fHz\n",DutyCycle,Frequency);
    DutyCycle = 0;
    Frequency = 0;
定时器设置如下:
static void TIMx_GPIO_Config(void)
    /*¶¨òåò»¸öGPIO_InitTypeDefààDíμĽá11ìå*/
    /*¿aÆôLEDÏà1ØμÄGPIOíaéèê±Öó*/
//    RCC_AHB1PeriphClockCmd (GENERAL_OCPWM_GPIO_CLK, ENABLE);
    RCC_AHB1PeriphClockCmd (ADVANCE_ICPWM_GPIO_CLK, ENABLE);
    /* ¶¨ê±Æ÷¸′óÃòy½Å */
//    GPIO_PinAFConfig(GENERAL_OCPWM_GPIO_PORT,GENERAL_OCPWM_PINSOURCE,GENERAL_OCPWM_AF);
    GPIO_PinAFConfig(ADVANCE_ICPWM_GPIO_PORT,ADVANCE_ICPWM_PINSOURCE,ADVANCE_ICPWM_AF);
    /* í¨óö¨ê±Æ÷PWMêä3öòy½Å */
//    GPIO_InitStructure.GPIO_Pin = GENERAL_OCPWM_PIN;
//    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
//    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
//    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
//    GPIO_Init(GENERAL_OCPWM_GPIO_PORT, &GPIO_InitStructure);
    /* ¸ß¼¶¿ØÖƶ¨ê±Æ÷PWMêäèë2¶»ñòy½Å */
    GPIO_InitStructure.GPIO_Pin = ADVANCE_ICPWM_PIN;
    GPIO_Init(ADVANCE_ICPWM_GPIO_PORT, &GPIO_InitStructure);
static void TIMx_NVIC_Configuration(void)
    NVIC_InitTypeDef NVIC_InitStructure;
    // éèÖÃÖD¶Ï×éÎa0
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        // éèÖÃÖD¶Ïà′Ô′
    NVIC_InitStructure.NVIC_IRQChannel = ADVANCE_TIM_IRQn;
        // éèÖÃÇàÕ¼óÅÏè¼¶
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
      // éèÖÃ×óóÅÏè¼¶
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
static void TIM_PWMINPUT_Config(void)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_ICInitTypeDef  TIM_ICInitStructure;
    // ¿aÆôTIMx_CLK,x[1,8]
  RCC_APB2PeriphClockCmd(ADVANCE_TIM_CLK, ENABLE);
  TIM_TimeBaseStructure.TIM_Period = 0xFFFF-1;
    // ¸ß¼¶¿ØÖƶ¨ê±Æ÷ê±ÖóÔ′TIMxCLK = HCLK=180MHz
    // é趨¶¨ê±Æ÷ÆμÂêÎa=TIMxCLK/(TIM_Prescaler+1)=100KHz
  TIM_TimeBaseStructure.TIM_Prescaler = 30-1;
  // ¼Æêy·½ê½
  TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
    // 3õê¼»ˉ¶¨ê±Æ÷TIMx, x[1,8]
    TIM_TimeBaseInit(ADVANCE_TIM, &TIM_TimeBaseStructure);
    /* IC12¶»ñ£oéÏéyÑØ′¥·¢ TI1FP1 */
  TIM_ICInitStructure.TIM_Channel = ADVANCE_IC1PWM_CHANNEL;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(ADVANCE_TIM, &TIM_ICInitStructure);
//    /* IC22¶»ñ£oϽμÑØ′¥·¢ TI1FP2 */
//    TIM_ICInitStructure.TIM_Channel = ADVANCE_IC2PWM_CHANNEL;
//  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
//  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_IndirectTI;
//  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
//  TIM_ICInitStructure.TIM_ICFilter = 0x0;
//  TIM_PWMIConfig(ADVANCE_TIM, &TIM_ICInitStructure);
    /* Ñ¡Ôñ¶¨ê±Æ÷êäèë′¥·¢: TI1FP1 */
  TIM_SelectInputTrigger(ADVANCE_TIM, TIM_TS_TI1FP1);
  /* Ñ¡Ôñ′óÄ£ê½: ¸′λÄ£ê½ */
  TIM_SelectSlaveMode(ADVANCE_TIM, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(ADVANCE_TIM,TIM_MasterSlaveMode_Enable);
  /* ê1Äü¸ß¼¶¿ØÖƶ¨ê±Æ÷ */
  /* ê1Äü2¶»ñ/±è½Ï2ÖD¶ÏÇëÇó */
  TIM_ITConfig(ADVANCE_TIM, TIM_IT_CC1, ENABLE);
void TIMx_Configuration(void)
    TIMx_GPIO_Config();
    TIMx_NVIC_Configuration();
    //TIM_PWMOUTPUT_Config();
    TIM_PWMINPUT_Config();
与之相关的是TIM3输出一个控制一个模块使他输入一个PWM波形用TIM9来测量。
 楼主| 发表于 2016-8-1 09:07:28 | 显示全部楼层
源代码如下 TIM9PWM输入捕获.rar (8.56 MB, 下载次数: 173)
发表于 2016-8-1 13:04:58 | 显示全部楼层
帮顶,下载下来看了一下,没有发现什么问题,找官方标准固件库里面的定时器捕获例子对比下,看看是不是那个选项少配置什么了。
发表于 2020-8-3 22:30:14 | 显示全部楼层
问题解决了吗?楼主可以说说
发表于 2020-8-4 08:21:10 | 显示全部楼层
erlun 发表于 2020-8-3 22:30
问题解决了吗?楼主可以说说
他这个是用的从机触发捕获,太麻烦了,用的TI1FP1
饶了非常大一个圈来使用
你应该直接使用IC输入捕获即可,参考案例,我们V6论坛置顶帖的标准库网盘,红色接收例子即可,用的这个方案:
GMT+8, 2026-11-25 17:02 , Processed in 0.391937 second(s), 27 queries .
