查看: 5614|回复: 1
[有问必答] STM32F407 USART1发送字符串乱码
发表于 2016-4-28 09:49:12 | 显示全部楼层 |阅读模式
int main(void)   //主函数
uint8_t *str;
       while(1)
              str = "Welcome to STM321111";
             TData(str, 20);
void TData(uint8_t *_usBuf, uint8_t _usLen)   //数据发送函数
    uint8_t  Tx_Status, Txread, Txwrite, Txcounter;
    uint16_t  i;
    Txread = p_uart.Tx_read;
    Txcounter = p_uart.Tx_counter;
    //将待发送数据缓冲区写入UART发送数据缓冲区
    for(i=0; i<_usLen; i++)
        if(++Txread >= USART1_TX_BUF_SIZE)
            Txread = 0;
        if(++Txcounter >= USART1_TX_BUF_SIZE)  //判断发送缓冲区数据个数
            Txcounter = 0;
        p_uart.pTxBuf[p_uart.Tx_write] = _usBuf;
        if(++p_uart.Tx_write >= USART1_TX_BUF_SIZE)
            p_uart.Tx_write = 0;
        p_uart.Tx_counter++;
    USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)        //中断函数
        USART_ClearITPendingBit(USART1, USART_IT_TXE);
        if(p_uart.Tx_read == p_uart.Tx_write)            //没有新数据
            USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
            USART_ITConfig(USART1, USART_IT_TC, ENABLE);
            USART_SendData(USART1, p_uart.pTxBuf[p_uart.Tx_read]);
            while(USART_GetFlagStatus(USART1, USART_FLAG_TXE == RESET));
            if(++p_uart.Tx_read >= USART1_TX_BUF_SIZE)
              p_uart.Tx_read = 0;
            p_uart.Tx_counter--;
else if(USART_GetITStatus(USART1, USART_IT_TC) !=RESET)
      USART_ClearITPendingBit(USART1, USART_IT_TC);    //清除发送完成标志位
        USART_ITConfig(USART1, USART_IT_TC, DISABLE);   //关闭发送完成中断
            while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
                p_uart.Tx_read = 0;
发表于 2016-4-28 11:56:17 | 显示全部楼层
乱码一般是波特率问题,是不是板子的波特率跟电脑端的波特率一致,另外重要的一点是,你是在往电脑端发送数据吧,看看串口线是否好用。
GMT+8, 2026-11-28 13:59 , Processed in 0.287474 second(s), 24 queries .
