查看: 5378|回复: 0
[FatFs] FatFS升级到0.12a版本(更新日期2016-07-10)
发表于 2016-7-17 10:08:49 | 显示全部楼层 |阅读模式
ff12a.zip (2.33 MB, 下载次数: 79)
更新记录:
R0.12a (July 10, 2016)
  Added support for creating exFAT volume with some changes of f_mkfs().
  Added a file open method FA_OPEN_APPEND. An f_lseek() following f_open() is no longer needed.
  f_forward() is available regardless of _FS_TINY.
  Fixed f_mkfs() creates wrong volume.
  Fixed compilation fails at some configurations, _USE_FASTSEEK and _USE_FORWARD.
  Fixed wrong memory read in create_name().
R0.12 (April 12, 2016)
  Added support for exFAT file system. (_FS_EXFAT)
  Added f_expand(). (_USE_EXPAND)
  Changed some members in FINFO structure and behavior of f_readdir().
  Added an option _USE_CHMOD.
  Removed an option _WORD_ACCESS.
  Fixed errors in the case conversion table of Unicode (cc*.c).
GMT+8, 2026-10-24 20:16 , Processed in 0.117975 second(s), 27 queries .
