查看: 5248|回复: 4
[RL-RTX] 自己写的LEd闪烁程序有问题,
发表于 2016-4-20 13:35:20 | 显示全部楼层 |阅读模式
#include "includes.h"
static void LEDtwinkleTask(void);
__task void Taskstart(void);
__task void Taskcreat(void);
__task void LEDtwinkle11111Task(void);
                                             ±äá¿
static uint64_t LEDtwinkleTaskStk[256/8]; //èÎÎñÕ»
static uint64_t TaskstartStk[256/8];
static uint64_t TaskcreatStk[256/8];
static uint64_t LEDtwinkle11111TaskStk[256/8]; /* èÎÎñÕ» */
OS_TID HandleLEDtwinkleTask = NULL;
OS_TID HandleLEDtwinkle11111Task = NULL;
*    oˉ êy Ãû: main
*    1|ÄüËμÃ÷: ±ê×¼c3ìDòèë¿ú¡£
*    DΠ   2Î: ÎT
*    ·μ »Ø Öμ: ÎT
int main (void)
    /* 3õê¼»ˉíaéè */
     LED_Init();
  os_sys_init_user (Taskstart,         /* èÎÎñoˉêy           Æô¶ˉèÎÎñ*/
                      3,                        /* èÎÎñóÅÏè¼¶ */
                     &TaskstartStk,         /* èÎÎñÕ» */
                     sizeof(TaskstartStk)); /* èÎÎñÕ»′óD¡£¬μ¥λ×Ö½úêy */
    while(1);
Taskcreat();
    while(1)
os_dly_wait(10);
HandleLEDtwinkleTask=os_tsk_create_user(LEDtwinkleTask,              //èÎÎñoˉêy
                                         1,                          //èÎÎñóÅÏè¼¶
                                          &LEDtwinkleTaskStk,          //èÎÎñÕ»
                                          sizeof(LEDtwinkleTaskStk)); //èÎÎñÕ»′óD¡£¬μ¥λ×Ö½úêy
HandleLEDtwinkle11111Task=os_tsk_create_user(LEDtwinkle11111Task,              //èÎÎñoˉêy
                                         2,                          //èÎÎñóÅÏè¼¶
                                         &LEDtwinkle11111TaskStk,          //èÎÎñÕ»
                                    sizeof(LEDtwinkle11111TaskStk)); //èÎÎñÕ»′óD¡£¬μ¥λ×Ö½úêy
os_dly_wait(10);
*    oˉ êy Ãû: LEDtwinkleTask
*    1|ÄüËμÃ÷: LEDéá˸
*    DΠ   2Î: ÎT
*    ·μ »Ø Öμ: ÎT
*   óÅ Ïè ¼¶: 1
__task void LEDtwinkleTask(void)
    while(1)
     LED0=0;
         LED1=1;
       os_dly_wait(200);
    while(1)
     LED0=1;
            LED1=0;
       os_dly_wait(100);
                                             ±äá¿
*    oˉ êy Ãû: main
*    DΠ   2Î: ÎT
*    ·μ »Ø Öμ: ÎT
int main (void)
    /* 3õê¼»ˉíaéè */
     LED_Init();
                      3,                        /* èÎÎñóÅÏè¼¶ */
    while(1);
Taskcreat();
    while(1)
os_dly_wait(10);
                                         1,                          //èÎÎñóÅÏè¼¶
                                         2,                          //èÎÎñóÅÏè¼¶
os_dly_wait(10);
*    1|ÄüËμÃ÷: LEDéá˸
*    DΠ   2Î: ÎT
*    ·μ »Ø Öμ: ÎT
*   óÅ Ïè ¼¶: 1
    while(1)
     LED0=0;
         LED1=1;
       os_dly_wait(200);
    while(1)
     LED0=1;
            LED1=0;
       os_dly_wait(100);
为什么Taskcreat(void)里面必须加个延时灯才闪烁啊~不加延时貌似程序跑不到里面啊~
 楼主| 发表于 2016-4-20 13:35:49 | 显示全部楼层
貌似复制了两次sorry
 楼主| 发表于 2016-4-20 13:40:15 | 显示全部楼层
                                         1,                          //èÎÎñóÅÏè¼¶
                                         2,                          //èÎÎñóÅÏè¼¶
///os_dly_wait(10);
把这个延时注释掉就不亮了,加上延时就亮
发表于 2016-4-20 19:17:04 | 显示全部楼层
带os的程序,任务不能让它自己返回,要么死循环,要么主动删除任务,你这里虽然看上去像是任务正常了,其实还是留下了巨大隐患,那个返回的任务很可能会跑飞的
 楼主| 发表于 2016-4-28 21:00:58 | 显示全部楼层
谢谢版主
GMT+8, 2026-11-25 22:11 , Processed in 0.133699 second(s), 23 queries .
