查看: 4832|回复: 3
[emWin] 有没有做FATFS和emwin的choosefile对话框的文件浏览器
发表于 2016-4-22 14:52:36 | 显示全部楼层 |阅读模式
有没有相关的FATFS和emwin的choosefile对话框的文件浏览器的例子?
发表于 2016-4-23 00:57:54 | 显示全部楼层
 楼主| 发表于 2016-4-25 09:46:35 | 显示全部楼层
eric2013:有的,参考emWin综合例子:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=1139 (2016-04-23 00:57)
我用那个file浏览的程序,但是触摸不响应,不知道是怎么回事?
没有使用操作系统,
void OnICON00Clicked(unsigned char _ucDriveID)
    const char        acMask[]            = "*.*";
    CHOOSEFILE_INFO   Info                = { 0 };
    WM_HWIN           hWin;
    int               r;
    char             acDir[_MAX_PATH]     = "0:";
    char const      * apDrives[1]         = { 0 };
    FRAMEWIN_SetDefaultFont(GUI_FONT_20_ASCII);
    FRAMEWIN_SetDefaultTextAlign(GUI_TA_HCENTER);
//    LISTVIEW_SetDefaultFont(&GUI_FontHZ_SimSun_16);
    HEADER_SetDefaultFont(GUI_FONT_16_ASCII);
    BUTTON_SetDefaultFont(GUI_FONT_16_ASCII);
        FS_SD        0
        FS_NAND        1
        FS_USB        2
    acDir[0] = _ucDriveID + 0x30 - 1;
    apDrives[0] = acDir;
    Info.pfGetData = _GetData2;
    Info.pMask     = acMask;
    while (1)
        // ½«°′Å¥éèÖÃμ½¶Ô»°¿òμÄéÏÃæ
        // CHOOSEFILE_SetTopMode(Cnt % 2);
        CHOOSEFILE_SetTopMode(1);
        hWin = CHOOSEFILE_Create(0,            //Handle of parent window.
                                 0,                    //X position in pixels of the  dialog in clie nt coordinates.
                                 0,                    //Y position in pixels of the  dialog in client coordinates.
                                 LCD_GetXSize(),        //X-size of the dialog in pixels.
                                 LCD_GetYSize(),       //Y-size of the dialog in pixels
                                 apDrives,                //Pointer to an array of strings containing the root directories to be used.
                                 GUI_COUNTOF(apDrives),//Number of root directories.
                                 0,                    //Initial index of the root directory to be used.
                                 "File Dialog",        //Title to be shown in the title bar.
                                 0,                    //Additional flags for the FRAMEWIN widget.
                                 &Info);               //Pointer to a CHOOSEFILE_INFO structure.
        CHOOSEFILE_SetButtonText(hWin, CHOOSEFILE_BI_CANCEL, "Close");
        GUI_Exec();
        GUI_TOUCH_Exec();
        r = GUI_ExecCreatedDialog(hWin);
        // óé case GUI_ID_OK: GUI_EndDialog(hWin, 0);
        if (r == 0)
            //μã»÷áËArchiveêôDÔμÄÎļt »á½øèëμ½Õaàò2¾íêÇË죬¿éòÔ
            //ÔúÕaàï½øèëí¼Æ¬ÏÔê¾£¬MP32¥·Åμè1|Äü¡£
            hWin = MESSAGEBOX_Create(Info.pRoot, "File:", 0);
            GUI_Delay(2000);
            WM_DeleteWindow(hWin);
        // óécase GUI_ID_CANCEL: GUI_EndDialog(hWin, 1);
            //OnICON00 = 0;
        GUI_Exec();
        GUI_TOUCH_Exec();
发表于 2016-4-26 00:58:21 | 显示全部楼层
回 mewan 的帖子
mewan:我用那个file浏览的程序,但是触摸不响应,不知道是怎么回事?
没有使用操作系统,
....... (2016-04-25 09:46)
将游标显示出来,看看是怎么个情况。
GMT+8, 2026-11-23 08:15 , Processed in 1.154197 second(s), 24 queries .
