查看: 4125|回复: 7
[其它] 请教一个关于rtx的问题
发表于 2016-5-23 15:53:07 | 显示全部楼层 |阅读模式
我用rtx和fatfs的时候开启多任务,经常出现死机的情况,我看安福莱的例子里也有好多没有使用多任务支持.
/* Sample code of OS dependent controls for FatFs                         */
/* (C)ChaN, 2014                                                          */
#include "ff.h"
#if _FS_REENTRANT
/* Create a Synchronization Object
/* This function is called in f_mount() function to create a new
/  synchronization object, such as semaphore and mutex. When a 0 is returned,
/  the f_mount() function fails with FR_INT_ERR.
_SYNC_t fs_MUX;
int ff_cre_syncobj (    /* 1:Function succeeded, 0:Could not create the sync object */
    BYTE vol,            /* Corresponding volume (logical drive number) */
    _SYNC_t *sobj        /* Pointer to return the created sync object */
    int ret;
//    *sobj = CreateMutex(NULL, FALSE, NULL);        /* Win32 */
//    ret = (int)(*sobj != INVALID_HANDLE_VALUE);
//    *sobj = SyncObjects[vol];            /* uITRON (give a static sync object) */
//    ret = 1;                            /* The initial value of the semaphore must be 1. */
//    *sobj = OSMutexCreate(0, &err);        /* uC/OS-II */
//    ret = (int)(err == OS_NO_ERR);
//    *sobj = xSemaphoreCreateMutex();    /* FreeRTOS */
//    ret = (int)(*sobj != NULL);
    os_mut_init(sobj);
    ret = (int)(*sobj != 0);
    return ret;
/* Delete a Synchronization Object                                        */
/* This function is called in f_mount() function to delete a synchronization
/  object that created with ff_cre_syncobj() function. When a 0 is returned,
int ff_del_syncobj (    /* 1:Function succeeded, 0:Could not delete due to any error */
    _SYNC_t sobj        /* Sync object tied to the logical drive to be deleted */
    int ret;
//    ret = CloseHandle(sobj);    /* Win32 */
//    ret = 1;                    /* uITRON (nothing to do) */
//    OSMutexDel(sobj, OS_DEL_ALWAYS, &err);    /* uC/OS-II */
//  vSemaphoreDelete(sobj);        /* FreeRTOS */
//    ret = 1;
    sobj = 0;
    ret = 1;
    return ret;
/* Request Grant to Access the Volume                                     */
/* This function is called on entering file functions to lock the volume.
/  When a 0 is returned, the file function fails with FR_TIMEOUT.
int ff_req_grant (    /* 1:Got a grant to access the volume, 0:Could not get a grant */
    _SYNC_t sobj    /* Sync object to wait */
    int ret;
//    ret = (int)(WaitForSingleObject(sobj, _FS_TIMEOUT) == WAIT_OBJECT_0);    /* Win32 */
//    ret = (int)(wai_sem(sobj) == E_OK);            /* uITRON */
//    OSMutexPend(sobj, _FS_TIMEOUT, &err));        /* uC/OS-II */
//    ret = (int)(xSemaphoreTake(sobj, _FS_TIMEOUT) == pdTRUE);    /* FreeRTOS */
    OS_RESULT result = os_mut_wait(sobj,_FS_TIMEOUT);
    if(result == OS_R_TMO)
        return 0;
        return 1;
/* Release Grant to Access the Volume                                     */
/* This function is called on leaving file functions to unlock the volume.
void ff_rel_grant (
    _SYNC_t sobj    /* Sync object to be signaled */
//    ReleaseMutex(sobj);        /* Win32 */
//    sig_sem(sobj);            /* uITRON */
//    OSMutexPost(sobj);        /* uC/OS-II */
//    xSemaphoreGive(sobj);    /* FreeRTOS */
    os_mut_release(sobj);
#endif
#if _USE_LFN == 3    /* LFN with a working buffer on the heap */
/* Allocate a memory block                                                */
/* If a NULL is returned, the file function fails with FR_NOT_ENOUGH_CORE.
void* ff_memalloc (    /* Returns pointer to the allocated memory block */
    UINT msize        /* Number of bytes to allocate */
    return malloc(msize);    /* Allocate a new memory block with POSIX API */
/* Free a memory block                                                    */
void ff_memfree (
    void* mblock    /* Pointer to the memory block to free */
    free(mblock);    /* Discard the memory block with POSIX API */
#endif
 楼主| 发表于 2016-5-23 15:54:02 | 显示全部楼层
我这么设计有问题吗?
发表于 2016-5-23 16:00:19 | 显示全部楼层
RTX配套fatfs多不爽,上专业配套的FlashFS,用起来爽爽的 ,缺点是FlashFS文件名不支持中文。
 楼主| 发表于 2016-5-24 09:46:04 | 显示全部楼层
eric2013:
发表于 2016-5-24 10:57:02 | 显示全部楼层
回 mewan 的帖子
mewan:我使用RL-flash出现这个问题,要怎么解决 (2016-05-24 09:46)
删掉MDK原有注册,使用这个帖子里面的第二个注册机:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=2346
 楼主| 发表于 2016-5-24 11:21:11 | 显示全部楼层
eric2013:删掉MDK原有注册,使用这个帖子里面的第二个注册机:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=2346 (2016-05-24 10:57)
使用rlflash怎么获取文件的大小啊?
 楼主| 发表于 2016-5-24 14:08:18 | 显示全部楼层
回 mewan 的帖子
mewan:使用rlflash怎么获取文件的大小啊? (2016-05-24 11:21)
使用rlflash后,用的是fs_cm3.lib替换fsn_cm3.lib后,但是还是不支持长文件名,还需要修改什么地方吗?
发表于 2016-5-24 16:14:45 | 显示全部楼层
回 mewan 的帖子
mewan:使用rlflash后,用的是fs_cm3.lib替换fsn_cm3.lib后,但是还是不支持长文件名,还需要修改什么地方吗? (2016-05-24 14:08)
例子:https://forum.anfulai.cn/forum.php?mod=viewthread&tid=15790
GMT+8, 2026-11-23 08:36 , Processed in 0.923605 second(s), 27 queries .
