查看: 6126|回复: 1
[有问必答] 各位大侠帮个忙看看ADC
发表于 2016-6-19 16:31:23 | 显示全部楼层 |阅读模式
我想用TIM2 来触发ADC 采样,我这样设置怎么都不进行ADC 采样呢。谢谢大家了
void bsp_adc(void)
    ADC_InitTypeDef       ADC_InitStructure;
    ADC_CommonInitTypeDef ADC_CommonInitStructure;
    DMA_InitTypeDef       DMA_InitStructure;
    GPIO_InitTypeDef      GPIO_InitStructure;
    NVIC_InitTypeDef        NVIC_InitStructure;
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    /* Enable peripheral clocks */
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC |RCC_AHB1Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);            //使能TIM2时钟
    /* Time base configuration */
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Period = 168000000/g_SampleFreqTable[TimeBaseId][0] - 1;;
    TIM_TimeBaseStructure.TIM_Prescaler = g_SampleFreqTable[TimeBaseId][1]-1; ;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
    /* Configure ADC Channel 12 pin as analog input */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1 |GPIO_Pin_2 |GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* DMA2 Stream0 channel0 configuration */
    DMA_InitStructure.DMA_Channel = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_Buffer;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize = ADC_Buffer_Size;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    /* Enable the DMA7 Interrupt*/
    NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    /* DMA2_Stream0 enable */
    DMA_ClearITPendingBit(DMA2_Stream0,DMA_IT_TC);
    DMA_ITConfig(DMA2_Stream0,DMA_IT_TC,ENABLE);
    DMA_Cmd(DMA2_Stream0, ENABLE);
    /* Enable ADC1 DMA */
    ADC_DMACmd(ADC1, ENABLE);
    /*  ADCs configuration: triple interleaved with 5cycles delay to reach 6Msps  */
    /* ADC Common configuration *************************************************/
    ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
    ADC_CommonInit(&ADC_CommonInitStructure);
    /* ADC1 regular channel 12 configuration ************************************/
      ADC_StructInit(&ADC_InitStructure);
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;  /*多通道必须enable*/
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;//;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_TRGO;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfConversion = 2;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 0, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_15Cycles);
     /* Enable DMA request after last transfer (Single-ADC mode) *********************/
      ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
    /* Enable ADC1 **************************************************************/
    ADC_Cmd(ADC1, ENABLE);
#if 1
     /*TM2 中断配置*/
    NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;/*抢占优先级*/
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;/*响应优先级*/
    NVIC_Init(&NVIC_InitStructure);/*配置中断分组,并使能中断*/
    TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);                      //使能TIM2中断
        TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);           //选择TIM2的update事件更新为触发
    /* TIM counter enable */
    TIM_Cmd(TIM2,ENABLE);
    /* TIM1 main Output Enable */
//    TIM_CtrlPWMOutputs(TIM1,ENABLE);
#endif
//    ADC_SoftwareStartConv(ADC1);
发表于 2016-6-20 09:39:37 | 显示全部楼层
1.  你确定你的触发是用的TRGO事件,而不是CC?,当然,两个都是可以的。
2.  连续转换模式也使能下。
另外就是你先测试ADC1的单通道定时器触发,然后再测试多通道试试。
GMT+8, 2026-11-28 14:00 , Processed in 0.161568 second(s), 30 queries .
