查看: 4509|回复: 1
[emWin] 求助:裸机程序+STemWin怎么不能画竖线?中英文字符显示正常
发表于 2016-6-29 20:27:25 | 显示全部楼层 |阅读模式
STM32F103RCT6裸机程序+STemWin 5.28, 2.0寸 ILI9225G 176*220液晶屏,显示方向:横屏(220*176)。
用LCD驱动直接画线,画矩形,位图,都正常。
但是emwin不能画圆,不能画矩形,也不能画竖线,画出来只显示成水平线,显示BMP位图也是乱的,呈撕裂模样看不清。但是显示中英文字符是正常的,画水平线也是正常的。
请问这是怎么回事?
GUI驱动只添加了打点函数:
static void LcdWriteReg(U16 Data) {
  // ... TBD by user
  LCD_WR_REG(Data);
static void LcdWriteData(U16 Data) {
  // ... TBD by user
  LCD_WR_DATAX(Data);
static void LcdWriteDataMultiple(U16 * pData, int NumItems) {
  while (NumItems--) {
    // ... TBD by user
LCD_WR_DATAX(*pData++);
static void LcdReadDataMultiple(U16 * pData, int NumItems) {
    // ... TBD by user
*pData++ = LCD_RD_DATA();
void LCD_X_Config(void) {
  GUI_DEVICE * pDevice;
  CONFIG_FLEXCOLOR Config = {0};
  GUI_PORT_API PortAPI = {0};
  // Set display driver and color conversion
  pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
  // Display driver configuration, required for Lin-driver
  LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
  LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
  // Orientation
  Config.Orientation = GUI_SWAP_XY;// | GUI_MIRROR_Y;
  GUIDRV_FlexColor_Config(pDevice, &Config);
  // Set controller and operation mode
  PortAPI.pfWrite16_A0  = LcdWriteReg;
  PortAPI.pfWrite16_A1  = LcdWriteData;
  PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
  PortAPI.pfReadM16_A1  = LcdReadDataMultiple;
  GUIDRV_FlexColor_SetFunc(pDevice, &amportAPI, GUIDRV_FLEXCOLOR_F66708, GUIDRV_FLEXCOLOR_M16C0B16);
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
  int r;
  (void) LayerIndex;
  (void) pData;
  switch (Cmd) {
  case LCD_X_INITCONTROLLER: {
    // Called during the initialization process in order to set up the
    // display controller and put it into operation. If the display
    // controller is not initialized by any external routine this needs
    // to be adapted by the customer...
LCD_Init();
    return 0;
  default:
    r = -1;
  return r;
发表于 2016-7-1 07:26:08 | 显示全部楼层
emWin自带的驱动方式,我没有通过,你有时间可以使用我们emWin教程里面的通用移植方式。
GMT+8, 2026-11-23 08:35 , Processed in 0.581973 second(s), 24 queries .
