查看: 4259|回复: 1
[emWin] 用GUIBuilder生成的窗口句柄是那个
发表于 2016-3-31 09:13:53 | 显示全部楼层 |阅读模式
用GUIBuilder生成的窗口句柄是那个,用WM_DeleteWindow怎样删除生成的窗口
  { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 320, 240, 0, 0x0, 0 },
  { LISTWHEEL_CreateIndirect, "Listwheel", ID_LISTWHEEL_0, 17, 7, 276, 179, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
WM_HWIN CreateFramewin(void) {  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);  return hWin;
发表于 2016-3-31 10:04:00 | 显示全部楼层
1、hWin 就是生成窗口的句柄,CreateFramewin()的返回值就是;
2、WM_DeleteWindow(hWin)删除生成的窗口。
GMT+8, 2026-11-23 08:16 , Processed in 1.595094 second(s), 23 queries .
