查看: 4229|回复: 4
[emWin] 新手發問  在EDIT控件上 要如何做出數值遞增之顯示效果
发表于 2016-3-23 12:18:52 | 显示全部楼层 |阅读模式
新手發問  在EDIT控件上 要如何做出數值遞增之顯示效果  謝謝
发表于 2016-3-23 14:05:03 | 显示全部楼层
给EDIT控件所在的窗口或者对话框加上一个emWin自带的定时器,定时器更新EDIT.
 楼主| 发表于 2016-3-23 21:04:27 | 显示全部楼层
eric2013:
請教eric2013     附上我生成C程序  請問要如何添加?  程序那個 i 就是想要變量  我一直搞不好  謝謝指點
[blockquote]static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    { FRAMEWIN_CreateIndirect,  "WEGOPCB",           0,                       0,  0,  800,480,FRAMEWIN_CF_MOVEABLE,0},
    { EDIT_CreateIndirect,       NULL,               GUI_ID_EDIT0,            173,93, 300,152,0,0}
[/quote][quote]
int i;
**      FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
**      Function: to initialize the Dialog items
**      call this function in _cbCallback --> WM_PAINT
[/quote][quote]void PaintDialog(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
[/quote][quote]}
[/quote][quote]
[/quote][quote]/*****************************************************************
**      FunctionName:void InitDialog(WM_MESSAGE * pMsg)
**      call this function in _cbCallback --> WM_INIT_DIALOG
[/quote][quote]void InitDialog(WM_MESSAGE * pMsg)
    //FRAMEWIN
    FRAMEWIN_SetTextAlign(hWin,GUI_TA_VCENTER|GUI_TA_CENTER);
    FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
    FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
    FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
    FRAMEWIN_SetTitleHeight(hWin,20);
    //GUI_ID_EDIT0
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_ID_EDIT0),&GUI_FontD60x80);
    EDIT_SetTextAlign(WM_GetDialogItem(hWin,GUI_ID_EDIT0),GUI_TA_VCENTER|GUI_TA_CENTER);
    EDIT_SetDecMode(WM_GetDialogItem(hWin,GUI_ID_EDIT0),i,0,255,0,0);       //   此處之 i 變量
*       Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_PAINT:
            PaintDialog(pMsg);
        case WM_INIT_DIALOG:
            InitDialog(pMsg);
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                case GUI_ID_CANCEL:
[/quote][quote]            }
        default:
            WM_DefaultProc(pMsg);
[/quote][quote]
*       MainTask
void MainTask(void)
    GUI_Init();
    WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    //PROGBAR_SetDefaultSkin(PROGBAR_SKIN_FLEX);
    //FRAMEWIN_SetDefaultSkin(FRAMEWIN_SKIN_FLEX);
    //BUTTON_SetDefaultSkin(BUTTON_SKIN_FLEX);
    //CHECKBOX_SetDefaultSkin(CHECKBOX_SKIN_FLEX);
    //DROPDOWN_SetDefaultSkin(DROPDOWN_SKIN_FLEX);
    //SCROLLBAR_SetDefaultSkin(SCROLLBAR_SKIN_FLEX);
    //SLIDER_SetDefaultSkin(SLIDER_SKIN_FLEX);
    //HEADER_SetDefaultSkin(HEADER_SKIN_FLEX);
    //RADIO_SetDefaultSkin(RADIO_SKIN_FLEX);
    while(1)
        GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
[/blockquote]
 楼主| 发表于 2016-3-23 21:15:17 | 显示全部楼层
請問 eric2013    附上我的生成C程序  要如何添加?  程序中之 i  是我設之變量   一直搞不好  謝謝你
**                      uCGUIBuilder                            **
**                  Version:   4.0.0.0                          **
**                     2012 / 04                               **
**                   CpoyRight to: wyl                          **
**              Email:ucguibuilder@163.com                        **
**          This text was Created by uCGUIBuilder               **
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
#include "BUTTON.h"
#include "CHECKBOX.h"
#include "DROPDOWN.h"
#include "EDIT.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include "MULTIEDIT.h"
#include "RADIO.h"
#include "SLIDER.h"
#include "TEXT.h"
#include &quotROGBAR.h"
#include "SCROLLBAR.h"
#include "LISTVIEW.h"
//EventsFunctionList
//EndofEventsFunctionList
*       static data
*       Dialog resource
* This table conatins the info required to create the dialog.
* It has been created by ucGUIbuilder.
int i;
    //FRAMEWIN
    //GUI_ID_EDIT0
    EDIT_SetDecMode(WM_GetDialogItem(hWin,GUI_ID_EDIT0),i,0,255,0,0);         // i 變量
    int NCode, Id;
        case WM_PAINT:
            PaintDialog(pMsg);
            InitDialog(pMsg);
        case WM_KEY:
                case GUI_KEY_ENTER:
            switch (Id)
                case GUI_ID_OK:
                case GUI_ID_CANCEL:
        default:
*       MainTask
void MainTask(void)
    GUI_Init();
    while(1)
发表于 2016-3-24 16:17:11 | 显示全部楼层
参看我们60期emWin教程的定时器部分。
GMT+8, 2026-11-23 08:16 , Processed in 0.774883 second(s), 24 queries .
