查看: 5960|回复: 3
[有问必答] ADC双通道采集数据,数据存储位置?
学习
发表于 2016-5-18 15:59:06 | 显示全部楼层 |阅读模式
我用的ADC+DMA模式双通道采集数据
采集后的数据存储在数组中
现在想分别调用两个通道采集的缓存数据
怎么调用呢?
大神们有什么推荐的例程和方法吗?
学习
 楼主| 发表于 2016-5-18 15:59:33 | 显示全部楼层
void bsp_InitADC(void)
        ADC_InitTypeDef       ADC_InitStructure;
    ADC_CommonInitTypeDef ADC_CommonInitStructure;
    DMA_InitTypeDef       DMA_InitStructure;
    GPIO_InitTypeDef      GPIO_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
    NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn;//
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOF |RCC_AHB1Periph_GPIOC, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 |
                                                   RCC_APB2Periph_ADC3, ENABLE);
        DMA_InitStructure.DMA_Channel = DMA_Channel_2;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_ADDRESS;
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC3ConvertedValue;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_InitStructure.DMA_BufferSize = SAMPLE_COUNT*2;//
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
        DMA_Init(DMA2_Stream1, &DMA_InitStructure);
        DMA_ClearITPendingBit(DMA2_Stream1, DMA_IT_HTIF1);
        DMA_ClearITPendingBit(DMA2_Stream1, DMA_IT_TCIF1);
        DMA_ITConfig(DMA2_Stream1, DMA_IT_HT, ENABLE);
        DMA_ITConfig(DMA2_Stream1, DMA_IT_TC, ENABLE);
        DMA_Cmd(DMA2_Stream1, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOF, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;//ADC_TwoSamplingDelay_8Cycles
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8 ;//ADC_Prescaler_Div2
    ADC_CommonInit(&ADC_CommonInitStructure);
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;//
        ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//ENABLE DISABLE
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC3;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
        ADC_InitStructure.ADC_NbrOfConversion = 2;
        ADC_Init(ADC3, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC3, ADC_Channel_10, 1, ADC_SampleTime_3Cycles);
        ADC_RegularChannelConfig(ADC3, ADC_Channel_13, 2, ADC_SampleTime_3Cycles);
        /* 使能 ADC3 DMA */
        ADC_DMACmd(ADC3, ENABLE);
      ADC_AnalogWatchdogThresholdsConfig(ADC3, ThresholdHigh, ThresholdLow);//
    ADC_AnalogWatchdogSingleChannelConfig(ADC3, ADC_Channel_10);//10
    ADC_AnalogWatchdogCmd(ADC3, ADC_AnalogWatchdog_SingleRegEnable);
    ADC_ITConfig(ADC3, ADC_IT_AWD, ENABLE);
        /* 使能DMA请求 (多ADC模式) --------------------------------------------------*/
        ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
        /* Enable ADC3 --------------------------------------------------------------*/
        ADC_Cmd(ADC3, ENABLE);
        /**定时器配置********************************************************************/
        TIM1_Config();
发表于 2016-5-19 21:53:44 | 显示全部楼层
在CDSN上搜索基于stm32f4的定时器触发双ADC多通道规则同步采样,可以参考一下!
发表于 2016-5-19 22:45:21 | 显示全部楼层
看V5板子的ADC例子就行,在基础篇里面。
GMT+8, 2026-11-28 14:01 , Processed in 0.842649 second(s), 24 queries .
