查看: 7995|回复: 5
[有问必答] F407的外部触发ADC无法工作
发表于 2016-4-14 11:22:41 | 显示全部楼层 |阅读模式
目的是为了实现外部给一个信号就转换一组规则组,用的是EXIT_11选做PF11口,接了按键0所在的PE2,希望通过按键来实现外部触发来AD转换,但是无论我的按键却没有反应,始终运行之后都会转换一组(无论我按不按键,有时候还会转换两组)然后就没反应了,是我没启动中断触发AD吗?可是该配置的函数我都配置了才对?
void  Adc_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
        ADC_InitTypeDef       ADC_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);//ê1ÄüGPIOAê±Öó
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); //ê1ÄüADC1ê±Öó
         //Ïè3õê¼»ˉADC1í¨μà5 IO¿ú
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4;//ê1ÄüáËADC1μÄ0£¬1£¬2í¨μà
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;//Ä£Äaêäèë
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;//2»′øéÏÏÂà-
  GPIO_Init(GPIOA, &GPIO_InitStructure);//3õê¼»ˉ
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,ENABLE);          //ADC1¸′λ
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,DISABLE);        //¸′λ½áêø
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;//¶àá¢Ä£ê½
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;//ὸö2éÑù½×¶ÎÖ®¼äμÄÑó3ù5¸öê±Öó
  ADC_CommonInitStructure.ADC_DMAAccessMode =  ADC_DMAAccessMode_1; //DMAģ꽶t
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;//Ô¤·ÖÆμ4·ÖÆμ¡£ADCCLK=PCLK2/4=84/4=21Mhz,ADCê±Öó×îoÃ2»òa3¬1y36Mhz
  ADC_CommonInit(&ADC_CommonInitStructure);//3õê¼»ˉ
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//12λÄ£ê½
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;//é¨ÃèÄ£ê½
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//¿aÆôá¬Dø×a»»
ADC_InitStructure.ADC_ExternalTrigConvEdge =ADC_ExternalTrigConvEdge_Rising;                               //?????
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_Ext_IT11;                  //??exti_11??
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//óò¶ÔÆë
  ADC_InitStructure.ADC_NbrOfConversion = 2;//3¸ö×a»»Ôú1æÔòDòáDÖD ò2¾íêÇÖ»×a»»1æÔòDòáD3
  ADC_Init(ADC1, &ADC_InitStructure);//ADC3õê¼»ˉ
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_3Cycles);
  ADC_DMACmd(ADC1, ENABLE);
        ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
        ADC_Cmd(ADC1, ENABLE);//¿aÆôAD×a»»Æ÷
  //ADC_DMACmd(ADC2, ENABLE);
//        ADC_Cmd(ADC2, ENABLE);//¿aÆôAD×a»»Æ÷
  //ADC_DMACmd(ADC3, ENABLE);
        //ADC_Cmd(ADC3, ENABLE);//¿aÆôAD×a»»Æ÷
        EXTIX_Init();
  ADC_SoftwareStartConv(ADC1);
//ADC_SoftwareStartConv(ADC2);
// ADC_SoftwareStartConv(ADC3);
void EXTIX_Init(void)
        NVIC_InitTypeDef   NVIC_InitStructure;
        EXTI_InitTypeDef   EXTI_InitStructure;
        KEY_Init();
        GPIO_InitStructure.GPIO_Pin =GPIO_Pin_11;//ê1ÄüáËADC10£11£¬¬12í¨μà
  GPIO_Init(GPIOF, &GPIO_InitStructure);//3õê¼»ˉ
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);//ê1ÄüSYSCFGê±Öó
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOF, EXTI_PinSource11);//PF11 ᬽóμ½ÖD¶ÏÏß11
  /* ÅäÖÃEXTI_Line0 */
  EXTI_InitStructure.EXTI_Line = EXTI_Line11;//LINE0
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Event;//ÖD¶Ïê¼t
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising; //éÏéyÑØ′¥·¢
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;//ê1ÄüLINE0
  EXTI_Init(&EXTI_InitStructure);//ÅäÖÃ
        NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQn;//ía2¿ÖD¶Ï0   ????
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;//ÇàÕ¼óÅÏè¼¶0
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x02;//×óóÅÏè¼¶2
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//ê1Äüía2¿ÖD¶Ïí¨μà
  NVIC_Init(&NVIC_InitStructure);//ÅäÖÃ
因为为事件触发,所以不用写中断处理函数。
发表于 2016-4-14 12:28:27 | 显示全部楼层
有两个问题
1. 使用外部触发就不要用ADC的软启动了:  ADC_SoftwareStartConv(ADC1);
2. 你这里使能了ADC的DMA,你的DMA配置在哪里
这个模式也没有用过,没有代码可供参考了。
 楼主| 发表于 2016-4-14 14:25:14 | 显示全部楼层
eric2013:有两个问题
     ADC_MultiModeDMARequestAft .. (2016-04-14 12:28)
软启动那个我注释掉了后来,DMA的写在别的函数下,因为与此部分无关就没贴,ADC+DMA是测试过的没有问题,就是改成想触发启动之后就不行了,安福莱的例程里面也只给了一个定时器触发的AD,没有啥参考价值啊
 楼主| 发表于 2016-4-14 14:27:18 | 显示全部楼层
eric2013:有两个问题
而且我看到F1系列里面有一个ADC_ExternalTrigConvCmd(ADC1, ENABLE);函数用来启动外部触发的,但是F4的库里没有这个函数
 楼主| 发表于 2016-4-14 19:11:02 | 显示全部楼层
eric2013:有两个问题
...已解决,我外部触发口的IO模式设定的是模拟输入,应该是IO输入,就这个问题...
发表于 2016-4-15 00:03:43 | 显示全部楼层
回 mengheli 的帖子
mengheli:...已解决,我外部触发口的IO模式设定的是模拟输入,应该是IO输入,就这个问题... (2016-04-14 19:11)
我还看了一遍你的程序,的确是没有发现这个问题。
GMT+8, 2026-11-28 14:01 , Processed in 0.972844 second(s), 24 queries .
